Solve Rigid Body Motion: Pendulum Rod & Disk Eqns of Motion
In summary: You might be able to use the angle between the radius from P to the disk center and the vertical to find the moment of inertia about the CM.
Logarythmic
281
Problem statement:
Consider a pendulum consisting of two parts: a uniform rod of mass m, length l, negligible thickness and with one end fixed; and a uniform disk of mass [tex]\mu[/tex] and radius [tex]\rho[/tex].
The rod is moving in a plane, and the disk is attached at a point P on its boundary to the non-fixed end of the rod, in such a way that it can freely rotate about P in the plane in which the rod is moving.
Obtain the Lagrangian and the equations of motion.
I suppose I should divide this into two parts; one for the rod and one for the disk.
For the rod I get
[tex]T_1 = \frac{1}{2} I_1 \dot{\theta}_1^2 + \frac{1}{2} m(\dot{x}_1^2 + \dot{y}_1^2)[/tex]
,where the index 1 is the rod, and
[tex]V_1 = mgh = mg \frac{l}{2} (1 - \cos \theta_1)[/tex].
The moment of inertia for the rod is
[tex]I_1 = \frac{1}{3} m l^2[/tex].
So far so good, I think.. But how should I do with the disc? Should I treat this the same way and just use a superposition of the two lagrangians? And how do I get the moment of inertia?
Can you post a picture ? I'm unable to imagine the setup.
Daniel.
P.S. There's no such thing as a superposition of lagrangians.
This is what I think it should look like. I guess it's like a double pendulum with two rigid bodies.
The double pendulum sounds right to me. The moment of inertia of the disk about its pivot point P can be obtained using the parallel axis theorem. I think you would want to use two angles as your generalized coordinates, one for the rod and one for the disk.
So the kinetic energies are just
[tex]T_{rod} = \frac{1}{2} I_O \dot{\theta}_1^2[/tex]
and
[tex]T_{disc} = \frac{1}{2} I_P \dot{\theta}_2^2[/tex]
or should I include translation movement aswell?
I get the equations of motion to be
[tex]0 = \mu \left[ l \ddot{\theta}_1 + R \dot{\theta}_2 \sin{(\theta_1 - \theta_2)} (\dot{\theta}_1 - \dot{\theta}_2 + \dot{\theta}_1 \dot{\theta}_2) + R \ddot{\theta}_2 \cos{(\theta_1 - \theta_2)} + g \sin{\theta_1} \right] + \frac{1}{2} mg \dot{\theta}_1 \sin{\theta_1}[/tex]
and
[tex]0 = R \ddot{\theta}_2 + l \ddot{\theta}_1 \cos{(\theta_1 - \theta_2)} - l \dot{\theta}_1^2 \sin{(\theta_1 - \theta_2)} + g \sin{\theta_2} [/tex]
where I have used R instead of [tex]\rho[/tex]
Could this be correct?
and
You will need translation and rotation for the disk- translation of the CM and rotation about the CM. I did not look at your equations of motion yet. Did you include more than what you have here?
Yes I used
[tex]T_{rod} = \frac{1}{2} I_O \dot{\theta}_1^2 [/tex]
and
[tex]T_{disc} = \frac{1}{2} I_P \dot{\theta}_2^2 + \frac{1}{2} m (\dot{x}_2^2 + \dot{y}_2^2) [/tex]
where [tex]I_O[/tex] is the moment of inertia about the upper end of the rod, [tex]I_P[/tex] is the moment of inertia about the pivot point P and [tex]x_2[/tex] and [tex]y_2[/tex] are the coordinates of the c.m. of the disc.
Logarythmic said:
Yes I used
and
With x and y the coordinates of the CM, then the I for the disc should be the I about the center of mass.
But if I'm using I about P, what should I include then?
You could express the moment of inertia about the center of mass in terms of the moment of inertia about P by using the parallel axis theorem, but why would you want to? The CM is a special point in an assembly of particles or a rigid body that (among other things) permits the separation of kinetic energy into the translation of the CM term and the rotation about the CM term. No arbitrary point is so well behaved.
When you used x and y translational velocities for part of the kinetic energy, you were already including some of the energy of rotation about P. If you use I about point P, you will be couble counting some of the energy contribution.
So
and
[tex]T_{disc} = \frac{1}{2} I_{CM} \dot{\theta}_2^2 + \frac{1}{2} m (\dot{x}_2^2 + \dot{y}_2^2) [/tex]
is correct?
Logarythmic said:
So
and
is correct?
Looks right to me. With Io being the moment of inertial of the rod about its end.
For what it's worth, I found it easier to do the algebra using the angle between the radius from P to the disk center and the vertical. That would be the sum of your angles I believe. When the algebra is done it can be expressed in terms of your angles.
That's how I've done it. =) Thanks for your help!
which one is right?
Could you explain a little?
1. What is a rigid body motion?
A rigid body motion is a movement of a solid object in which all the points of the object move in parallel without any deformation or change in shape.
2. What is a pendulum rod?
A pendulum rod is a thin, rigid rod that is attached to a fixed point at one end and has a mass or object attached to the other end. It is used to study the motion of a pendulum and can be used to measure time or demonstrate concepts in physics.
3. What are the equations of motion for a pendulum rod and disk?
The equations of motion for a pendulum rod and disk can be derived using Newton's laws of motion. They include the equation for torque, angular acceleration, and the conservation of energy.
4. How do you solve for rigid body motion in a pendulum rod and disk system?
To solve for rigid body motion in a pendulum rod and disk system, you need to use the equations of motion and apply them to the specific system. This typically involves setting up and solving a differential equation to find the position, velocity, and acceleration of the pendulum.
5. What are some real-world applications of solving rigid body motion in a pendulum rod and disk system?
Solving rigid body motion in a pendulum rod and disk system can be applied in a variety of fields, such as engineering, physics, and astronomy. It can be used to analyze the motion of a clock pendulum, the motion of a bridge during an earthquake, or the orbit of a satellite around a planet.
