What is the magnetic field inside a cylinder with a hole?
In summary, the conversation is about solving a physics question involving a cylinder with a hole and determining the magnetic field inside the hole. The participants discuss the use of Ampere's Law and the principle of superposition to solve the problem. There is also a question about why the field inside the hole is constant and the use of the constants c and d in the solution.
Planck const
First I have to say that my English isn't good:)
Ok..
There is a cylinder that at him, there is hole.
Cylinder radius is "a" and the hole radius is "b"
The distance from the cylinder center to the hole center is "d".
The current density is "J", in the hole there is nothing.
What is the field inside the hole?
Why the answer is 2PiJd/c in the book (CGS), why the field in it is constant(by heart the book) ?
Amper rule?
I can look in this quesion, like all the cylinder got +J and the hole - -J.
So I choose the positive direction in the direction of the J in hole.
I can use Amper rule:
B*P(hole) = mu0*J*A(hole)
So:
B*2pir=mu0*J*pir^2
B=mu0*Jr/2
Why the gave me a,d,b ? In the hole there is variable field!
Thanks in advance
First of all, welcome to PF, the world of physics.
Definately Ampere's law I think. I am not quite sure about this question.
Is A really the area of the hole? Because current in Ampere's Law is the current passing through the area attached to the close loop. But what is c in the answer? c=confusion?
amperes law will not be valid in this case
revise your notes and you will see why
"fill" the hole with +current and equal -current
so the net current remains 0
now club the +current of as 1 single wire
and calculate its magnetic field at the desired point
and similarly for the -current
then add vectoricaly
i hope you get it
i find it difficult to explain
Are you aware of the principle of superposition of fields?It follows directly from this principle that if a part of the source of the field is removed the field due to that part vanishes.So you can picture the hole in the wire as this: a part of the source of the field(the current) has been removed so the new field is actually the original filed minus the field of the current removed(of course vectorially).If you formulate the vector equation upto this point with the cross products and all you will see clearly why it comes out to be a constant.
Edit:
Ampere's Law is ALWAYS valid as long as you deal with classical physics.How do you mean that,Troglio?
i hope you get it
Then how to do it? Other than ampere's Law, what else can you use? Biot-Savart? I think you mean there is no current passing through the cross section of the hole. But in this case field is generated by current in the wire due to assymmetry of the wire, if they are coaxical cylinders there would not be any field. So the same question as OP's: why it's uniform? There is part where symmetry is valid but there is point where there is not.
Reply
Zeal - Thanks:)
Im not sure about the area.. Is it 2Pi*b*L...or 2Pib^2. I chose the secen - 2Pib^2 becuse I tought L (lenght) won't be reduced. c = velocity of light
Troglio - So which law will worked?!
about your idea... I will get +B and -B ? because its one dimension (the donations of the two currents are opposite..don't they?
Aim - I heard about superposition :)
So you say (I mean.. I say :))
I equal= A(of cylinder)J-A(of hole)J = 2PiLJ(a-b) or (As written above) PiJ(a^2-b^2)
Im not getting the solution that written in the book... if I use Amper rule.
Thanks about the replies!
So by c the answer implies that there is a square root of ε0μ0? But this doesn't make sense as there isn't any suggestion of using electric field here.
I can't work out the answer like that either and I don't think my answer is correct either. But at least I think that there is no current passing through the hole, so why use the cross section of the hole?
i can't reply in tech terms bcoz i dnt know much f them
so excuse m for that
i meant superposition
fill the hole with + and -
anperes law wouldn't work bcoz of lack of symetery
amperes law works some wat like gauss law in electro
Yes, they are much alike, and there is assymetry, so I think here we just use the current passint through the loop which has no symmetrical counterpart.
State the Ampere's Law clearly and also the reason you think makes it invalid.
[Please make a distinction between "The law works" and "The law is not valid"]
Edit::Repost.
aim1732 said:
Edit::Repost.
There is an option of deleting a post too :wink:
And that is exercised only by moderators.They did,actually.Two posts are missing.
Related to What is the magnetic field inside a cylinder with a hole?
1. What is a magnetic field?
A magnetic field is a region in space where a magnetic force can be detected. It is created by moving electric charges, such as electrons, and is represented by magnetic field lines.
2. How is a magnetic field measured?
A magnetic field is measured using a device called a magnetometer. This device can detect the strength and direction of a magnetic field at a specific location.
3. What is the difference between a magnetic field and an electric field?
A magnetic field is created by moving electric charges, while an electric field is created by stationary electric charges. Additionally, magnetic fields are detected with a compass, while electric fields are detected with a voltmeter.
4. How is a magnetic field used in everyday life?
Magnetic fields have many practical applications in everyday life, including in motors, generators, compasses, and MRI machines. They are also used in credit and debit cards for data storage.
5. Can magnetic fields be harmful to humans?
In general, magnetic fields are not harmful to humans. However, extremely strong magnetic fields can affect the functioning of certain medical devices, such as pacemakers. Some studies have also shown a possible link between exposure to high levels of magnetic fields and an increased risk of certain cancers, but more research is needed in this area.
