Is This Function a Solution to the Differential Equation?
In summary, you differentiated (y) with respect to (x), and substituted (y' and y) in equation (1), but that led you to nowhere. You can simplify the last term of y by multiplying it by 1/√(x2+1).
Ammar Kurd
Hello everyone, this is my first post in "Physics Forums"...
I need help with this problem:
Verify that y = (x^2/2) + ((x/2)*√(x^2 + 1)) + ln(√(x+√(x^2 +1))) is a solution of the
equation 2y = x*y' + ln(y')...(1)
I differentiated (y) with respect to (x), and substituted (y' and y) in equation (1), but that
led me to nowhere.
*The problem might be easy, but I study by myself and have no one to consult, I appreciate
any tips or hints, thanks in advance.
Welcome to PF!
Hello Ammar Kurd! Welcome to PF! :smile:
(try using the X2 button just above the Reply box :wink:)
Ammar Kurd said:
Verify that y = (x2/2) + ((x/2)*√(x2 + 1)) + ln(√(x+√(x2 +1))) is a solution of the
Show us what you got for y' :smile:
Thank you for the replay, I got
y' = x + 0.5√(x2+1) + (x2 / (2√(x2+1))) + (x+√(x2+1) / (x√(x2+1)+x2+1))
I also tried to simplify the (y) in this way:
y = 0.5x2 + 0.5x√(x2+1) + ln(√(x+√(x2+1)))
= .5x(x+√(x2+1)) + 0.5ln(x+√(x2+1))
then putting G(x) = x+√(x2+1)
y becomes:
y = 0.5x*G(x) + 0.5ln(G(x)), and
y' = 0.5*G(x) +0.5xG'(x) + 0.5*(G'(x)/G(x))
But when I substitute in the differential equation it only get complicated...
*Thank you for the x2 tip :smile:.
Hello Ammar Kurd! :smile:
Ammar Kurd said:
Thank you for the reply, I got
y' = x + 0.5√(x2+1) + (x2 / (2√(x2+1))) + (x+√(x2+1) / (x√(x2+1)+x2+1)) …
Yes, that's correct, except I think there should be a factor 2 in the last term. :smile:
I don't know how you got that last term, but it simplifies, to 1/√(x2+1) :wink:
That was my problem I didn't notice that the last term can be further simplified :redface:.
Thank you, Problem solved :smile:
1. What is a differential equation?
A differential equation is a mathematical equation that describes the relationship between a function and its derivatives. It is used to model various phenomena in physics, chemistry, engineering, and other fields.
2. How do I solve a differential equation?
There are various methods for solving a differential equation, depending on its type and complexity. Some common techniques include separation of variables, integrating factors, and using power series. It is important to first determine the type of differential equation and then select the appropriate method for solving it.
3. What is the purpose of using differential equations in science?
Differential equations are used in science to model and understand the behavior of systems that change over time. They help us to make predictions and analyze complex phenomena in fields such as physics, biology, and economics.
4. How can I check if my solution to a differential equation is correct?
To check the correctness of a solution to a differential equation, you can substitute the solution into the original equation and see if it satisfies the equation. Additionally, you can also plot the solution and see if it matches the behavior of the system being modeled.
5. Are there any real-life applications of differential equations?
Yes, there are many real-life applications of differential equations. They are used to model and understand various phenomena such as population growth, heat transfer, and the spread of diseases. They are also used in engineering to design and optimize systems, such as in control theory and circuit analysis.
