How to solve 2nd order diff. eqn.
  • Thread starter physiker99
  • Tags
    2nd order
In summary, the method to solve a differential equation involves assuming a solution of the form y=erx and substituting it into the equation to find the characteristic polynomial. The roots of the polynomial will give the values of r for which the assumed solution will satisfy the equation. From there, the general solution can be found by plugging in the values of r into the equation.
physiker99
36
what's the method to solve a diff. equation as follows:
d^2(psi)/d(x^2) - (k^2)*(psi) = 0
Notice that:
[tex] \frac{d^2 \psi}{dx^2}=k^2 \psi[/tex]
And the general solution is,
[tex]\psi(x) = Ae^{kx} + Be^{-kx}[/tex]
Since
[tex]\frac{d^2 \psi}{dx^2} = k^2(Ae^{kx} + Be^{-kx}) = k^2 \psi(x)[/tex]
thanks kreil. but how do you get a*e^kx and b*e^-kx?
When you have a linear differential equation with constant coefficients, like yours, you assume a solution of the form y=erx and substitute it into the equation. You'll get what's called a characteristic polynomial. Its roots are the values of r for which your assumed solution will satisfy the differential equation.
The method for solving a second order differential equation, such as the one provided, is known as the "method of undetermined coefficients." This method involves assuming a solution for the equation in the form of a polynomial or exponential function and then substituting it into the equation to solve for the unknown coefficients. The specific steps for solving the equation would depend on the initial conditions and boundary conditions given. Another method that can be used is the "method of variation of parameters," which involves finding a particular solution by varying the parameters in the assumed solution. Both of these methods require a good understanding of calculus and algebra, as well as knowledge of specific techniques for solving differential equations. It is also important to check the solution obtained to ensure it satisfies the original equation.
1. How do I determine the order of a differential equation?
The order of a differential equation is determined by the highest derivative present in the equation. For example, if the equation contains a second derivative, it is a second order differential equation.
2. What is the general form of a 2nd order differential equation?
The general form of a second order differential equation is y'' + P(x)y' + Q(x)y = R(x), where P(x), Q(x), and R(x) are functions of x and y' represents the first derivative of y.
3. How do I solve a 2nd order differential equation with constant coefficients?
To solve a second order differential equation with constant coefficients, first find the roots of the characteristic equation. Then, use these roots to determine the general solution by using the form y = C1e^(r1x) + C2e^(r2x), where C1 and C2 are constants and r1 and r2 are the roots of the characteristic equation.
4. Is there a shortcut method for solving 2nd order differential equations?
Yes, for certain types of differential equations, such as homogeneous or linear equations, there are shortcut methods such as substitution or variation of parameters that can be used to solve them.
5. Can I use a calculator to solve 2nd order differential equations?
It is not recommended to use a calculator to solve 2nd order differential equations as it may not give accurate results. It is best to solve them by hand or use a computer software specifically designed for solving differential equations.
