Constellation of date and the actual constellation that follows the sun
  • Thread starter Philosophaie
  • Tags
    Sun The sun
In summary, there are two forms of zodiac signs - the Tropical and Sidereal signs - which set their dates differently. The difference in stability between these two sources causes the signs to drift apart over time. Additionally, constellations do not actually move around the sun, but only appear to do so due to the Earth's position. According to Wikipedia, the drift between the two signs is 1.4 degrees per century, regardless of the RA and DEC used.
Philosophaie
462
Each month a different zodiac constellation follows around the sun day and night.
The constellation is in the house of the zodiac sign but the actual constellation is the zodiac before.
Example: the constellation of date is Libra but the constellation that follows the sun around is Virgo.
My question is what is the angle difference between the actual and when original constellation of date went around the sun.
Astronomy news on Phys.org
There are two major forms of signs. The Tropical zodiac and Sidereal zodiac
The Sidereal signs set their dates relative to the Earth's position within the Galaxy.
The Tropical signs are dependent upon the vernal equinox (seasons) to set dates.
The different stabilities of these two sources for the signs are causing them to drift apart over time.
Also, the Constellations do not travel around the sun. They appear to move because of the Earth's relative position which changes the backdrop behind the Sun.
Oh and after checking wiki (I know, an excellent source), the two signs drift apart at 1.4 degrees per century.
So you plug in any RA and DEC the regression will be 1.4 degrees per century. That will be its position however many centuries ago.
I can provide a response to this content by explaining the concept of precession. The Earth's axis slowly wobbles over time, causing a gradual shift in the orientation of the Earth's rotational axis. This phenomenon is known as precession and it has a significant impact on the position of constellations in the night sky.
The angle difference between the actual and original constellation of date can be attributed to precession. Due to the Earth's axis shifting, the position of the sun in relation to the constellations has changed over time. This means that the dates associated with each zodiac constellation have also shifted.
For example, the constellation of Libra may have been the actual constellation that followed the sun during a specific month in the past, but due to precession, it is now the constellation of Virgo that follows the sun in that same month. The angle difference between the two constellations depends on the length of time since the original constellation was associated with that month.
It is important to note that precession is a gradual process and it takes approximately 26,000 years for the Earth's axis to complete one full wobble. This means that the angle difference between the actual and original constellation of date is constantly changing and will continue to do so over time.
In conclusion, the angle difference between the actual and original constellation of date is a result of precession, which is a natural phenomenon that affects the position of constellations in the night sky. I find this concept fascinating and it serves as a reminder of the ever-changing nature of our universe.
1. What is a constellation?
A constellation is a group of stars that form a recognizable pattern in the night sky. They are used as a way to organize and map the stars.
2. What is the constellation of date?
The constellation of date refers to the constellation that is directly behind the sun on a specific date. It changes throughout the year as the Earth orbits around the sun.
3. How is the constellation of date determined?
The constellation of date is determined based on the position of the sun in the sky. As the Earth orbits around the sun, the sun appears to move against the backdrop of the stars, creating the illusion of different constellations throughout the year.
4. What is the actual constellation that follows the sun?
The actual constellation that follows the sun is called the zodiac constellation. There are 12 zodiac constellations, each representing a different month of the year.
5. Why does the constellation of date change throughout the year?
The constellation of date changes throughout the year because of the Earth's orbit around the sun. As the Earth moves, the position of the sun in the sky changes, causing the background stars to appear differently. This creates the illusion of different constellations throughout the year.
  • Astronomy and Astrophysics
  • Art, Music, History, and Linguistics
