Exploring Constant Acceleration with Nuclear Chain Reaction in Space
In summary, the conversation discusses the possibility of using sustained nuclear chain reactions to provide constant acceleration for objects in space. While there are concerns about safety and the use of radioactive materials, experts argue that the dangers are minimal and that there are already high levels of radiation in space. Additionally, the use of nuclear energy is considered a more efficient and powerful option for deep space travel. The conversation also touches on the topic of nuclear waste and its impact on the environment, with some arguing that it is not a major concern while others believe it should not be added to the already existing pollution issues.
wllsrvive
Is it possible to make an object travel with a constant acceleration using sustained nuclear chain reaction in space?
Astronomy news on Phys.org
Yes. A nuclear powered ion engine could provide constant acceleration for years. That's constant according to the spacecraft , btw...
I'd say no. The first thing anyone must consider about space technology is safety. Would you consider volunteering to hop on a radioactive propulsive vehicle knowing you can't get out if something goes wrong? If in fact you did get out in the event something went wrong, where would you go? Deaths by radiation are not only gruesome but from what i understand extraordinarily painful.
Perhaps you consider an unmanned vehicle?
Well, no to that as well. Suppose it's guidance was altered by some undiscovered gravity anomaly and pointed the sucker right at something other then the intended target. Not only would millions of dollars in equipment would be lost but also damage to the unintended target could be catastrophic to possible life there.
Absolutely. The radioactivity isn't much of a concern at all.
So are deaths from fire.
Indeed, such vehicles already exist:
http://en.wikipedia.org/wiki/Deep_Space_1#NSTAR_ion_engine
That craft fired its engine for just under two years, continuously. It was solar powered, though.
Spacecraft are guided, so that's not an issue.
russ_watters said:
Absolutely. The radioactivity isn't much of a concern at all. So are deaths from fire. Indeed, such vehicles already exist:
That craft fired its engine for just under two years, continuously. It was solar powered, though. Spacecraft are guided, so that's not an issue.
I am by far not an expert, but after russ's comments about radiation not being much of a concern I further researched and found Uranium-235 to be a constant base for these types of "engines". The substance alone is hazardous and when undergoes a reaction may result with gamma radiation... that stuff that mad hulk mad... not so good for homo sapian sapian...
also other possible substances are known to be radioactive as well... plutonium, thorium, and uranium would fit into the category of these materials with radioactive capabilities.
https://secure.wikimedia.org/wikipedia/en/wiki/File:HEUraniumC.jpg
http://www.lm.doe.gov/land/sites/oh/fernald_orig/50th/photos/85-193.jpg
http://www.corbisimages.com/images/67/F1B0F0FC-C457-4761-AD93-705DC67DE8E8/IH081416.jpg
Those are some random pics I found of people holding uranium in their hands. Uranium is not particularly dangerous (not much more dangerous than lead). Just because something is radioactive does not mean it is automatically deadly and evil. If I was going into space on a properly engineered spacecraft , a nuclear power plant would be near the last of my concerns.
As russ pointed out fires in a spacecraft would be just as bad (and much more likely) as any nuclear accident. I think nuclear powered subs would be a good analogy. There are certainly plenty of people willing to be on them.
Unmanned spacecraft often use RTGs for power, which use a small amount of radioactive material to generate heat and in turn power. The reason the are used for unmanned spacecraft doesn't have to do with safety, but rather because they are only used farther from the sun than humans have ever gone.
https://secure.wikimedia.org/wikipedia/en/wiki/Radioisotope_thermoelectric_generator
Lastly, I'd like to point out that if you are leaving low Earth orbit, i.e., going to the moon, then there is already plenty of radiation in space.
Nuclear fission allows, in theory, exhaust velocities of 12,000 km/s. Accelerating at 1 m/s^2 means that can be sustained for 12 million seconds with a fuel mass 1.72 times the vehicle's mass - long enough? Of course you can go faster, but the fuel mass increases rapidly, exponentially even. Unless you can get more fuel on the fly... What were you planning? A long trip?
Love how in all the pictures they're wearing protective gloves. The material may be relatively inert, but as Dave stated there's plenty of radiation in space already. I can only guess that in the near future producing more radiation in space will have catastrophic effects throughout. Just as it is inappropriate to dispose of waste here on Earth space will also hold these emission values... Adding to the problem hasn't solved much here where people are barely beginning to understand the impact of pollution.
I understand that many objects in physics may be theoretical. But what's the point of theory if your grandchildren will disprove it.
You think those rubber gloves protect them against radiation?
You really misunderstand nuclear energy. Nuclear "waste" is not a pollutant in normal circumstances as it is never intended to be released into the environment. Even including accidents, nuclear energy is neither a major safety nor pollution problem - no western country has ever had a civilian nuclear energy accident that killed more than a handful of people or caused a substantial amount of pollution. The magnitude of the danger and environmental impact of nuclear energy is much smaller than that of chemicals both for regular use and in the event of accidents.
For accidents, the Russians are the world leaders in environmental destruction, but all of the world's deaths due to nuclear power excluding Russia total under 100. Yet we accept with barely the batting of an eyelash, the death of 20,000 people a year in the US alone due to coal power pollution.
They are wearing gloves because uranium is a toxic metal, like lead. I'd want to wear gloves if I had to handle lead on a regular basis as part of my job.
Correct me if I'm wrong, but are you arguing that we are going to damage space by polluting it with radioactive materials? Space is a massive, virtually empty, expanse. There's nothing to damage there. Even if there were, the Sun contains more radioactive material and puts out more ionizing radiation than we as humans could ever hope to. As for the inner planets they are largely rocks, and there isn't much to radiate there. The outer planets and their moons would have quite a bit more care taken as they are more interesting. In either case though, contaminating with life from Earth (bacteria) is a more serious concern than radioactive material.
The point is that "nuclear" elicits an irrational fear in many people. This is frustrating because there is tremendous potential with the energy of nuclear power. Radiation can be dangerous, but so can toxic metals, and flammable materials. However, if the risks are understood and handled properly they can be mitigated greatly. Avoiding any possible risk, or waiting to do anything until we have perfect understanding will only lead to an end to advancement.
Your statement is incoherent. Care to rephrase it?
I thought the question was specifically addressed to whether it is possible by today's technological and scientific community. All I've heard is a lot of talk, and not much product. So in theory, which could be debated for decades or more, it could be refined to such a process as Dale suggests. But I wouldn't count on that unless you're smarter then Albert Einstein, who has many theories which have been dis-proven by today's scientific community.
It's not a matter of theory, but practicalities. Different matter entirely. But it also is irrelevant to drag Einstein into the question since he doesn't forbid uniform rectilinear acceleration from the point of view of the accelerating reference frame. In fact relativity guarantees such is perfectly physical. What relativity violates is the naive Newtonian expectation that all observers will see the same motion.
1. What is a nuclear chain reaction?
A nuclear chain reaction is a process in which one atomic nucleus splits, releasing energy and particles that can trigger other nuclei to split in a continuous chain. This process is the basis of nuclear power and nuclear weapons.
2. How is constant acceleration achieved with a nuclear chain reaction in space?
In space, a nuclear chain reaction can be used to produce thrust by continuously splitting atomic nuclei and releasing energy in a controlled manner. This energy can be harnessed to propel a spacecraft forward at a constant acceleration.
3. What are the advantages of using nuclear chain reaction for constant acceleration in space?
Compared to traditional chemical rockets, a nuclear chain reaction can provide a much higher specific impulse, meaning more efficient use of fuel and longer duration of acceleration. It also allows for a higher top speed and potentially shorter travel times for space missions.
4. Are there any safety concerns with using a nuclear chain reaction in space?
Safety protocols and precautions must be taken when using nuclear technology in space, just as they are on Earth. However, the risk of a nuclear accident in space is relatively low due to the lack of oxygen and other factors that can cause explosions.
5. How does the use of nuclear chain reaction in space impact the environment?
If proper safeguards are in place, the impact of a nuclear chain reaction in space on the environment is minimal. The main concern would be the potential release of radioactive material in the event of an accident, but the vastness of space would likely disperse and dilute any harmful effects.
  • Astronomy and Astrophysics
  • Nuclear Engineering
  • Science Fiction and Fantasy Media
  • Mechanical Engineering
