Magnetic Field of wire on rectangular loop
In summary, the conversation discusses a problem in which an infinitely long wire with a current of 5.00 A is placed next to a rectangular loop with dimensions of 0.150 m x 0.450 m and a current of 10.0 A. In part (a) of the problem, the magnitude and direction of the net force exerted on the loop by the magnetic field created by the wire is found. In part (b), the force on the top horizontal segment of the loop is calculated in three ways: net force, average force, and the force on the midpoint. The calculations for these forces are shown, but there is uncertainty about the accuracy of the calculation for the force on the midpoint. Suggestions for improvement are
BrettB
I have attached a diagram. In case you can't view it, it shows an infinitely long wire [itex] I_i = 5.00 [/itex] A on the positive y direction. 0.100 m to the right, there is a rectangular loop of dimensions 0.150 m x 0.450 m, the long side is parallel to the infinitely long wire to its left. The current is [itex] I_2 = 10.0 [/itex] A and also flowing up (in the position closest to the infinitely long wire).
a) Find the magnitude and direction of the net force exerted on the loop by the magnetic field created by the wire.
b) Find the force on the top, horizontal segment of the loop. Calculate this three ways: net force, average force, and the force on the midpoint.
Bio-Savaart equation.
I didn't have any trouble with (a). The force on the top and bottom horizontal segments just cancel, so I can disregard them. The rest is pretty simple.
Part (b) is giving me lots of trouble. I am not 100% sure I am calculating the magnetic force of the infinitely long wire on the horizontal part of the loop properly, and I really am not certain how to handle the vertical segments of the loop. These are not infinite, so there must be some error introduced in this case, but I have no idea how to approximate it. Would the errors just cancel, and the net force of these also be zero?
Here is what I have done so far, I hope this is ok:
For the net force:
[tex] B = \int_{0.100}^{0.250} \frac{(5.00)(10.0)(\mu_0)}{2\pi x}\,dx = 1.00268(\ln(x))_{0.100}^{0.250} = 9.19 \times 10^{-6} [/tex]
For the average force, I just used the mean value theorem, and multiplied the above by 1/(0.250-0.100) to get 6.12 x 10^{-15}.
To calculate the force on the midpoint, I first calculate the force from the vertical wire:
[tex] \frac{\mu_0(5.00)}{2\pi(0.100+\frac{0.150}{2})}\hat{i} = 5.73\times 10^{-6}\hat{i} [/tex]
Then the other force:
[tex] \frac{\mu_0(10.0)}{2\pi(0.100 + \frac{0.150}{2})}\hat{j} = 1.15 \times 10^{-5}\hat{j} [/tex]
Since these are perpendicular, I got the rest as
[tex] \sqrt{(5.73\times 10^{-6})^2 + (1.15 \times 10^{-5})^2} = 1.28 \times 10^{-5} [/tex]
Intuitively, I would have expected closer values with all these results, so I am surprised they are so far apart, and that makes me question my work.
Any advice gratefully accepted.
Thanks,
Brett
Wow, nobody? Well, I fixed a couple of typos, but I am no closer to certainty. If I've violated some rule, I'm sorry. I'm new here :-) But I would really appreciate some help.
Thanks,
Brett
You haven't done anything wrong, I think you've done a good job of presenting your problem. I just honestly am not sure I can help!
I'm a bit puzzled by this question. I would interpret it as: Calculate the force exerted on the top horizontal segment by the magnetic field created by the wire in three different ways and compare.
For the "net force" you integrated to find the actual force from the wire on the segment. OK. (Don't really know what "net force" means in this context.)
By "average force", I would have calculated the force per unit length at each end of the segment, averaged them, then multiplied by the length of the segment.
For "force at midpoint", I would have calculated the force per unit length at the midpoint, then multiplied by the length of the segment.
Grasping at straws here, since the question isn't clear to me.
I can point out a couple of things for you to double check. I think you are getting B and F mixed up when you are using the equations. Not sure, just a thought.
For the net force:
This is for F, though, you have B there. Just a typo maybe?
OK, I don't think this is for F, you are actually calculating B. Check the units.
B again, not F.
Thanks,
Brett
Thank you both, VERY much. Hage567, yes, I was calculating the completely wrong thing, thank you.
I think I still must be doing something wrong, since I get answers that are very different, or I don't understand why they should be this different. I'm also wondering why using the mean-value theorem wouldn't be the right way to calculate the "average" value in this case.
Using Doc Al's suggestion to compute the average, I get for the left end of the horiztonal wire:
[tex] \frac{(1.26 \times 10^{-6})(5.00)(10.0)}{2\pi (0.100)} = 1.00268 \times 10^{-4} [/tex]
For the right end:
[tex] \frac{(1.26 \times 10^{-6})(5.00)(10.0)}{2\pi (0.250)} = 4.01070 \times 10^{-5} [/tex]
These values would be the force per meter, I believe.
Taking the average, and multiplying by the length of the wire, I get 1.05 x 10^-5.
For the force/m at the midpoint:
[tex] \frac{(1.26\times 10^{-6})(5.00)(10.0)}{2\pi(0.100 + \frac{0.150}{2})} = 5.72958 \times 10^{-5} [/tex]
and multiplying by 0.150 (the length of the wire), I get 8.59 x 10^-6, which is closer to the total force. But not very.
Is this the right way to go about it? The only conclusion I can come to from this is that, since the force doesn't vary linearly (if you look at the integral, it is a logarithmic function), using these other ways is not the right way to estimate the force on a perpendicular wire.
Thanks again for your help, and any additional help or comments would be really appreciated.
Thanks!
Brett
What is a magnetic field?
A magnetic field is a region in space where magnetic forces can be detected. It is created by moving electric charges, such as the flow of electricity through a wire.
How does a wire on a rectangular loop create a magnetic field?
When an electric current flows through a wire, it creates a circular magnetic field around the wire. When the wire is formed into a rectangular loop, the magnetic fields from each side of the wire combine to form a stronger and more uniform magnetic field inside the loop.
What factors affect the strength of the magnetic field in a wire on a rectangular loop?
The strength of the magnetic field in a wire on a rectangular loop depends on the current flowing through the wire, the number of turns in the loop, and the distance between the wire and the loop.
Can the direction of the magnetic field be changed?
Yes, the direction of the magnetic field can be changed by changing the direction of the current flowing through the wire or by changing the orientation of the wire on the loop.
What are some real-world applications of the magnetic field of wire on a rectangular loop?
The magnetic field of a wire on a rectangular loop is used in various applications, including electric motors, generators, and transformers. It is also used in magnetic sensors and magnetic levitation systems.
