sqrt_9
- 3
Hi!
I'm breaking my head about the following problem:
Consider an A/C at a certain velocity flying at a certain altitude. The A/C measures it's speed via the difference in total- and static-pressure and applying bernoulli.
Now the aircraft accelerates. What happens?
At this point I get uncertain and look forward to hear your opinions:
- I assume that the measured static pressure drops
--> measured velocity increases (no problem)
--> But: static pressure drops: altitude decreases (big problem!)
The other opportunity would be:
- The total pressure increases
--> The static pressure remains constant & only dynamic pressure increasesEdit: Additional fundamental question:
Does a static pressure sensor see reduced static pressure if a flow is doubled in speed? If yes, this would again mean that the static pressure sensor indicates lower altitude due to higher velocity...
Thanks in advance!
Thanks in advance!
