Exploring the Relationship between Energy Eigenstates and Wavefunctions
In summary, the energy eigenstates are associated with the "wavefunction" and "position" because they are the energy levels of a system. The wavefunction is a function that describes the probability of finding a particle at a given position, and the position/momentum basis is the most convenient one for solving the wave function for electrons in atoms.
jeebs
325
Why do we associate the energy eigenstates with the "wavefunction" and "position"?
This is something that has bothered me for a long time but that I never got around to asking. I suspect I'll feel like an idiot for not knowing this but anyway...
One of the first things I was introduced to in quantum mechanics courses is the time-independent "schrodinger" equation, or in other words, the "energy eigenvalue equation", [tex] H\Psi = E\Psi [/tex], where [tex]\Psi[/tex] are the eigenfunctions of H.
We were also introduced to the idea that you could take this object [tex] \Psi [/tex], square it, and that would give you the probability of finding your particle at a given position. [tex]\Psi[/tex] gets called the "wavefunction" but I notice that the use of that word seems to dry up when you start getting into doing your quantum mechanical calculations using Dirac notation.
I have never understood where this dual use of the energy eigenstate [tex]\Psi[/tex] came from, and it seems like it should be an important thing to know. I mean, we have our set of observables like momentum, energy, etc. and their corresponding operators, eigenstates and eigenvalues - why is it the energy eigenstates in particular that we take as our "wavefunction"?
We could find different eigenstates for any operator that does not commute with H, right?
Why isn't our "wavefunction" the eigenstate of some other operator?
This can't have been an arbitrary choice?
A quantum mechanical system can have a state that is not an eigenstate of H. But if you have some Hermitian operator you can express any state as a linear combination of eigenstates of that operator. So for instance if we learn everything there is to learn about eigenstates of H, then we can form any state whatsoever as a linear combination of eigenstates of H, and so we know all there is to know. You are right in pointing out that H is not special in this way, but we want to know what the eigenstates of H are because these are the energy levels of the system, which are important.
I think at this level you should make a distinction between the state and the wavefunction. The state is some vector in Hilbert space, written like [tex]| \psi \rangle[/tex]. The wave function (in position space) is a function [tex]\psi(x)[/tex] which is shorthand for what in Dirac notation is written [tex]\langle x | \psi \rangle[/tex] where [tex]| x \rangle[/tex] is a position eigenstate. This then is a complex number whose squared magnitude gives the probability density to find the particle at x. Again the position basis is not unique, you can define a momentum space wave function [tex]\psi(p) = \langle p | \psi \rangle[/tex] whose squared magnitude gives the probability density for a momentum measurement to give the value p.
Consider the historical context in which QM developed. The key problem was explaining the emission/absorption spectrum of hydrogen and other atoms. The answer involves predicting the energy eigenvalues of hydrogen, along with the selection rules that decide which transitions between them can actually happen.
In the early days of QM, there was Schrödinger, who worked with the wave function. "wave mechanics/Wellenmechanik") Then there was Heisenberg, who worked with matrices. Dirac tied it all together with his operator formalism. Schrödinger was originally concerned with electrons in atoms. His original interpretation of the wave function's square was as the electron density around the atom. So that's basically where it came from.
So the question: "What's so special about the energy/position basis?" is a good one. There isn't anything special about them. You can of course form any number of hermitian operators with their own corresponding basis. It's basically just a historic artifact of the original problem they were tackling. The whole 'wave-particle duality' thing is also an artifact of that.
That said, the position/momentum basis is still usually the most convenient one if you're trying to solve the wave function for electrons in atoms.
But from the modern viewpoint, there's indeed nothing special about it.
alxm said:
That said, the position/momentum basis is still usually the most convenient one if you're trying to solve the wave function for electrons in atoms. .
Not quite. All heavily used computational packages use Gaussian wave packets (or superpositions of these) as basis functions. Whether one describes the latter in the position representation or in the momentum representation (or any other) is completely irrelevant: They are Gaussian in both representations, but only their inner product matters, and these are tabulated already.
However, in as far as chemists are interested in the charge distirbution, they need to convert whatever they get at the end into a charge density, and this is a position-dependent field.
The latter is not far from Schroedinger's view - see the entry ''How do atoms and molecules look like?'' in Chapter A6 of my theoretical physics FAQ at http://arnold-neumaier.at/physfaq/physics-faq.html#atoms
I'm afraid that's confusing things more than clarifying. Basis functions/basis sets aren't the same thing as the quantum-mechanical basis. The quantum mechanical basis involved is usually spin-orbitals, i.e. the eigenfunctions of the Fock operator. (And in a multireference method, that's expanded to multiple determinants over more states) The populations being calculated are those of the spin-orbitals and the determinants, not the populations of harmonic-oscillator states.
The mathematical functions used to approximate the spatial part of the spin-orbitals are arbitrary and have no real physical significance. Gaussians are used out of purely computational considerations. The fact that they're a eigenbasis for the harmonic-oscillator Hamiltonian is useful if you want to illustrate that they form a complete set, and therefore are suitable to use as basis functions, but that's about as far as that extends here. There are methods in general use (and many more that have been experimented with) that make use of other basis functions, such as ordinary exponential functions and even splines. Not to mention that in DFT methods, the basis functions don't represent the wave function of any real thing at all.
Since there are methods that do use actual gaussian wave packets (e.g. http://jcp.aip.org/resource/1/jcpsa6/v134/i7/p074107_s1" ) to model electron transfer in complexes, I think you're liable to cause a lot of confusion here.
I appreciate your FAQ, Arnold, but I've been doing quantum chemistry for some years now, so I'd hope I already know the answer to that question! :smile:
Actually this reminds me of another curiosity I've had relating to wavefunctions. When I think of a wave, I'm picturing a traveling disturbance. However, unless I'm gravely mistaken, the electron orbitals of atoms aren't really waves at all are they? More like a sort of cloud of probability? For example, the hydrogen ground state probability density is just a peak and then an exponential decline as a function of distance from the nucleus. That's not a wave since it doesn't evolve in time. So, why is it called the "wavefunction" if it first sprouted from calculating atomic energy levels and their corresponding positions?
Don't get me wrong, I'm all too familiar with treating particles as waves when it's useful to, but when I think of an electron bound to a nucleus, a wave is not the word I would use... unless the electron orbitals do go through oscillating changes in shape for things more complicated than the H ground state?
But in a confined space, you can have a standing wave. The wave function of a particle in a 1-dimensional box (the perennial first thing you learn in QM) has stationary states that are simply standing sine waves.
The hydrogen atom has states which are spherical harmonics (apart from the radial exponential function), which are in fact just a 3-dimensional standing wave when confined to a spherically-symmetric 'box'.
Although I believe it's called the 'wave function' more out of analogy to the classical dispersion relation than to the classical wave equation.
While the hydrogen wave-function corresponds directly to the electronic density, the wave function of any many-particle system doesn't really exist in 'real' space, but a multi-dimensional 'configuration space', because it's a function of all coordinates of all electrons. E.g. helium would be Ψ(r1, r2) with the coordinates of both electrons, its square giving the probability of finding electron 1 at point r1 simultaneously with electron 2 at point r2. So to get the actual electron density (the probability of finding any electron at some point in space), you have to integrate the square of the wave function over all of space for all coordinates but one.
(Or in other terms, you have the 1-particle density, the two-particle density and so on)
The 'probability cloud' description can be a bit misleading, since it's easy to forget that the electrons are still moving (in some, non-classical sense), even if the resulting particle density does not change with time. Otherwise you might ask why we'd need quantum mechanics to begin with, since classical electrostatics doesn't actually have any problems modeling a static charge-density cloud.
1. What are energy eigenstates and wavefunctions?
Energy eigenstates are the possible energy levels that a quantum system can have, while wavefunctions are mathematical representations of the quantum state of a system. They describe the probability of finding a particle in a specific position and momentum.
2. How are energy eigenstates and wavefunctions related?
Energy eigenstates and wavefunctions are related through the Schrödinger equation, which describes how the wavefunction of a system evolves over time. The energy eigenstates are the solutions to this equation, and the wavefunction can be expressed as a linear combination of these energy eigenstates.
3. What is the significance of exploring the relationship between energy eigenstates and wavefunctions?
Understanding the relationship between energy eigenstates and wavefunctions is crucial in quantum mechanics, as it allows us to predict the behavior of quantum systems. It also helps us to understand the fundamental principles of quantum mechanics, such as superposition and uncertainty.
4. How can we determine the energy eigenstates and wavefunctions of a system?
The energy eigenstates and wavefunctions of a system can be determined through various mathematical techniques. One common method is to solve the Schrödinger equation for the system, which will give the energy eigenvalues and corresponding wavefunctions. Experimental measurements can also be used to determine these quantities.
5. What are some real-life applications of energy eigenstates and wavefunctions?
Energy eigenstates and wavefunctions have numerous applications in various fields, including quantum computing, material science, and chemistry. They help us to understand and predict the behavior of quantum systems, which is essential for developing new technologies and advancing our understanding of the physical world.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
