Acceleration vs Gravity and effect on time/clocks
In summary, there is a difference between acceleration and gravity when it comes to time dilation. While a higher acceleration does not necessarily result in a greater time dilation, a greater gravitational potential does. This can be demonstrated through experiments with clocks in different gravitational fields or in an accelerating spaceship. Additionally, clock velocity also plays a role in time dilation, as shown in the experiments referenced by the conversation.
DarioC
255
Just kicking some things around and this came up:
Albert says that it is not possible to discern acceleration from gravity under his imposed conditions.
Question, does that apply to clock type "devices," and time?
As practical example; let us put a radioactive sample in an ultra-centrifuge and spin it up, monitoring the average radio-active decay rate. Will it be slower?
Yes.
Yes. If you click on the sticky thread on experimental basis of SR and search for muon you will find some experiments (Bailey?) about exactly that.
While the decay will be slower in the centrifuge, you have to be really careful how you interpret this. The slowing is exactly that which you would expect from time dilation for a clock traveling at the speed of the end of the centrifuge. The acceleration itself does not add any extra time dilation.
This can be shown by using centrifuges with different arm lengths if the speed at the end of the arm is kept constant, the time dilation remains the same, even though the acceleration experienced will be different.
So how do we equate gravity and acceleration when it comes to time dilation? First you have to realize that gravitational time dilation is related to gravitational potential and not gravitational acceleration. If you had a uniform gravity field (one that did not differ in strength with height) and put two clocks in it at different heights, the higher one would run faster compared to the lower even though they feel the same pull of gravity.
With acceleration, this same effect can be shown by having two clocks sitting in the nose and tail of an accelerating spaceship. The clock in the nose willing run faster than the one in the tail, even though they are both accelerating at the same rate.
OK, thanks for the references. The one on "clock" velocity vs acceleration was most interesting.
DC
1. What is the difference between acceleration and gravity?
Acceleration is the rate of change of velocity, while gravity is the force of attraction between two objects. In simpler terms, acceleration is how quickly an object's speed changes, while gravity is what pulls objects towards each other.
2. How does acceleration affect time and clocks?
According to Einstein's theory of relativity, time is relative to the observer's frame of reference. This means that the rate at which time passes is affected by the acceleration of the observer. The greater the acceleration, the slower time will pass for the observer. This effect is known as time dilation.
3. Does the strength of gravity affect time and clocks?
Yes, the strength of gravity also affects time and clocks according to Einstein's theory of relativity. The closer an object is to a massive body, the stronger the gravitational pull, and the slower time will pass in that region. This effect is known as gravitational time dilation.
4. How does time dilation due to acceleration and gravity impact everyday life?
Time dilation due to acceleration and gravity is only noticeable at extremely high speeds or near massive objects like black holes. Therefore, it does not have a significant impact on our everyday lives. However, it is essential to consider when making precise measurements, such as in GPS technology.
5. Are there any experiments that have proven the effects of acceleration and gravity on time?
Yes, there have been several experiments that have demonstrated the effects of acceleration and gravity on time, such as the Hafele-Keating experiment and the Pound-Rebka experiment. These experiments involved comparing the time measured by clocks in different frames of reference with varying levels of acceleration and gravity.
