How Does the Filtration Barrier at the Kidney Work?
  • Thread starter sameeralord
  • Tags
    Barrier
In summary, the basement membrane is like a coffee filter made up of connective tissue fibers, not a barrier. It allows for the transport of molecules from the capillary to the podocyte, which has slit diaphragms that are about 10 nm wide. These cells do not divide and have high cholesterol levels in their membrane, making them rigid. They also experience high fluid stress due to the large amount of fluid they filter each day.
sameeralord
662
Red-capillary Purple- Basement membrane Blue-podocyte
Hello everyone, Now my question is after something if filtered from the capillary how does it go to the podocyte. The basement membrane looks too thick with no pores to me, it seems to be blocking the passage of molecules. Thanks :smile:
Biology news on Phys.org
What do you mean, "go to the podocyte"?
The podocyte processes are separated in space, these are called "slit diaphragms" The size of these are about (IIRC) 10 nm wide, allowing transport of the blood plasma into the glomerular tuft. Again, AFAIK the slit diaphragms are too small to allow passage of viruses/bacteria/cells.
Podocytes are interesting cells- they don't divide (you are born with a full complement), and have a very high amount of cholesterol in the cell membrane, increasing the rigidity. The slit diaphragms are subject to enormous fluid stress- which you can very for yourself, given the size of the pore and the amount of fluid that passes (each kidney deals with about 150 L of fluid per day)
Basement membrane - think coffee filter - not barrier. It is a mesh of connective tissue fibres (collagen/elastin). PS nice diagram - where is it from?
I am happy to provide an explanation for the filtration barrier at the kidney. The filtration barrier is made up of three layers: the red-capillary, the purple-basement membrane, and the blue-podocyte. The red-capillary is responsible for filtering small molecules and waste products from the blood, while the purple-basement membrane acts as a physical barrier to prevent larger molecules and cells from passing through. The blue-podocyte, with its unique structure of interlocking foot processes, serves as a final barrier to ensure that only the necessary molecules and fluids are able to pass through and enter the urine.
To address your question, after filtration occurs at the red-capillary, the small molecules and waste products pass through the pores of the purple-basement membrane and reach the blue-podocyte. While the basement membrane may appear thick and impermeable, it actually contains small pores that allow for selective passage of molecules based on their size and charge.
The podocytes also play a crucial role in this process. As the molecules pass through the basement membrane, the podocytes use their foot processes to actively regulate and control the passage of molecules. This ensures that only the necessary substances are able to pass through and enter the urine, while larger molecules and cells are retained in the blood.
In summary, the filtration barrier at the kidney is a complex and highly regulated process that involves the coordinated function of the red-capillary, purple-basement membrane, and blue-podocyte. Each layer serves a specific purpose in filtering and regulating the passage of molecules, ultimately maintaining the body's fluid and electrolyte balance. I hope this explanation helps to clarify the role of each component in the filtration barrier. Thank you.
Related to How Does the Filtration Barrier at the Kidney Work?
1. What is the filtration barrier at the kidney?
The filtration barrier at the kidney is a specialized structure that is responsible for filtering blood to remove waste products and excess fluid from the body. It is made up of three layers: the glomerular endothelium, the glomerular basement membrane, and the podocytes.
2. How does the filtration barrier work?
The filtration barrier works by allowing small molecules, such as water, electrolytes, and waste products, to pass through while preventing larger molecules, such as proteins and blood cells, from crossing into the urine. This process is known as selective permeability and is essential for maintaining proper balance in the body.
3. What happens if the filtration barrier is damaged?
If the filtration barrier is damaged, it can lead to the leakage of proteins and blood cells into the urine, which can be a sign of kidney disease. This can also cause a decrease in the filtration rate, leading to a buildup of waste products and excess fluid in the body.
4. What are some common causes of damage to the filtration barrier?
Damage to the filtration barrier can be caused by a variety of factors, including high blood pressure, diabetes, autoimmune disorders, and certain medications. In some cases, genetic factors can also play a role in the development of kidney disease and damage to the filtration barrier.
5. Can the filtration barrier be repaired?
The filtration barrier can sometimes repair itself if the damage is not severe. However, in cases of chronic kidney disease, the damage may be irreversible. Treatment options, such as medication and lifestyle changes, can help slow down the progression of the disease and protect the filtration barrier from further damage.
  • Biology and Medical
9K
  • Other Physics Topics
  • STEM Career Guidance
15K
  • DIY Projects
