Can galaxies separate at speeds faster than the speed of light?
In summary, the speed at which galaxies separate cannot exceed the speed of light. Most galaxies we can see have a redshift greater than 1.5, and so are receding faster than the speed of light.
iamBevan
32
Can the speed at which galaxies separate exceed the speed of light?
Space news on Phys.org
No, as with all objects, as the relative speed between the two increases, relativistic effects (such as increased mass and time dilation) work to create a limit on their speeds.
Dave
Sure, if the universe is expanding as per the "big bang", then effectively the separation would be "superluminal".
However, in inertially defined space, the answer is still no...
Clear as mud eh?
There is an article that I once read talking about faster than light particles that could have been created in the big bang, but would be relegated to always being faster than light. They wouldn't be able to slow down and would be trapped on the other side of the asymptote. I think this is the ref... Don't have time to read it now.
http://prola.aps.org/pdf/PR/v159/i5/p1089_1
General relativity doesn't provide a uniquely defined way of measuring the velocity of objects that are far away from one another. There is no well defined value for the velocity of one galaxy relative to another at cosmological distances. You can say it's some big number, but it's equally valid to say that they're at rest, and the space between them is expanding. Neither verbal description is preferred over the other in GR. Only local velocities are uniquely defined in GR, not global ones.
B. Crowell pretty well said it. Beyond that, you should realize that the speed at which MOST galaxies we know of are receding exceeds the speed of light---assuming it is the speed and distance that you see in the Hubble Law
v = Hd
In the Hubble Law, the distance d is the freezeframe distance (as if you could stop the expansion process and measure with radar or yardstick, any conventional means, the distance at that moment) and v is the rate at which that distance d is increasing.
Most of the galaxies we can see have redshift > 1.5 and it is just a fact that any such galaxy is at this moment receding faster than light. As per Hubble Law.
We see galaxies with redshifts out past 5, 6, 7 and more. Most of the universe which we study is redshift > 1.5 and therefore receding > c.
I have a cosmology calculator link in my signature that gives recession speeds:
http://www.uni.edu/morgans/ajjar/Cosmology/cosmos.html
You have to give it 3 model parameters on the LHS margin (.27, .73, 71) and THEN the redshift. Press calculate and it gives the distances and recession rates. Try redshift 1.7, you may be surprised! Ask if you have any questions.
FAQ: Can galaxies separate at speeds faster than the speed of light?
1. What is the definition of "galaxies separation speed"?
The galaxies separation speed refers to the rate at which galaxies move away from each other within the expanding universe. It is typically measured in units of kilometers per second.
2. How is the galaxies separation speed measured?
The galaxies separation speed is measured using a variety of methods, including the redshift of light from distant galaxies, the Doppler effect, and the Hubble Law. Scientists also use computer simulations to model the movement of galaxies over time.
3. What factors influence the galaxies separation speed?
The galaxies separation speed is influenced by the overall expansion of the universe, as well as the distribution of matter and energy within it. Dark energy, a mysterious force that is thought to be responsible for the accelerating expansion of the universe, also plays a role in determining the galaxies separation speed.
4. Can the galaxies separation speed change over time?
Yes, the galaxies separation speed can change over time due to the effects of gravity and dark energy. As the universe continues to expand, the galaxies separation speed is expected to increase, resulting in even greater distances between galaxies.
5. How does the galaxies separation speed impact our understanding of the universe?
The galaxies separation speed is a crucial component of our understanding of the universe and its evolution. It provides evidence for the expanding universe and the concept of the Big Bang, and helps scientists to map the large-scale structure of the cosmos. Studying the galaxies separation speed also allows us to better understand the nature of dark energy and the fate of the universe.
