Fluid Dynamics: Waterflow out of a Tank
  • Thread starter Noorac
  • Tags
    Tank
In summary, the speed v is related to the timedependancy of hight h by a derivative with the same units as v.
Noorac
Hi, this is some questions about fluid dynamics(mostly). There are three somewhat connected questions here, I will try to organize it as best as I can.
A sylindrical tank filled with water is standing on a table, the tank has a small hole at the side of the tank at the very bottom(not underneath). The tank is placed on the table so that the water coming out of the hole will drop directly to the floor(it won't touch the table).
Variables:
Hight of table(hight from the hole in the tank to the ground) = H
Hight of waterlevel inside the tank = h
(inside)Radius of hole at the bottom of the tank = r
(inside)Radius of the tank = R
Speed at which the waterlevel inside the tank drops = V
Speed of the water flowing out of the hole = v
Distance on the floor, from the floor directly beneath the hole to where the water hits the floor = L.
I've added a sketch of the variables.
The airpressure is constant everywhere, g is gravity and works in the negative y direction, and the density of the water is constant.
Q1: What is the relation between the speed v and the speed V?
Q2: The speed V is related to the timedependancy of hight h by some differentiate. What is the relation?
Q3: What is the length L as a function of hight h?
- Bernoullis equation for incompressible liquid(see attempt at solution).
A1: The relation can be given by [itex]\rho t v \pi r^2 = \rho t V \pi R^2 = constant[/itex]
Wich means [itex]vr^2 = VR^2 = constant[/itex]. I don't know what more i need to do in order to show the relation, is this enough?
A2: I don't know how to solve this.
A3: I used Bernoullis equation to get a model for v: [itex] v = \sqrt{2gh}[/itex]. So now I have the speed v out of the hole(i think), but don't know how to get from there. It is supposed to be a function of hight h, so I think I'm not supposed to mix time into it, in which case it would be easier.
I'm mostly interested in a small push in the right direction, and any help would be much appreciated=)
Edit: I forgot to say the mass is conserved!
V is the speed the water level drops. Look at its units. What derivative in variable h has the same units and, of course, defines the same thing.
This is a typical projectile being shot off a cliff problem.
Hmm, okey, so given that my A1 is correct, I would think I could solve Q2 like this:
Velocity is the derivative of position with respect to time, so if h is the displacement:
[itex] \frac{dh}{dt} = V(t) [/itex]
If I am correct in A1, then [itex] vr^2 = VR^2 [/itex] which means [itex] \frac{vr^2}{R^2} = V(t)[/itex] which again means; [itex] \frac{dh}{dt} = \frac{vr^2}{R^2} [/itex]. Is this correct?
And for Q2: I haven't really been doing any cannonball off cliffs problems, but I would solve it as:
[itex] v(t) = \sqrt{2gh} \Rightarrow position = t\sqrt{2gh} [/itex] which represents the position of the water in x-direction as a function of time. And:
[itex] acc = -g \Rightarrow Velocity = -gt \Rightarrow position = -\frac{1}{2}gt^2[/itex] which represents the position of the water in y-direction, giving me:
[itex]position = x(t) = \sqrt{2gh} \boldsymbol{i} - \frac{1}{2}gt^2 \boldsymbol{j} [/itex] Wich I guess would be nice for a graph. But how do I go from there? Would it be possible to solve it as a quadratic equation (?) :
[itex]x(t) = -gt^2 + \sqrt{2gh}t + H[/itex], and pick the positive root?
Unless I am misunderstanding the question, I would simply answer by saying V = dh/dt.
For the water passing through the air part, first determine how long it takes the water to reach the ground. The basic assumption is that the horizontal velocity is constant. The portions of these problems are solved separately. You already have written the correct formula to determine the time for it to reach the ground - y-direction computation for t. Solve for t and use it to determine range L.
I'm going to work a bit more on it tomorrow=) Thanks for all the help!
What is the concept of waterflow out of a tank?
The concept of waterflow out of a tank is the movement of water from a higher level to a lower level due to the force of gravity. This flow is caused by the pressure difference between the water at the bottom of the tank and the surrounding atmosphere.
What factors affect the rate of waterflow out of a tank?
The rate of waterflow out of a tank is affected by several factors including the size and shape of the tank, the height of the water column, the size of the opening at the bottom of the tank, and the viscosity of the water.
How is waterflow out of a tank calculated?
The rate of waterflow out of a tank can be calculated using the Bernoulli's equation, which takes into account the pressure difference between the top and bottom of the tank, the area of the opening, and the density of the water.
What are some real-world applications of studying waterflow out of a tank?
Studying waterflow out of a tank has many practical applications, such as designing efficient irrigation systems, understanding the behavior of water in dams and reservoirs, and predicting the flow of water in plumbing systems.
How can the rate of waterflow out of a tank be controlled?
The rate of waterflow out of a tank can be controlled by adjusting the height of the water column, changing the size of the opening at the bottom of the tank, or using valves and pumps to regulate the flow. Additionally, altering the size and shape of the tank can also affect the rate of waterflow out of a tank.
