Probability Density Function of two Resistors in Parallel
In summary, if you have two resistors in parallel, and want to find the equivalent resistance, you can use a change of variables to transform x, y to u(=z). Then, f(u,v) = f(x,y)*|J| where J is the Jacobian of the transformation and f(x,y) = 1/400 inside the ranges of x and y, 0 outside.
darthhath
I have a problem where there are two resistors in parallel and I need to find the equivalent resistance. R1 = X and R2 = Y, and X and Y are independent random variables, uniform over the range of 100-120.
If R equivalent = Z = XY/X+Y, what is probability density function of Z?
I played around with this in Mathematica, but didn't get it to work. But I don't have time to check my work or play around with this much more.
What I did was a change of variables:
u= [(1/x) + (1/y)]^-1 = What you call z
v = x
Therefore:
x = v
y = uv/(v-u)
The limits of integration are now:
u: 50 to 60
v: 100u/(100-u) to 120u/(120-u)
(This may be where I messed up)
Now, f(u,v) = f(x,y)*|J| where J is the Jacobian of the transformation and
Then f(u) = Integral of f(u,v) with respect to v.
I am unclear on everything except for the limits of integration. I know that you may have messed up, but if you could let me know what you are shooting for, maybe I can figure them out.
Thanks
Well, I did the integration of my joint pdf over all of u and v, and did not get 1. So my answer is wrong.
The whole point is that you want to transform from x,y to u(=z). However, I don't know how to do that - transform two variables to one. However, you can transform two variables to two variables, and integrate out one of the variables, which in this case is v. Once you integrate over v, then you will be left with the pdf of u, which is what you want.
The transformation itself requires calculating the absolute value of the Jacobian, as well as evaluating the new limits.
Unfortunately, this is as much detail as I am willing to provide, so I would recommend looking at a decent statistics textbook like Casella and Berger.
v = x
Therefore:
x = v
y = uv/(v-u)
u: 50 to 60
I think you are right. If you think in terms of the reciprocals of the resistance, for every Z there is a range of possible X values, with a unique Y corresponding to each X. At the limiting values of 1/Z (1/60 and 1/50) there is only 1 value of 1/X (1/120 and 1/100). Starting at 1/Z = 1/60 and increasing (decreasing Z), all 1/X values from 1/120 to a maximum are permitted, with the maximum being 1/Z - 1/120. So the range of possible values of 1/X increases linearly with 1/Z until the maximum 1/X reaches 1/100. Any additional increase in 1/Z places a lower limit on the value of 1/X, with a maxiumum 1/X at 1/100. The lower limit is also linear in 1/Z, so the range of 1/X shrinks linearly toward zero.
The point where the X range is maximized is not in the middle of the Z range, but it is in the middle of the 1/Z range. The middle of the 1/Z range occurs at
Z = 600/11 = 54.545454
The 1/Z distribution is not quite triangular, because the 1/X distribution is not quite uniform, and I'm not sure if changing back to the Z distribution from 1/Z is going to "undue" the non-linearity or compouund it, probably the latter. Roughly speaking the Z distributions should be approximately triangular from zero at 50 and 60, peaking at 54.5454. Maybe you want to revise your approach and get the final answer.
FAQ: Probability Density Function of two Resistors in Parallel
What is a Probability Density Function (PDF)?
A Probability Density Function (PDF) is a mathematical function that describes the probability distribution of a continuous random variable. It shows the relative likelihood of obtaining a certain value within a given range of values.
What does the PDF of two resistors in parallel represent?
The PDF of two resistors in parallel represents the probability distribution of the equivalent resistance when two resistors are connected in parallel. It shows the likelihood of obtaining a certain equivalent resistance value when the individual resistances have a certain range of values.
How is the PDF of two resistors in parallel calculated?
The PDF of two resistors in parallel can be calculated using the formula: f(x) = (1/R1R2) * (1/x) * e^(-1/(R1R2) * (1/x)) where R1 and R2 are the individual resistances and x is the equivalent resistance. This formula is derived from the probability distribution of the sum of two independent random variables.
What is the shape of the PDF of two resistors in parallel?
The shape of the PDF of two resistors in parallel is an exponential curve. This means that the most likely values for the equivalent resistance are those that are closer to zero, and the likelihood decreases as the equivalent resistance increases.
How is the PDF of two resistors in parallel used in practical applications?
The PDF of two resistors in parallel is used in practical applications to calculate the probability of obtaining a certain equivalent resistance value when two resistors are connected in parallel. It can also be used to determine the expected range of values for the equivalent resistance and to analyze the reliability of the parallel circuit.
