Photosynthesis occurs in all plant life and makes plant green
In summary, Photosynthesis occurs in all plant life and is responsible for making them green. The reason some plants are not green is because no photosynthesis goes on in them. Ancillary pigments reflect different colors - xanthins, flavonoids, anthocyanins, etc. Those show up in the Fall when leaves turn colors.
pivoxa15
2,255
Why are not all plant life green. I.e. flowers can be yellow, red and some leaves too like the leaves of Poinsettia. Is the reason because no photosynthesis goes on in them? Or is something else more dominant which gives them their distinct colours. If so what usually is that something?
Does the red or yellow autum leaves suggest their photosynthetic abilities have died? So does that colour suggest death soon for these leaves (i.e. sign of old age)?
Biology news on Phys.org
You've got this backwards. It is the green pigment (chlorophyll a) which primarily enables photosynthesis, and not the other way round.
Thats interesting. I read in a (physics) book that the fact that plants are green suggest photosynthesis recquires all colours except green. From what you suggest, this seems wrong?
There may be some truth to this, though I'm fairly certain that there are some other pigments which also enable photosynthesis, and are not green (I think chlorophyll b is one). These, I think, are a minority.
In any case, I misinterpreted the statement in the OP, thinking you were suggesting that photosynthesis is directly responsible for the formation of the green pigments.
Not all plants have chlorophyll a - Cuscuta spp (dodder, a parasitic plant) are an example.
FWIW.
FWIW.
So they wouldn't look green.
In fact they are pale yellow.
I remember reading that plants reflect light at the colors (yellow-green) where the sun's intensity is greatest. Furthermore, chlorophyll is related to the light-sensitive compounds used in rods and cones. The conclusion is that appropriately useful light-sensitive compounds are rare and nature used the one it found even though its efficiency is sub-optimal.
Edit: am not a biologist, would appreciate knowledgeable comments!
Chlorophyll a has an absoprtion spectrum with maximum at about 430nm with a secondary max at 662nm. Chlorophyll b: 453 & 642.
That means if they appear green, green is the color they reflect the most.
Chl a is light green, Chl b is kinda turquoise.
I don't think the absorption spectrum works out the way you think. Plants want to maximize the light energy they absorb - short wavelengths have more energy. Violet has the most energy in the visible spectrum. Chl a absorbs violet/indigo pretty well.
Not all photosynthetic will produce a green pigment. Bacteria have a few different otosynthetic pigment that will produce a different colour. These pigment also absorb at a different wavelength
Wikipedia has a list but i don`t know how extensive it is.
http://en.wikipedia.org/wiki/Bacteriochlorophyll
What about this question in the OP
"Does the red or yellow autum leaves suggest their photosynthetic abilities have died? So does that colour suggest death soon for these leaves (i.e. sign of old age)?"
It means the abscission layer has formed - ie., the main plant has cut off the leaf from the vascular system of the tree/shrub/bush. Your answer is yes, the leaf is dying.
To go along with the bacteriochlorophyll wikipedia list, this is the taxa for phototrophic bacteria.
http://www.the-icsp.org/taxa/phototrophlist.htm"
What is photosynthesis?
Photosynthesis is the process by which plants, algae, and some bacteria convert light energy from the sun into chemical energy. This process produces oxygen and carbohydrates, which are essential for the survival of plant life.
Why is photosynthesis important?
Photosynthesis is crucial for the existence of life on Earth. It is responsible for producing oxygen, which is necessary for the respiration of animals and humans. It also plays a crucial role in the carbon cycle, regulating the amount of carbon dioxide in the atmosphere and maintaining a stable climate.
How does photosynthesis occur?
Photosynthesis occurs in two stages: the light-dependent reactions and the light-independent reactions. In the light-dependent reactions, light energy is absorbed by pigments such as chlorophyll, and converted into chemical energy in the form of ATP and NADPH. In the light-independent reactions, these energy molecules are used to convert carbon dioxide into glucose.
What is the role of chlorophyll in photosynthesis?
Chlorophyll is a pigment found in the chloroplasts of plant cells. It absorbs light energy during photosynthesis and is responsible for giving plants their green color. Without chlorophyll, plants would not be able to carry out photosynthesis and would not be able to produce food for themselves.
Does photosynthesis occur in all plant life?
Yes, photosynthesis occurs in all plant life, including trees, flowers, grass, and algae. It is the primary source of energy for all living organisms on Earth, and without it, life as we know it would not be possible.
  • Biology and Medical
