Old fashioned 2 pole ac/dc motor/generator used for classroom demonstrations
In summary, the device can generate AC and DC electricity, but the AC output is limited by the speed of the crank.
Spencer M
Hello this is my first posting. I have a device that I acquired from my old high school. It is a demonstration unit of AC and DC electricity generation. It has a small crank on one end. It is not equipped with permanent magnets in either the field or the armature. If I test the voltage off the commutator whilst spinning it without energizing the field-- no electricity is produced.
By that same token if I energize the field with a 14 volt battery from a cordless drill, and then manually spin the crank, voltage is generated. (this is limited however, by the speed at which i can turn the crank, not very fast)
I have successfully managed to wire it in series to a 14 volt battery from a cordless drill. This was done in the "DC configuration" It spins quite fast but the field windings get too warm to touch. I try to avoid running it for any extended period of time.
Figure 1 shows the internal wiring of the device under DC "motoring" conditions. Omitted is the 14 volt power supply, which would be connected to the field windings.
http://img25.imageshack.us/img25/2695/devicewiredfordc.th.jpg http://img25.imageshack.us/img25/4782/diviceasac.th.jpg
Figure 2 shows the motor as configured, but without wiring, for presumably AC generation and motoring. I have yet figured out how to safely connect it to AC power. I have managed to energize the field with 14 Volt DC as before, and turn the crank--this generated some AC voltage. At the slow rotational speed the voltage dipped and rose. This proves it was AC. At this point I am beginning to wonder whether or not the device truly goes "both ways". I have produced enough proof for myself that it does indeed "motor" under DC, and that it generates DC, and I have proven that it generates AC. I have yet to prove if it can "motor" under AC.
My ultimate question is this:: Where can I obtain low voltage and low current AC to make it motor under AC?
(the field will still be energized by 14 volt DC, separately)how does AC frequency affect the speed of the motor if i do manage to make it run? 60 hertz with 2 poles? is that 3600 RPM? I am not sure the motor will handle that amount of rotational stress
Hello and welcome to PF. Some electronics distributors (Mouser, Jameco, etc.) carry low-cost, low-power, AC-to-AC wall adapters.
I agree that you will need a low-speed AC source to experiment with driving that motor. Do you have access to a signal generator? You will still likely need some power amplification to drive the motor with the output of the signal generator.
You might consider looking through the many electronics kits on the Internet, to see if there is an inexpensive kit for an audio signal generator, and one for an inexpensive audio power amplifier. Or use a combo kits something like these:
http://www.kitsusa.net/phpstore/index.php?l=search_list&s[title]=Y&s[short_desc]=Y&s[full_desc]=Y&s[sku]=Y&s[match]=all&s[cid]=0&s[search]=signal+generator
It's great that you are curious and are working through the experiments to better understand how things work.
Are any of the three copper bands around the rotor axle a commutator rather than a slip ring? If so, you can get DC out with DC on the field coil. Don't overheat the field coil with too much current. It should never be too hot to touch. Measure the resistance of the field coil, and keep the applied voltage below that number, so A<= 1 amp.
1. How does an old fashioned 2 pole ac/dc motor/generator work?
The motor/generator works by using an electromagnet to create a magnetic field. When electricity is passed through the electromagnet, it creates a force that causes the motor to spin. This spinning motion can then be used to generate electricity through the process of electromagnetic induction.
2. What is the purpose of using a 2 pole design for the motor/generator?
A 2 pole design means that there are two sets of magnetic poles in the motor/generator. This allows for a more efficient transfer of energy between the electromagnet and the permanent magnet, resulting in a stronger magnetic field and more powerful motor/generator.
3. Is this type of motor/generator still used in modern technology?
While the design of the 2 pole motor/generator may be outdated, the principles behind it are still used in modern technology. For example, generators in power plants and electric motors in appliances and vehicles all use the process of electromagnetic induction to function.
4. What are some common classroom demonstrations that can be done with this motor/generator?
There are many fun and educational demonstrations that can be done with this type of motor/generator. Some popular ones include lighting up a light bulb using the generated electricity, powering a small fan, and demonstrating the conversion of mechanical energy into electrical energy.
5. How can I safely use this motor/generator for classroom demonstrations?
It is important to always follow proper safety precautions when using any electrical equipment. Make sure to read and understand the instructions and warnings before using the motor/generator. It is also recommended to have adult supervision and to use appropriate protective gear, such as gloves and safety goggles, when conducting demonstrations.
  • Electrical Engineering
14K
