Heat conduction in nuclear reactor (introductory question)
In summary: The Attempt at a Solution:To solve this problem, you have to first calculate the rate of heat gererated per unit length of the rod. This is done by multiplying Q by the heat transfer coefficient, h. Next, you have to calculate the rate of heat carry away by the water. This is done by multiplying T by the surface area of the water, A. Finally, you have to set these two rates of heat transfer equal to get the final temperature, Delta T.
*Alice*
The elements of a boiling water nuclear reactor consist of long cylindrical rods of uranium dioxide (U02) of diameter 8mm surrounded by a thin layer of aluminium cladding. In the reactor core the elements are cooled by boiling water at 285°C with a heat transfer coefficient of 35kW/m^2K. If heat is generated uniformly within the rod at a rate of 760 MW/m^3, calculate the temperature of the cladding and the maximum temperature within the rod. The mean thermal conductivity of U=2 is 2.3 W/m K
first part: model it as a slab with equation Q= h(T*-285) ?
second part : T-T* = (Q/4k)r^2
first part: I just assumed that one can model the situation at the wall as a slab with very thin walls and using the equation above with the values of
h= 35kW/m^2K
and
Q=760 MW/m^3*2*pi*0.004 = 19.1 MW/m^3
does not give the required solution of 328°C. I don't really see what exactly is wrong with this calculation and would therefore appreciate if anyone could give me a hint.
second part: completely fine
thanks a lot
Hint:
First, you have to calculate the rate of heat gererated per unit length of the rod...
Then, calculate the rate of heat carry away by the water, (it depends on the temperature different between the rod and the water and the surface area)
At the equalibrium point, The heat generated is equal to the heat carry away... set them equal to get the [tex] \Delta T[/tex]
Thanks a lot - I now have the answer!
Q = h * (T-285)
The Q on the LHS is the heat created per unit length,
but h*(T-285) is heat carry away per unit area
You have to multiple something on the RHS to make this equation works... can you tell me what you have missed?
What is heat conduction?
Heat conduction is the transfer of thermal energy or heat from one object to another due to a difference in temperature. It occurs through direct contact between the objects and does not involve the movement of the objects themselves.
How does heat conduction work in a nuclear reactor?
In a nuclear reactor, heat conduction occurs when the fuel rods, which contain the nuclear fuel, transfer heat to the surrounding coolant. This heat is then used to generate steam, which powers turbines to produce electricity.
What factors affect heat conduction in a nuclear reactor?
The rate of heat conduction in a nuclear reactor can be influenced by several factors, such as the temperature difference between the fuel rods and coolant, the material properties of the fuel rods and coolant, and the shape and size of the fuel rods.
How is heat conduction controlled in a nuclear reactor?
To control the amount of heat being transferred through conduction in a nuclear reactor, control rods are used to absorb or slow down the neutrons that cause nuclear reactions. This allows for the regulation of the reactor's power output and prevents overheating.
What are the potential hazards of heat conduction in a nuclear reactor?
If not properly controlled, heat conduction in a nuclear reactor can lead to overheating, which can cause damage to the fuel rods and other components. This can result in the release of radioactive materials and potentially lead to a nuclear meltdown. However, strict safety measures and protocols are in place to prevent such incidents from occurring.
  • Nuclear Engineering
9K
