Looking for piston details explained
  • Thread starter 5.0stang
  • Tags
    Piston
In summary: There are other factors at play too, like the type of oil and tune, but that's a whole other topic.In summary, the different parts of a piston's configuration affect how the engine performs. For example, the compression height, ringland, deck thickness, ring grooves, and piston/deck height volume all play a role in how the engine performs.
5.0stang
63
I'm trying to find an article or something similar online that has a diagram of a piston and explains the different parts of the piston.
For example, trying to find out what the piston's compression height, ringland, deck thickness, ring grooves, etc.
I would like to know what all of these mean.
A particular piston I'm looking at says:
Compression Height: 1.090
Ringland: .220, .140, 075.
Deck Thick: .325
Ring Grooves: 1/16,1/16,3/16
What do those numbers mean?
Thanks from a newbie:)
Compression height is the distance from the centre of the gudgeon pin to the crown of the piston (the flat bit on the top).
Ring land is the distance between the rings; hence top ring land is the distance between the top ring and the crown.
Ring grooves are the grooves into which the piston rings sit.
I'm not sure about 'deck thick', I imagine it to be the thickness of the top deck taken at its thinnest point.
Your always a helpful one:cool:
Anyone got a piston diagram that is labeled?
Fred's link said:
Piston/Deck height volume is the small volume at the top of the cylinder that is not swept by the
piston.
That's what I was going to suggest too, but it's not actually a piston parameter because it's dependent on other components, whereas all the others are piston-specific. I think there's a subtle difference between piston/deck height volume and deck thickness.
I'll try and remember to ask next time my piston man is around.
I've got a labelled piston diagram but it's in a book and doesn't have all the parameters you were after. I'll see what I can find at work, failing that I'm certain you'll find something on the Federal Mogul or Mahle websites.
I was thinking the same thing when I saw that. However, couldn't that parameter be changed simply by changing the height of the piston? I honestly have no idea why one would do that other than increased pressure. Is that usually an option with pistons?
Yes it could be changed by altering the height of the piston, that's why I don't think it's a piston parameter; it's as much to do with the crankshaft, case, and conrod as the piston itself.
You'd be changing it to alter the engine's compression ratio for power and efficiency.
Related to Looking for piston details explained
What is a piston?
A piston is a cylindrical component that moves up and down inside an engine cylinder. It is responsible for converting the energy from fuel combustion into mechanical motion.
How does a piston work?
When fuel is ignited in the engine cylinder, it creates a controlled explosion that pushes the piston downward. This motion is then transferred to the connecting rod and eventually to the engine's crankshaft, which powers the vehicle.
What are the main parts of a piston?
A piston typically consists of a head, a skirt, a wrist pin, and piston rings. The head is the top part of the piston that comes into contact with the fuel explosion. The skirt is the cylindrical body of the piston that moves up and down in the cylinder. The wrist pin connects the piston to the connecting rod. The piston rings are located on the outer edge of the piston and help seal the combustion chamber.
What are some common materials used to make pistons?
Pistons are typically made from aluminum, cast iron, or steel. Aluminum is the most commonly used material due to its lightweight and heat-resistant properties. Cast iron is more durable but also heavier. Steel is the strongest material but is more expensive and not commonly used in everyday vehicles.
How do I know when my piston needs to be replaced?
There are a few signs that may indicate a worn or damaged piston, such as a decrease in engine performance, loud knocking noises coming from the engine, and excessive oil consumption. If you notice any of these symptoms, it is best to have a professional mechanic inspect your piston and determine if it needs to be replaced.
  • Mechanical Engineering
  • Classical Physics
  • Other Physics Topics
9K
10K
