Quantum physics underlining the 'magic numbers' in chemical bonding & more.
In summary, the number of electrons in an atomic shell is determined by quantum numbers, specifically n, l, ml, and ms. Each shell can hold a maximum of 2 electrons, as per Pauli's exclusion principle. This explains why the outermost atomic shell can hold 8 electrons, while the innermost shell can hold 2. These numbers are not based on any physical theory, but are instead an empirical reality.
bentzy
37
a. What do we know about any quantum-physical law, dictating 8 electrons in the outer atomic shell + the other shells' populations, including the 2 electrons in the innermost. Any physical theory behind these numbers, or just an empirical reality ?
b. How reacting atoms 'choose' between, e.g., ionic bond and covalent bond ?
c. What Hydrogen was used in the early spectra measurements (e.g., Balmer) - atomic or molecular ? Since the spectra are atomic in nature, how did they split the H molecule into two atoms in those days ?
Let me take a try at the question (a)
The number of electrons in the shell come from "quantum numbers". While solving the Schrodinger equation for Hydrogen atom, we get 3 quantum numbers : n (principal), l (orbital) and ml (magnetic). The values these take are given as
n : 1,2,3,,,, (This number refers to "shells")
l : 0 to n-1
ml: -l to l
All of these are integers.
Apart from this we have a quantum number for spin(ms), which takes only 2 values.
The combination of all the 4 quantum numbers define a quantum state (n,l,ml,ms). As per Pauli's exclusion principle, each of these states can be occupied by only one electron.
So if you start from n=1, and apply the above rules, you will see that for n=1, l = 0, and ml =0. So we have only one combination. But we have 2 values for ms. So that means, we have 2 quantum states for n=1. Hence the lowermost shell, can take 2 electrons.
From this, you can continue for n=2 etc...
1. What are the 'magic numbers' in chemical bonding?
The 'magic numbers' in chemical bonding refer to specific numbers of electrons that result in particularly stable atoms or molecules. These numbers, such as 2, 8, 18, and 32, correspond to the number of electrons that can fully occupy certain energy levels or orbitals within an atom.
2. How does quantum physics explain the 'magic numbers' in chemical bonding?
Quantum physics explains the 'magic numbers' in chemical bonding through the concept of electron energy levels and the Pauli exclusion principle. According to quantum theory, electrons can only occupy certain discrete energy levels, and each energy level can only hold a certain number of electrons. The 'magic numbers' correspond to the maximum number of electrons that can occupy each level, resulting in stable configurations.
3. What is the significance of the 'magic numbers' in chemical bonding?
The 'magic numbers' in chemical bonding are significant because they determine the stability and reactivity of atoms and molecules. Atoms with a full outer energy level, such as the noble gases with 8 valence electrons, are highly stable and unreactive. This stability is due to the 'magic number' of 8 electrons in the outer energy level.
4. How do the 'magic numbers' affect chemical reactions?
The 'magic numbers' affect chemical reactions by determining the types of bonds and molecules that can form. For example, atoms with 2 or 8 valence electrons tend to form ionic bonds, while atoms with 4 or 6 valence electrons tend to form covalent bonds. This is because these numbers correspond to full or half-filled energy levels, resulting in more stable configurations.
5. Can the 'magic numbers' be applied to all elements?
The 'magic numbers' can be applied to all elements, but they are most commonly observed in atoms with low atomic numbers. As the atomic number increases, the energy levels become more complex and the 'magic numbers' become less apparent. Additionally, the 'magic numbers' may vary slightly for different elements due to differences in electron configurations and energy levels.
  • Atomic and Condensed Matter
  • Chemistry
