Continuity equation for Schrodinger equation with minimal coupling
In summary, the Schrodinger equation with minimal coupling to the electromagnetic field in the Coulomb gauge has a continuity equation that shows probability conservation. However, there is a question about whether a more general continuity equation exists without the need for fixing the Coulomb gauge. It is suggested that starting from the Schrodinger equation with arbitrary A and φ, the equation for ρ can be found, but it may not have the same form as a temporal derivative plus the divergence of a current.
nembokid
The Schrodinger equation with the minimal coupling to the Electromagnetic field, in the Coulomb gauge [tex]\nabla \cdot A [/tex], has a continuity equation [tex]\partial_t \rho = \nabla \cdot j[/tex] where [tex] j \propto Re[p^* D p] [/tex] (D is the covariant gradient [tex] D= \nabla + iA [/tex].
My question is: is there any continuity equation which generalized the preceding one, without having to fix the Coulomb gauge? I think that, being the Schrodinger equation nonrelativistic, a choice of a noncovariant gauge is necessary, but maybe some ugly-to-see equation still exists.
thank you
It seems to me that this continuity equation is gauge-invariant. It means the probability conservation.
It's gauge invariant as long as you perform gauge transformations compatible with the Coulomb gauge constraint (which does not fix completely the gauge, as is well known). But what about an equation which does not require this constraint?
It is the same. Start from the Schroedinger equation with an arbitrary A and φ and find the equation for ρ.
But this equation for [tex] \rho [/tex] has no longer the form of a temporal derivative plus the gradient of a current (at least, I can't see how to put it in this form).
It should not be a gradient but divergence of current: divj.
Related to Continuity equation for Schrodinger equation with minimal coupling
1. What is the continuity equation for the Schrodinger equation with minimal coupling?
The continuity equation for the Schrodinger equation with minimal coupling is a mathematical expression that describes the conservation of probability density in a quantum system. It relates the change in probability density to the flux of probability density through a given surface.
2. How is the continuity equation derived for the Schrodinger equation with minimal coupling?
The continuity equation is derived from the Schrodinger equation with minimal coupling by taking the complex conjugate of the equation and multiplying it by the Schrodinger equation itself. This results in a new equation that can be rearranged to form the continuity equation.
3. What is the significance of the continuity equation in quantum mechanics?
The continuity equation is significant in quantum mechanics because it ensures that the total probability of finding a particle in a given region remains constant over time. This is a fundamental principle in quantum mechanics and is a consequence of the conservation of probability density.
4. How does the continuity equation relate to the conservation of charge in quantum systems?
The continuity equation is closely related to the conservation of charge in quantum systems. In quantum mechanics, particles are described by wave functions, and the continuity equation ensures that the probability of finding a particle in a given region is conserved just as the total charge is conserved in classical physics.
5. Can the continuity equation be applied to all quantum systems?
Yes, the continuity equation can be applied to all quantum systems as long as they are described by the Schrodinger equation with minimal coupling. This includes systems with various potentials and interactions, such as the free particle, the harmonic oscillator, and the hydrogen atom.
