Solving 1-D Motion Questions with Constant Velocity and Acceleration
In summary: If an object is accelerating, can we view things from a frame in which the object is at rest?If an object is accelerating, can we view things from a frame in which the object is at rest?Sure, why not?
Shing
144
Hi guys, I am self-studying physics, but I am confused for something following:
given 1-d motion of an object o, we can use these equations to describe the motion of it.
[itex]\overline{v}[/itex] is a constant, so is[itex]\overline{a}[/itex] .
1)[tex]x_t=x_0+\overline{v}t[/tex]
2)[tex]v_t=v_0+\overline{a}t[/tex]
3)[tex]d(x_t,x_o)=v_ot+\frac{1}{2}\overline{a}t^2[/tex]
if we take an rest reference frame of o
then how will those equations be changed?
here is how I think:
in case I,
there is no acceleration,
[tex]x_t=x_0+\overline{v}t=x_0[/tex] if [itex]v_0=\overline{v}[/itex]
question 1. what if[itex]v_0>\overline{v}[/itex]? and [itex]v_0<\overline{v}[/itex]
should it be written as: [itex]x_t=x_o+|\overline{v}-v_r|t[/itex]??
in case II,
there is acceleration,
I am really confused by this case,
since the textbook told me there is no relative motion when it comes to acceleration. And I have no idea WHY.
and after reading Newton's bucket, I am even more confused.
I have no idea how I should write the two equations 2)&3)
question 2.the acceleration seems to be changed... but how?
thanks for your reading, please help me =)
Those look like kinematic equations for constant acceleration. But what you mean by the lines over the symbols? ([itex]\overline{v}[/itex] & [itex]\overline{a}[/itex] ?)
If the acceleration is constant (and non-zero), how can the speed be constant also?
And if you take a frame co-moving with the particle, the equation of motion becomes: x = x0 (it doesn't move in its own frame).
Perhaps you can give us more background and rephrase your question.
my bad, sorry for my poor expression
1) --> o's rest reference frame, no acceleration.
2) and 3) --> when o has an constant acceleration.
in case I,
if we take the rest reference frame of o, and it doesn't have acceleration.
So we will observe a rest o
and how we express in equation is:
[tex]x_t=x_0+(v-v_r)t=x_o[/tex]
right?
and in case II, o has an constant acceleration
and how should we express the equation if when we take the reference with the same speed as the [itex]v_o[/itex]?
[tex] v_t=v_o-v_r+at=at[/tex]
and the speed of the reference doesn't affect how we observe the acceleration?
and thinking further ,
if an object's motion can be expressed by [tex]\frac{d^nx}{dt^n}[/tex]
would how we observe the object be affected by the taken reference frame expressed as [tex]\frac{d^{n-1}x}{dt^{n-1}}[/tex]?
I think you're asking: Take a standard reference frame and a second reference frame moving at speed V with respect to the first.
If an object has a constant speed V in the first frame, its position will be: x = x0 + Vt in that frame. From the second frame it will be x' = x - Vt = x0 and v' = v -V = 0.
It the particle is accelerating, x = x0 + v0t + .5at^2 and v = v0 + at. In the second frame, x' = x -Vt = x0 + v0t + .5at^2 -Vt = x0 + .5at^2 and v' = v - V = v0 + at - V = at.
Which I think is just what you are saying. Right?
Yes, thank you for your help =)
but I also would like to know that:
if the object is accelerating, can we take rest reference frame of it?
I think you are asking: If an object is accelerating, can we view things from a frame in which the object is at rest?
Sure, why not?
Sure, why not?
but if we view things from a frame in which the object is at rest, but actually it is accelerating.
we still can feel we are accelerating, pushed back.
And will we still think that "we" and "that object" are still at rest as how we observe?
And such frames are NON-INERTIAL reference frames, and the transition from them to an inertial reference frame is quite different than from another inertial reference frame.
The relativity of inertial reference frames means that the "laws of physics" are indistinguishable between two such (i.e, the same forces and accelerations will be calculated from either frame), whereas an accelerated reference frame will calculate another set of forces and accelerations than those calculated within an inertial frame.
Just to add to what arildno already explained...
If all you care to do is describe the motion (kinematics), then there's no problem at all in using an accelerated frame. But as soon as you want to talk about the physics (dynamics), then you must face the consequences of using a non-inertial frame of reference. In order to apply Newton's laws in such a frame, one must introduce inertial pseudo-forces to account for the fact that you are using such a frame.
Thanks to DocAl & Arildno!
but I still have some questions,
if there are two reference frames for an object, let's say, Y
If Y is accelerating in the first reference frame.
And compared to the first reference frame, the second reference frame is accelerating too (a lower [tex]
\frac{d^2x}{dt^2}
[/tex] .)
from the second reference frame, if we measure the acceleration of Y.
Will the acceleration be different to what we measure from the first?
I've draw a graph, and I found the acceleration will be different from different frames, is that correct?
Sure it will be different.
As you know, any two inertial frames will measure the object as having the same acceleration (at least non-relativistically).
But if one of the frames is accelerating, it will measure a different acceleration for the object. An obvious example is if the second frame is accelerating at the same rate as the object--in that case the object would appear to have no acceleration at all.
1. How do you calculate velocity in 1-D motion with constant acceleration?
In order to calculate velocity in 1-D motion with constant acceleration, you can use the equation v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time. Simply plug in the given values and solve for v.
2. What is the difference between constant velocity and constant acceleration?
Constant velocity means that an object is moving at a steady speed in a straight line, while constant acceleration means that an object's velocity is changing at a constant rate. In other words, constant acceleration means that the object is either speeding up or slowing down at a constant rate.
3. How do you find the displacement of an object in 1-D motion with constant velocity and acceleration?
The displacement of an object can be found using the equation s = ut + 1/2at^2, where s is the displacement, u is the initial velocity, a is the acceleration, and t is the time. Plug in the given values and solve for s.
4. What is the importance of understanding 1-D motion with constant velocity and acceleration?
Understanding 1-D motion with constant velocity and acceleration is important because it is the basis for understanding more complex motion, such as 2-D and 3-D motion. It also allows us to make predictions and calculations about the motion of objects, which is essential in fields such as physics and engineering.
5. How do you interpret a velocity-time graph for an object with constant acceleration?
In a velocity-time graph for an object with constant acceleration, the slope of the line represents the acceleration of the object. A positive slope indicates that the object is accelerating in the positive direction, while a negative slope indicates acceleration in the negative direction. The area under the line represents the displacement of the object.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
