Physics Olympiad 2010 practice test question # 23
In summary, the speed of water in the tube on the right is twice the speed of water in the tube on the left.
NewtonGalileo
Two streams of water flow through two U-shaped tubes (the two U-tubes are facing away from each other, but touching each other at the base of the 'U's). The tube on the left has cross-sectional area A, and the speed of the water flowing through it is v. The tube on the right has cross-sectional area A' = A/2. If the net force on the tube assembly is zero, what must be the speed v' of the water flowing through the tube on the right? Neglect gravity, and assume that the speed of the water in each tube is the same upon entry and exit.
Hi NewtonGalileo! :wink:
What principle do you think you should use?
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
This is what I tried.
Imagine that the two U's were separated and were moving towards each other. Since their final momentum is 0 (they're touching each other in equilibrium as the problem states), their initial momentum ought to be 0 because the system is closed. So, since the tube on the left has twice the mass of the tube on the right, the speed of water on the right has to be twice the speed of water on the left. So, my answer was [tex]2v[/tex]. But, this solution really does not make much sense to me, and the correct answer should be [tex]\sqrt{2}*v[/tex]. Please help!
(have a square-root: √ :wink:)
how did you calculate the momentum? :confused:
The momentum of each tube is zero, they don't have equal and opposite momentum which cancels (they do but it's zero because no tube is moving),, so for each tube water is coming in and leaving at the same speed, for this to happen there would have to be a force on the tube which is canceled from the force due to the other tube..
hi alemsalem! :smile:
alemsalem said:
The momentum of each tube is zero …
uhh? :confused:
the momentum changes: it start to the left, but after the bend it's to the right …
so how much does it change?
uhh? :confused:
I was referring earlier to his approach, he treated it as if the two U tubes where moving in opposite directions and one with twice the mass should have half the velocity in order to have equal and opposite momentum. but that's not the case the total momentum of each tube alone is zero
not really following you (or maybe I'm not following him) :confused:
anyway, your calculations are correct, but please don't give the full answer when the OP hasn't yet done the question …
fortunately, he's still off-line, so can you do a bit of editing? :wink:
done :smile:
1. What is the topic of question #23 in the 2010 Physics Olympiad practice test?
The topic of question #23 is rotational motion.
2. Can you provide the equation related to this question?
Yes, the equation related to this question is τ = Iα, where τ is the torque, I is the moment of inertia, and α is the angular acceleration.
3. Is there any specific concept or formula that I should focus on to solve this question?
Yes, you should focus on the concept of rotational motion and the formula for torque (τ = rFsinθ) as well as the formula for moment of inertia (I = mr²).
4. How can I approach this question and what steps should I follow?
To approach this question, you should first understand the given scenario and identify the relevant concepts and formulas. Then, you can use the given information to calculate the moment of inertia and the torque. Once you have these values, you can use the equation τ = Iα to solve for the angular acceleration.
5. Are there any common mistakes that students make while solving this question?
One common mistake is not considering the direction of the torque, as it is a vector quantity. Another mistake is not using the correct formula for moment of inertia, as it varies depending on the shape of the object. It is also important to use the correct units for all values in the calculations.
  • Mechanical Engineering
  • General Engineering
  • Classical Physics
  • STEM Academic Advising
