What are the Forces Behind Quark Color?
In summary, the color of quarks gives rise to the strong force, with same-color repelling and different-color attracting. The attractive force between color/anti-color is stronger than color/different color, but there is no clear ratio between the two. The color charge is represented by a matrix belonging to the SU(3) group and when a quark and an anti-quark interact, it produces two channels: the singlet, which is attractive, and the octet, which is repulsive. Quark/anti-quark pairs can be created in both the singlet and octet configurations, depending on the source. While the singlet configuration is the only one seen physically, the octet configuration can appear in virtual processes.
xortdsc
98
Hi,
the "color" of quarks gives rise to the strong-force. I've read on some page (cannot remember where) that same-color repels and different color attracts. Additionally it was stated that the attractive force between color/anti-color is stronger than color/different color. But no ratios or any details were given. Is there such clear ratio between the two ?
Also if a pair of quark/anti-quark is created will they always be anti-colored (e.g. a green quark and an anti-green anti-quark) ?
Yes. Color charge is conserved.
The situation is not that easy. The color charge is not a number as the electric charge. It is, instead, represented by a matrix belonging to the SU(3) group. Consider, for example, two quarks (keep in mind that quarks are not the only particles carrying color, we also have gluons). In group theory language we say that quarks belong to the [itex]3[/itex] representation of SU(3), i.e. their color is represented by the 3x3 Gell-Mann matrices. It turns out that when a quark and an anti-quark (which belongs to the [itex]\bar 3[/itex] representation) interact, this interaction produces two "channels": the singlet, [itex]1[/itex], and the octet, [itex]8[/itex]. The singlet is attractive while the octet is repulsive.
However, the situation is complicated. If you want more insight you should look at some QCD book. The most rough way to estimate whether or not the interaction between to colored particles is attractive or not is to use the so-called "one gluon exchange" approximation. I'm sure that you can find enough info on that on Google.
It depends on what creates the pair. If the quark/anti-quark pair is created from the vacuum, from photon or from any other colorless source, then the final net color must be zero (by conservation of the color charge), which means that the pair is automatically created in a singlet configuration. However, if the pair is created from a gluon (which belongs to the octet of SU(3)) then it will be created in the octet as well, i.e. in a colorful configuration.
The only color combination for a quark-antiquark state that is seen physically is the color singlet
[tex](G-{\overline G}-(R-{\overline R}+(B{\overline B})/\ sqrt{3}[/tex].
Nothing is known about the dependence on color, because only the one combination is known.
The singlet configuration is the so-called "asymptotic state". However this doesn't mean that we can't say anything about the octet configuration. It can appear, for example, in radiative virtual processes. Consider for example the quark/anti-quark loop contribution from the gluon self energy.
You are right when you say that we have never experimentally seen any configuration different from the singlet one, however the fact that QCD works so well in describing the experiment can be considered as a strong indication that quark/anti-quark in the octet representation can actually be produced in non-asymptotic states.
1. What is quark color?
Quark color is a property of subatomic particles called quarks, which are the building blocks of protons and neutrons. It is not related to the colors we see in the visible spectrum, but rather refers to the way quarks interact with each other through the strong nuclear force.
2. What are the forces behind quark color?
The forces behind quark color are known as the strong nuclear force or strong interaction. This force is responsible for holding quarks together to form protons and neutrons, and is one of the four fundamental forces in nature.
3. How does the strong nuclear force work?
The strong nuclear force works by exchanging particles called gluons between quarks. The gluons carry a "color" charge, which is similar to the electric charge carried by particles interacting through the electromagnetic force. This exchange of gluons creates a strong binding force between quarks, keeping them together within a proton or neutron.
4. How many colors do quarks have?
Quarks have three "colors": red, green, and blue. These colors are simply labels used to describe the way quarks interact with each other and do not correspond to the colors we see in the visible spectrum. Particles made up of quarks, such as protons and neutrons, are colorless because they contain a balanced combination of all three colors.
5. Are there any other forces besides quark color?
Yes, besides the strong nuclear force, there are three other fundamental forces in nature: gravity, electromagnetism, and the weak nuclear force. The weak nuclear force is responsible for certain types of radioactive decay, while electromagnetism is responsible for interactions between particles with electric charge. Gravity is the weakest of the four forces and is responsible for the attraction between objects with mass.
  • High Energy, Nuclear, Particle Physics
  • Beyond the Standard Models
  • Cosmology
