- #36
Baluncore
2023 Award
- 14,439
- 8,336
Not true. That is where the semiconductor H-bridge, class D amplifier, works well.EinsteinKreuz said:In the case of audio electronics, digital will never truly replace analog because without conversion back into analog, you wouldn't be able to hear digitized recorded sound!
Not true. You are assuming class A, without feedback. In reality, analogue transistor amplifiers are way more linear than VT amplifiers. That is because the circuit can be designed using many more integrated transistors than could possibly be done with VTs. It it possible to build ultra-linear SC amplifiers that require only milliwatts of power. Saturation of any device will always cause harmonic distortion. VTs and SCs both have the same saturation problem.EinsteinKreuz said:The problem with analog transistor amplifiers is that semiconductors are nonlinear in terms of the output current response to input voltages( collector current plotted against base-emitter voltage) and have very low impedance. This causes unwanted distortion of large signals(the clipping effect which is very unpleasant to the human ear).
Semiconductors do not require coupling capacitors or level-shifting because two polarities of device are available.EinsteinKreuz said:To minimize the distortion of large signals you need bypass capacitors and swamping resistors.
A VT is an N-channel FET with a pilot lamp. There is no equivalent to the P-channel FET in VTs.
It is a mistake to argue that VTs are better than SCs. There are places where each has it's place.
Emotions are not rational. People who think VTs are better will buy higher priced VT audio amplifiers.
