General questions regarding pressure sensors , needed equipment
In summary, the conversation discusses the use of pressure sensors for measuring flow levels in small rivers. The speaker is unsure about the equipment needed for submerged pressure sensors and whether differential pressure sensors are necessary. It is mentioned that hydrostatic pressure can be measured by submerging a pressure sensor, but a better method is to keep the sensor technology above the flood level using a tube and a peristaltic pump. This allows for easy replacement and avoids damage from floods or vandalism.
Hemmelig
Hey
Working on a rather large project and it's the first time I've had to look into the world of pressure sensors.
Basicly, we're looking into measuring flow levels in small rivers, either in areas where we build a profile to gather up the water and in natural areas where there's no need for construction.
Most of it seems to be pretty straight forward, but there's a couple of things I'm struggling to fully grasp
What type of equipment is needed for submerged pressure sensors ? Is it pretty much a case of getting it to the bottom of the river and fasten it there by using your own preferred method ?
Is there any point in using a differential pressure sensor in rivers ?
Basicly been looking at absolute pressure sensors and gauge reference pressure.
Differential pressure is only needed if you are looking for very accurate records that could be affected by barometric surface pressure.
Hydrostatic pressure can be measured by submerging a pressure sensor. But a better way is to keep all the sensor technology above the flood level. To do that, fix any suitable tube in position with the lower end in the water at the depth required. The upper end of the tube is in the instrument housing where a small peristaltic pump pushes filtered air down the tube, so a small bubble rises every few seconds from the deep end of the tube. The air pressure in that tube is sensed at the top or pump end and represents the hydrostatic pressure at the deep end of the tube. The tube can be buried in the river bank, and does not get blocked by growth, while all instrumentation remains dry, above the flood level. The tube diameter, length, and material are not critical parameters, it can be a cheap small bore tube. The tube is easily replaced after flood damage (or vandalism), without any need for re-calibration, apart from getting the depth of the deep-end correctly fixed.
What is a pressure sensor and how does it work?
A pressure sensor is a device that measures the force per unit area exerted by a fluid or gas. It works by converting the pressure into an electrical signal that can be measured and interpreted by other equipment.
What types of pressure sensors are available and what are their differences?
There are several types of pressure sensors, including piezoelectric, capacitive, and strain gauge sensors. Each type has its own unique method of measuring pressure and has different applications and accuracy levels.
What equipment is needed to use a pressure sensor?
The specific equipment needed will depend on the type of pressure sensor being used, but generally, you will need a power supply, a data acquisition system, and a signal conditioning circuit. Additional equipment may be needed for specific applications.
How do I calibrate a pressure sensor?
To calibrate a pressure sensor, you will need a known pressure source, such as a deadweight tester or a pressure calibrator. The sensor should be connected to the source and the output signal should be compared to the expected value. Adjustments can then be made to the sensor if necessary.
What are some common sources of error when using pressure sensors?
Some common sources of error when using pressure sensors include environmental factors (such as temperature and humidity), mechanical stress on the sensor, and electrical interference. Proper calibration and maintenance can help minimize these errors.
  • Optics
