When p(A)=0 iff p(B)=0 for any polynomial,why same minimal polynomial?
So PB(x) is NOT the minimal polynomial for B. Similarly, if PB(x), of degree m, is the minimal polynomial for B, then PB(A)= 0 so PB(B)= 0 which implies that PB(x) is the minimal polynomial for A. Therefore, A and B have the same minimal polynomial.In summary, for two matrices A and B, if p(A)=0 iff p(B)=0 for any polynomial, it can be concluded that A and B have the same minimal polynomial. This is because if they did not have the same minimal polynomial, there would exist a polynomial that is minimal for one matrix but not for the other, which would lead to a contradiction. Therefore, it can be concluded
td21
For two matrices A and B, when p(A)=0 iff p(B)=0 for any polynomial, what will happen? i read that A and B have the same minimal polynomial, why?
Let [tex]m_A, m_B[/tex] be the minimal polynimials of A and B. Then [tex]m_A (A) = 0\Rightarrow m_A (B) = 0 \Rightarrow m_B / m_A^{(1)}[/tex]
and
[tex]m_B (B) = 0\Rightarrow m_B (B) = 0 \Rightarrow m_A / m_B ^{(2)}[/tex]
[tex]\overset {(1), (2)}{\Rightarrow} m_A = k \cdot m_B[/tex]
with k a constant.
But [tex]m_A, m_B[/tex] are both monic polynomials so, [tex]k=1[/tex]
and finally [tex]m_A = m_B.[/tex]
Pretty much the same thing but in slightly differentwords:
Suppose PA(x), of degree n, is the minimal polynomial for A. Then PA(A)= 0 so PA(B)= 0. If This is not the minimal polynomial for B, there exist a polynomial PB, of degree m< n, such that PB(A)= 0. But then PB(A)= 0 contradicting the fact that the mininal polynomial of A has degree n> m.
1. What does it mean for p(A) to equal 0?
When p(A) equals 0, it means that when the polynomial p(x) is evaluated at the value A, the result is 0. In other words, A is a root or solution of the polynomial equation p(x) = 0.
2. How is p(B) related to p(A) when both equal 0?
If both p(A) and p(B) equal 0, it means that both A and B are roots of the polynomial equation p(x) = 0. This means that both A and B are solutions to the same polynomial equation.
3. Why is it important that p(A) equals 0 iff p(B) equals 0?
This property is important because it allows us to compare and relate different roots of a polynomial. If two different values, A and B, both make the polynomial equal to 0, then it means they are both solutions to the same equation and can be used interchangeably in certain situations.
4. What is the minimal polynomial?
The minimal polynomial is the smallest degree polynomial that has a given root or solution. In other words, it is the polynomial of lowest degree that has the same root as a given polynomial.
5. Why does the same minimal polynomial matter?
The same minimal polynomial matters because it provides a unique representation of a root or solution. In other words, if two different polynomials have the same root, then they must also have the same minimal polynomial. This allows us to make certain conclusions and simplifications when working with polynomial equations.
  • Linear and Abstract Algebra
