With what speed does the ion enter the magnetic field in a mass spectrometer?
In summary: Since the magnetic force is in the same direction as the centripetal force, the force is equal and opposite. The magnitude of the force is then F=qvB.
pinkyaliya
A mass spectrometer has a potential difference of 120 V applied to its accelerator plates. It is accelerating a positively charged ion that has a mass of 2.32 x 10^-26 kg. the ion then is directed into a uniform magnetic field of 0.17 T. The magnetic field is perpendicular to the direction that the particle is traveling. The radius of the circular path that the ion takes, while in the magnetic field, is 2.5 cm.
with what speed does the ion enter the magnetic field?
Potential difference = 120 V
Mass = 2.32 x 10^-26 kg
Magnetic field=0.17 T
Theta=90 degrees
Radius= 0.025m
Charge=3.08 x 10^-19 C
since it's traveling in a circular path a=v^2 / r
I also am confused about the free body diagram (do you even need me to figure this question out?)
edit: Is it that the magnetic force = the force of gravity or something like that?
So for your equations, you don't want to use the strength of the B-field, voltage or mass? Do you need any of them? ohhh charge also?
Some of the information was used to solve for the charge so some of the given is not necessary. I'm pretty sure you need the charge to figure this one out.
Yea that is a bit of a strange charge. How did you get it? Its close to what I would expect, but not quite...
I used the equation
m=qβ^2R^2 / 2ΔV
q=m2ΔV / β^2R^2
q=(2.32 x10^-26kg)(2)(120V) / (0.17T^2)(0.025m^2)
q=3.08...x10^-19 C
Is that right?
pinkyaliya said:
I used the equation
m=qβ^2R^2 / 2ΔV
q=m2ΔV / β^2R^2
q=3.08...x10^-19 C
Is that right?
Yes but...
Probably rounded a bit short since you have a very wide range of numbers some much smaller than the others. Since the amount of charge in 1 electron or proton is 1.6 x 10^-19C.
That would mean 2 extra protons in your ion should have about 3.2 x 10^-19C of charge.
Anyways...
Since you went through all that and got close, how about using cons. of Energy? What do you know about this situation. Any thoughts on kinetic and potential energy?
pgardn said:
Yes but...
Anyways...
Is it maybe that
Ek + Ee = Ek' + Ee'
I don't see how potential energy would play role since it's not changing height.
pinkyaliya said:
Is it maybe that
Ek + Ee = Ek' + Ee'
Potential Energy comes in many forms. Sometimes unit analysis can help you. I am going to tell you that before the ion is accelerated it has electric potential energy. Do you have an equation for this, or can you just look a the units on what you have and come out with Joules?
What does that Ee mean for example?
I was working around with it and the only problem I have is finding out the velocity in the end
What I mean is
v=?
ΔV=120 V
β=0.17 T
q=3.08...x10^-19 C
m=2.32 x10^-26 kg
v'=?
ΔE = qΔV
ΔE = (3.08...x10^-19 C)(120 V)
ΔE = 3.696...x10^-17 J
So I know that there was a potential energy of 3.696...x10^-17 J. If it started at rest, I know that this energy would be transformed into kinetic energy and that
Ek'=3.696...x10^-17 J
but I don't know what kinetic energy it ended with.
The ion is accelerated by U=120 V potential difference. Its final KE is equal to the initial potential energy qU, the accelerating voltage multiplied by the charge of the ion: mv2/2 =qU
The magnetic field exerts a force F, which is perpendicular to both the magnetic field B and the velocity of the ion. The magnitude of the force when v is perpendicular to B is F=qvB. The ion moves along a circle of radius R, and the centripetal force is equal to the magnetic force, mv2/R=qvB. Substitute 2qU for mv2, you get 2qU/R=qvB. q cancels. Isolate v.
ehild
So as Ehilde stated:
All potential energy starting from rest
to all kinetic as the ion enters perpendicular to the B field at which point it turns a circle.
Sorry but I was attempting to "draw" it out of you.
All electrical pot qV = all kinetic 1/2mv^2
1. How is the speed of an ion determined in a mass spectrometer?
The speed of an ion in a mass spectrometer is determined by the electric and magnetic fields it encounters. The electric field accelerates the ion, while the magnetic field bends its path. By measuring the degree of deflection, the speed of the ion can be calculated.
2. What factors affect the speed of an ion in a mass spectrometer?
The speed of an ion in a mass spectrometer can be affected by the strength of the electric and magnetic fields, as well as the mass and charge of the ion. The length of the flight path and any collisions with other particles can also impact the speed of the ion.
3. Is the speed of the ion constant throughout the mass spectrometer?
No, the speed of the ion is not constant throughout the mass spectrometer. As the ion encounters different electric and magnetic fields, its speed may change. However, the speed can be accurately measured at specific points in the instrument.
4. How does the speed of an ion relate to its mass-to-charge ratio in a mass spectrometer?
The speed of an ion is directly proportional to its mass-to-charge ratio in a mass spectrometer. This means that ions with higher mass-to-charge ratios will have lower speeds, while those with lower mass-to-charge ratios will have higher speeds.
5. Can the speed of an ion be manipulated in a mass spectrometer?
Yes, the speed of an ion can be manipulated in a mass spectrometer by adjusting the strength of the electric and magnetic fields. This allows for the separation and identification of different ions based on their mass-to-charge ratios.
