Electric force problem (determining unknown position to make zero net force)
In summary, in order for a proton to experience no net force, it must be placed either to the left of the positive charge or to the right of the negative charge. By using the equation F01 = F02 and solving for r using the quadratic formula, we can determine the position of the proton. The two possible positions are at +0.414cm or -2.41cm, where the magnitudes of the two forces are equal. However, the direction of the forces must be opposite, so the required position of the proton is 2.41cms on the side opposite the negative charge.
KYUI
A +2.0-nC charge is at the origin and a -4.0-nC charge is at x = 1.0-cm.
At what x-coordinate could you place a proton so that is would experience no net force?
[NOTE by me] I put q1 as the positive charge (+2.0nC) and q2 as the negative charge (-4.0nC). q0, of course, is the proton.
- quadratic formula
- F0 = F01 - F02 which becomes F01 = F02 when I replace F0 with zero (no net force).
So I know that the proton must be either to the left of the positive charge or the right of the negative charge. It can't be in between these two charges for it to have zero net force.
I plugged in numbers into this equation (F01 = F02) which became:
(2 x 10-9)/(r2) = (4 x 10-9) / ((1.0 x 10-2) + r)2
I simplified this and got:
0 = r2 + (2 x 10-2)r - (1 x 10-4)
Then I solved for r using quadratic formula and got:
r = (+ 4.1421 x 10-3) or (- 2.4142 x 10-2).
I thought the negative number would automatically cancel out because r is distance but the actual answer goes with the negative number. I'm confused at how cramster.com explained it.
The book is called Physics for Scientists and Engineers A Strategic Approach (2nd) by Randall Dewey Knight) and its chapter 26 number 47. Here's a direct link (have to be a member though; it's free to look at odd numbers): http://physics.cramster.com/physics-for-scientists-and-engineers-a-strategic-approach-2nd-problem-9-718769.aspx
Thanks.
Well r is measured relative to the origin, so if you get r is positive, you place the proton where the force between the proton and the +ve charge pushes it towards the negative charge.
Otherwise, r is negative, and the proton is placed to the left of the +ve charge. The force between the proton and the positve charge pushes it away i.e. towards the left. The Force between the proton and the -ve charge will attract it i.e. attract it towards the right. Thus with r negative, there exists a location where the net force is zero.
Do you understand a little more now?
Thanks for answering my question. I really appreciate it. And I'm sorry I still don't understand :(
I understand that r can be negative and relation to the origin but I don't understand how to determine which number (that I found for r) is used as the answer.
If r is positive, the proton will be on left side of the positive charge, right? I thought it would be attracted to the negative charge and repelled by positive charge to possibly get a net zero force, no?
And same thing for negative r. It will be on the right side of the negative charge, right? Then it would be attracted to the negative charge and repelled by positive charge in the same way to possibly get a net zero force.
Mm I don't know if I'm making my question clear. Do you have to determine the position by calculating it and prove if the net force is zero or not?
Thanks again.
Thanks again.
Since you used the condition [itex]F_{01} = F_{02}[/itex], whatever value of r you get, that is where the net force is zero. But I can't see how the book explained it as I need to join. I understand what you're saying and both answers should be correct.
This is what it said:
"x = +0.414cm or -2.41cm at the above two points the magnitudes of the two forces are equal. At point .414cm the magnitudes of both the forces are equal but the directions are same. But we require the forces to be in opposite direction. So the required position of the proton is 2.41cms on the side opposite q_2. "
They also used same equation as me: F01 = F02.
1. What is the electric force problem?
The electric force problem is a physics problem where the goal is to determine the unknown position of a charged particle in order to achieve a zero net force on the particle.
2. Why is it important to solve the electric force problem?
Solving the electric force problem allows us to understand the behavior of charged particles and how they interact with each other. This knowledge is crucial in various fields such as electricity, magnetism, and electronics.
3. What are the key principles involved in solving the electric force problem?
The key principles involved in solving the electric force problem are Coulomb's law, which describes the force between two charged particles, and the principle of superposition, which states that the total force on a charged particle is the sum of the individual forces from all other charged particles.
4. How do you determine the unknown position in the electric force problem?
To determine the unknown position, you would first need to identify all the known positions and charges of the particles involved. Then, using the principles mentioned above, you can set up an equation and solve for the unknown position.
5. Are there any real-life applications of the electric force problem?
Yes, the electric force problem has many real-life applications such as in the design of electrical circuits, the behavior of particles in particle accelerators, and the interaction between charged particles in atoms and molecules.
