Tension of wire between posts with weight added to the wire
In summary: That is much too small. The tension in the wire would be approximately 800,000 N.Second, your calculations do not take into account the pretension of the cable. When you reduce the tension on the cable, the cable will not only stretch, but also become stronger. This causes the angle of the wire to increase, as the force is now distributed over a larger area. Third, the cable modulus of elasticity is not a constant, but will increase as the cable stretches. This will cause the tension in the wire to be much higher than what you have calculated.
bobbles22
I have a problem with a design at work. We have a wire tensioned to 400N between two vetical steel posts 7m apart.
What would the tension be in the wire if someone of about 100kgs (1000N for the sake of the calcualtion) sat on the middle of the wire. Assuming there is almost no stretch to the wire as it is spun steel rope of reasonable thickness (4mm).
I'm confused as the tension is horizonal, but the force is vertical with no horizontal component, but you know that it is pulling the posts together more as a result of the added force.
Any help greatly appreciated.
Bob
bobbles22: Assuming your cable has an equivalent solid circular cross-sectional diameter of 4.0 mm, it currently appears the tension on your loaded cable would be roughly 7210 N. If you could give us the exact solid cross-sectional area of your cable, and the tensile yield strength of your cable material, it might be helpful.
Thank you for that NVN. Could you explain how you reached that answer. I got approx 24,000N. I worked on the basis that I knew the wire would stretch about 7mm, worked out the angle of the bend from horizontal, then took the 1000N acting down and worked out the horizontal compoment of it. Have you got an easier way?
nvn: how do you get this figure, could you explain your working? I am not doubting you, i am just getting confused with this problem - all of my mechanics problems have always used solid steel structures, but this problem is confusing me a bit?
Cheers
Using the assumption stated in post 2, I currently got a cable elongation of 19.0 mm (9.5 mm per side), neglecting your cable pretension. This gave me a cable sag angle of theta = 4.21 deg. Therefore, T = 0.5*P/sin(theta) = 6811 N, where P = 1000 N. I then added to this the cable pretension stated in post 1 (400 N), as an approximation, thus giving cable tension T = 7210 N.
If you could provide the cable properties mentioned in post 2, and the cable modulus of elasticity, it might be helpful.
Bob
Solve as a triangle with point load at the bottom node, assume hinge at ends. Angle theta will increase with reduction in rope diameter and reduction in rope tension. Pretension increases the capacity of vertical load. You can compute a table for theta ranging from 5 deg to 20 deg.
No, an increase in pretension decreases the cable load capacity.
Thanks for everyones help with this. So you are aware, the figures I have put in are 7000mm initial length, 8mm extension (rounded up from 7.96mm) using Diameter 4mm (therefore radius 2 of course), Young's Modulus is 70,000N/mm2.
Using this 8mm extension, I found the angle to be 2.74 degrees and therefore the force to be 10467N along the wire (acting as the hypotenuse) then added the 400N original force, giving 10867N total in the wire.
Obviously, this uses the stated exact figure of Young's Modulus of 70,000 and this is likely slightly higher than the figures used by others. I have also found out my error on the original calculation (basically, I forgot to change the diameter into a radius, as I had a brain-fart!).
Thanks for everyones help. It is greatly appreciated.
Bob
bobbles22: Thanks for the modulus of elasticity. That new value will change my previous results, greatly reducing T. But we will get into that later.
First, your results appear to be far off, unless I am misinterpreting what you wrote. What is the cross-sectional area of your cable?
1. How does the weight added to a wire affect its tension?
The weight added to a wire will increase its tension, as the wire will experience a downward force due to gravity. This increased tension can be calculated using the formula T = mg, where T is the tension, m is the mass of the added weight, and g is the acceleration due to gravity.
2. What factors can affect the tension of a wire between posts?
The tension of a wire between posts can be affected by several factors, including the weight of the wire itself, the distance between the posts, the material and thickness of the wire, and any additional weight added to the wire.
3. How can the tension of a wire between posts be measured?
The tension of a wire between posts can be measured using a spring scale or a tension meter. These tools can provide an accurate reading of the force being exerted on the wire, which can then be used to calculate the tension using the formula T = Fd, where T is the tension, F is the force measured by the tool, and d is the distance between the posts.
4. Can the tension of a wire between posts be too high?
Yes, the tension of a wire between posts can be too high. If the tension exceeds the strength of the wire, it can lead to the wire breaking or snapping. This can be dangerous, especially if the wire is used for supporting heavy objects or structures.
5. How can the tension of a wire between posts be adjusted?
The tension of a wire between posts can be adjusted by changing the distance between the posts, using a different wire with a different material or thickness, or adding or removing weight from the wire. It is important to carefully consider the purpose of the wire and the weight it will need to support when adjusting the tension.
  • General Engineering
