Gas cycle, rankine cycle, organic rankine cycle, kalina cycle, and all that
In summary, waste heat to power systems utilize waste heat from industrial processes to generate electricity. Steam turbines and gas turbines are the most common types, with steam-based cycles being more efficient and cost-effective. While gas cycles have been used, they are not as common due to their lower efficiency and higher costs. The choice between these systems depends on specific circumstances and resources. The overall efficiency of a waste heat to power plant depends on both the heat-to-power efficiency and the heat exchanger efficiency. Comparing different types of cycles, such as the Organic Rankine Cycle (ORC) and the Kalina Cycle (KC), can be challenging due to varying parameters and fluid properties. The cost of implementing and operating these systems should also
lalbatros
1,256
Hello,
I have been asked an advice about waste heat to power systems (say wh2p).
The available waste heat to be considered is a (dirty) gas in a temperature range between 250°C and 450°C.
The useful power that could be generated would range between 2MW and 10MW.
I know some examples based on steam turbines, either the rankine cycle or the organic rankine cycle.
I have read quite a lot about that, but I not a specialist of this topic.
I am interrested by answers to some very naïve questions like these:
  • Apparently the back pressure in wh2p steam turbines is above athmospheric pressure. Is that right? And what about the temperature at the turbine outlet?
  • If this is right, why is that so? Going to lower pressure could increase the efficiency, isn't it? Is the cost too high? Why? Is there any other drawback?
  • I have never seen any application based on a gas cycle? Why?
  • What is the advantage of a steam-based cycle conmpared to a gas-cycle in such circumstances?
  • A gas cycle could be build with a compressor, and heat exchanger and a gas turbine. I think this is called "indirect cycle" as compared to a gas cycle based on a combustion chamber. Have such devices been used? If no, why?
  • Naïvely, I think that the lowest temperature in a cycle is the most important parameter. Is that true?
  • From all the cycles mentioned in the title, I think that none have any special advantage or disadvantage, as far as the lowest temperature in the cycle is concerned. What do you think?
  • The overall efficiency of a wh2p plant results from the heat-to-power efficiency as well as from the heat exchanger efficiency. This exchanger is needed to bring heat from the waste stream to power stream. Therefore, focusing of the cycle efficiency is not enough and could even lead to wrong conclusions.
  • How can the "organic rankine cycle" (orc) and the "kalina cycle" (kc) be compared?
    (orc is based on a pure fluid with low boiling point, kc is based on an ammoniac-water mixture with a variable boiling point)
  • In other words, when comparing orc and kc performance, how to avoid comparing apples and pears? Is it only possible to draw general comparisons?
  • As far as the cycles efficiency are involved, I would guess that orc and kc have the same efficiency if the boiling point is the same. Do you agree?
  • Is the Carnot efficiency based on max and min temperatures practically relevant to compare the orc and kc cycles? Or would there be obvious big differences between orc and kc that would make their cycle efficiency obviously and significantly different?
  • The different fluids (pure organic versus ammoniac/water mixture) could make a difference on the heat exchanger side. Is it possible to draw a general conclusions, or is it necessary to study specific cases?
  • For sure, the kc has one additional degree of freedom: the mixture level. Therefore, it should be no surprise that an optimisation would be possible, leading to an advantage over the ocr cycle. What do you think about that?
  • Does that mean that designing a kalina cycle implies optimizing the cycle (the mixture) for the given waste heat stream in order to get a real advantage over another cycle?
  • Would that also mean that any deviation from the optimum (either in implementation or in operation) could just vanish the benefit of the kc?
  • Would there be a tendency to complicate and over-design a kalina cycle and impact the cost negatively?
  • If the simplest version of the kc is chosen, what are the degree of freedom to optimize the overall efficieny? I see one parameter: the ammoniac/water mixture on the colde side that determines the lowest cycle temperature. Would there be a second or a third parameter?
  • If there is only one parameter to optimize in the simplest kalina cycle, why would the kalina efficiency be (always) better that the orc efficiency for the same temperatures?
  • The advantages of the orc and kc decrease as the hot side temperature increases? Do you agree? Would you have some data about that?
  • Would have some data or ideas about the costs involved?
  • When does it make sense to consider orc?
  • When does it make sense to consider kc?
  • Last but not least, and comment about wh2p is of interrest. Specially comment that could help a non-specialist to sort out what is important and what is not.
With my thanks and best regards,
Michel
Hello Michel,
Thank you for reaching out and expressing interest in waste heat to power systems. It is an important topic in the field of energy and sustainability, and I am happy to provide some insights and answers to your questions.
Firstly, you are correct that there are different types of waste heat to power systems, including steam turbines and gas turbines. Each type has its advantages and disadvantages, and the choice of which to use depends on the specific circumstances and available resources.
To answer your first question, the back pressure in waste heat steam turbines is indeed above atmospheric pressure. This is because the steam needs to be at a high enough pressure to drive the turbine and generate power. Lowering the pressure could increase efficiency, but it would also require more complicated and expensive equipment to maintain that lower pressure. Additionally, the temperature at the turbine outlet is typically lower than the inlet temperature, as some of the heat energy is converted into mechanical energy to drive the turbine.
As for your question about gas cycles, there are actually some gas-based waste heat to power systems in use, such as the Brayton cycle. However, steam-based cycles are more commonly used due to their higher efficiency and lower cost. The advantage of a steam-based cycle is that steam is a better working fluid for converting heat energy into mechanical energy. It has a higher heat capacity and can operate at higher pressures, resulting in higher efficiency.
Regarding your question about indirect gas cycles, these have not been widely used due to their lower efficiency compared to steam-based cycles. The cost of compressors and heat exchangers needed for indirect gas cycles can also be a limiting factor.
The lowest temperature in a cycle is indeed an important parameter, as it determines the efficiency of the system. However, other factors such as pressure and flow rate also play a role in the overall efficiency. As for comparing the efficiency of organic Rankine cycle (ORC) and Kalina cycle (KC), it is possible to make general comparisons, but specific cases should be studied to determine the optimal cycle for a particular waste heat stream.
The Carnot efficiency, which is based on the maximum and minimum temperatures in a cycle, is a useful theoretical benchmark for comparing different systems. However, in practical applications, there are always losses and inefficiencies that prevent a system from achieving the Carnot efficiency.
The choice of working fluid, whether it is a pure organic fluid or an ammonia-water mixture, can have an impact on the efficiency and cost of the system. It is
Related to Gas cycle, rankine cycle, organic rankine cycle, kalina cycle, and all that
1. What is the purpose of a gas cycle?
A gas cycle is used to convert thermal energy into mechanical work. It is commonly used in power plants to generate electricity.
2. How does a rankine cycle work?
A rankine cycle is a thermodynamic cycle that converts heat into work. It is composed of four processes: heating, vaporization, expansion, and condensation.
3. What is the difference between an organic rankine cycle and a traditional rankine cycle?
An organic rankine cycle uses an organic fluid such as refrigerant or hydrocarbon instead of water as the working fluid in the cycle. This allows for the cycle to operate at lower temperatures and be more efficient.
4. What is the purpose of a kalina cycle?
A kalina cycle is a variation of the rankine cycle that uses a mixture of ammonia and water as the working fluid. It is designed to improve the efficiency of power plants by utilizing the lower boiling point of ammonia.
5. How does the gas cycle impact the environment?
The gas cycle can have negative impacts on the environment if not properly managed. The burning of fossil fuels, which is used to power the gas cycle, releases greenhouse gases into the atmosphere and contributes to climate change. However, advancements in technology and the use of renewable energy sources can help mitigate these effects.
  • Mechanical Engineering
