Effect of lunar/solar gravity on shape of earth
In summary, Gamow's book 'Gravity' explains the effect of lunar gravity on the Earth, including the seeming paradox of oceans swelling both towards and away from the moon. This paradox is resolved by considering Kepler's laws and the greater angular velocity of water on the opposite side of the Earth. The extra water in high tide areas is drawn from low tide areas within the same ocean. However, this does not explain the absence of tides in small closed seas such as the Baltic. The Earth's rotation and the moon's orbit cause regular cycles of high and low tides at different ocean coasts. The main issue with this explanation is the separation of the Americas, which prevents significant water flow between the Pacific and Arctic Oceans. The far
  • #36
russ_watters said:
Hurkyl, what I think I'm seeing for the near side doesn't sound like any of those:
The tidal force creates a near-side bulge and flattens the far side.
Then #4 would explain the far side bulge.
It just so happens someone posted a discussion of exactly what I'm referring to in another thread (the second diagram shows it):
One of the few books that clearly defines "tide" at the outset is The Planetary System by Morrison and Owen [1966]: "A tide is a distortion in the shape of one body induced by the gravitational pull of another nearby object." This is definition (2) above. It clearly says that tides are the result of gravitation, without any mention of rotation effects...
http://www.lhup.edu/~dsimanek/scenario/tides.htm
Now here's where it gets really interesting:
In this representation [the centrifugal force misconception] we can treat this system as if it were an inertial system, but only at the expense of introducing the concept of centrifugal force. It turns out that when this is done, the centrifugal force on a mass anywhere on or within the Earth is of constant size, and is therefore equal to the size of the gravitational force the moon exerts on the same amount of mass at the center of the Earth... ...
We are now focusing on the effects due only to the Earth-moon system. The motion of the Earth about the Earth-moon center of mass, causes every point on or within the Earth to move in an arc of the same radius. This is a geometric result most books totally ignore, or fail to illustrate properly. Therefore every point on or within the Earth experiences the same size centrifugal force. A force of constant size throughout a volume cannot give rise to tidal forces (as we explained above). The size of the centrifugal force is the same as the force the moon exerts at the Earth-moon center of mass (the barycenter), where these two forces are in equilibrium. [This barycenter is 3000 miles from the Earth center—within the Earth's volume.]
That's a twist I actually wasn't aware of, but of course it makes sense: The barycenter is not a fixed point that the Earth rotates around, but a virtual point that moves as the moon moves around the earth.
  • #38
K^2 said:
Are we looking at tidal force on the dumbbell? Ok. How about this. Ceter - Earth's center at t0, traveling at 30,000km/s in direction tangential to the line connecting Earth and dumbbell. Rotation - omega=1 with axis perpendicular to the direction of CS center's travel and the line connecting Earth and dumbbell. Dumbbell is stationary at t0 in this coordinate system, yet clearly experiences centrifugal tide.
Does that help?
Yes, thanks. So:
1. How did you come up with this coordinate system?
2. Can you show me how you would compute the tidal force using your coordinate system? By that I mean, show me the equations you would plug that information into to compute the force.
  • #39
1. I didn't want to deal with Coriolis effect, so I picked one where dumbbell system is stationary. I also like to use heavy body as center for CM for simpler symmetry. All other numbers are arbitrary.
2. Schwarzschild metric in the rotating frame:
[tex]ds^2 = \left(r^2\omega^2 sin^2\theta + \frac{2M}{r} -1\right) dt^2 + \left(1 - \frac{2M}{r}\right)^{-1} dr^2 + r^2 d\theta^2 + r^2 sin\theta d\phi^2 - 2 r \omega dt d\phi[/tex]
I'm sure you know how to compute free-fall Reiman tensor.
  • #40
russ_watters said:
What bulges are you referring to?
The bulges that cause tides. In your scenario without rotation, would the tides will still be the same, as in the case of Moon and Earth orbiting each other?
russ_watters said:
And just to be as clear as possible, here's the equation for tidal force:
[tex]F=2G \frac{mM}{r^3}dr[/tex]
http://burro.cwru.edu/Academics/Astr221/Gravity/tides.html
Does anyone have an equation for tidal force that includes a centrifugal force?
That is the tidal force due to gravity gradient alone, so it obviously doesn't include the effects of rotation. My question is if the effective tidal force for a rotating system would be different, and cause different tides than in a non rotating system.
For simplicity let's replace the Earth with two masses connected via a string :
O-------O to the moon --->
Will the force in the string will be the same, regardless if the system rotates or not, or will it be different?
  • #41
Hurkyl said:
Agree or disagree:
  1. Tidal force from the moon causes a bulge on the near and far sides of the Earth, and flattens the places in-between.
  2. Tidal forces from the sun cause a bulge on the sides of the Earth near and far from the Sun, and flattens the places in-between.
  3. The Earth's rotation causes a bulge evenly distributed around the equator, and flattens the poles. [..]
The last one quoted (no.3) is misleading: due to the centrifugal action the land mass is bulged the same as the oceans, in a steady state (this is verified with atomic clocks: at mean sea level they have the same rate everywhere). Thus the Earth's rotation cannot explain the tides.
The common (and probably correct) explanation is that the acceleration of the water due to the moon's "pull" is higher than that of the Earth on the side of the moon, and lower than that of the Earth on the other side.
  • #42
The tides are the same size whether there is an orbit or not and whether there is a rotation or not.
I'm sorry, but that's nonsense. By definition that's all the tidal force is.
If the system rotates, the force on the string will be greater, but that isn't a tidal force. What you are describing sounds to me like the constant height equatorial bulge, not the tidal force.
  • #43
You're claiming you can calculate a tidal force from that equation? Doesn't look like it to me, but I'd love to see it. I'd also like to see a reference for that being an equation for tidal force.
  • #44
I'm not asking about the definition of the term "tidal force". I'm asking if the tides on Earth are solely an effect of the "tidal force" due to gravity gradient, or if the effect is modified by the gradient in the centripetal force required for the orbit of the Earth's COM around the common COM of Earth & Moon. (In the co rotating frame it would be the gradient of the centrifugal force)
I don't care how it's called. If the force is greater in a rotating system then it means the Earth's is stretched more, than it would be due to gravity gradient alone. That would mean that the rotation of the system does affect the magnitude of the tides on Earth.
No. The equatorial bulge is due to the spin of the Earth around it's own axis in 24h periods. I'm talking about the effects of the rotation of the Earth's COM around the common COM of Earth & Moon in 27d periods.
  • #45
A.T. said:
I'm not asking about the definition of the term "tidal force". I'm asking if the tides on Earth are solely an effect of the "tidal force" due to gravity gradient...
Yes. The tides are soley due to the tidal force.
  • #46
Hurkyl said:
The primary effect of the gravity of an object is to pull other objects towards it.
Tidal force is the difference in gravitational attraction. If you have an elastic object and you tug (along a line) on the opposite sides with different force, then you stretch the object out along that line. This is the secondary effect of gravity -- to stretch objects. To deform spheres into things like seen at this wiki page.
Your reply is given without reference to other posts. To suggest that a prolate spheroid results from the moon's gravitational pull on the Earth begs the question. The question is, why would a pull in the direction of the moon cause the waters on the far side of the Earth to move in the *opposite* direction? At worst we would expect a bulge at the far side that did not exceed the "equatorial bulge."
You suggest that a *difference* in attraction might result in a rebellion of waters at the far side of the earth, but this is contrary to the idea that the moon's g-field is continuous. It may fall off quickly as the distance from the moon, but it will not change directions.
While I agree with Russ, who only acknowledges me in the third person, that resort to tensor calculus is unhelpful, and I can be persuaded that the argument he cites (Siminak, who directly contradicts Gamow) regarding centrifugal forces is correct, I do not see in the cited page the calculation of the "gradient of the moon's gravitational force" resulting in "tidal forces" whose sense is precisely opposite to that of the force creating them--the moon's pull. It's counterintuitive and I would like a cite for the calculation.
  • #47
The waters on the far side don't move away from the moon.
The waters on the far side move away from the center of the Earth for exactly the same reason that the center of the Earth moves away from the waters on the near side.
  • #48
If you are agreeing with Russ, can you explain Simanek's "gradient"? The moon's gravitational field is a vector field--he speaks of finding the "gradient of the moon's gravitational force upon...[the volume of the earth]." Well, then it would be tensorial.
You are proposing that the Earth arranges itself along the axis of lunar pull, and that if we suddenly placed the moon on the opposite side, in a while the (tidal) shape of the Earth would be essentially unchanged.
  • #49
Okay, thanks. I found this website:
http://www.vialattea.net/maree/eng/index.htm
It comes to the same conclusion:
The orbiting of the Earth's COM around the common COM of Moon & Earth has no effect on the tides.
I have not checked the math in every detail. It goes into great detail explaining common errors, and it has the calculation in all possible reference frames.
  • #50
"Tensorial"? "Simanek's gradient"? "Schwarzschild's metric"? Guys, stick to common sense!
Tide is a phenomenon that on a full/new moon you may go to the beach in the afternoon to pick crabs, moules, and other tasty living beings, while on the quartermoon you could drown in the place you used to pick crabs a week before, rather than being able to pick something for a dinner.
No tensorial analysis is able to explain why on Bretonian beach tides are 2 metres high, while on Lofoten they may be 8 meters high. And even Simanek won't help you hunting crabs.
  • #51
This appears helpful. I will be interested to see if the effect is not slightly attenuated on the far-side of the Earth w/r to the moon. And perhaps I can get a refund from Dover for Gamow's book?
  • #52
Yeah, except I messed up transform, and the metric I gave you isn't Ricci flat. I'll fix it and get back to you.
Edit: Ok, here we go. Corrected form of the metric, first.
[tex]ds^2 = \left(r^2\omega^2 sin^2\theta + \frac{2M}{r} -1\right) dt^2 + \left(1 - \frac{2M}{r}\right)^{-1} dr^2 + r^2 d\theta^2 + r^2 sin\theta d\phi^2 - 2 r^2 \omega sin^2\theta dt d\phi[/tex]
Given that metric, all you have to do is compute the Rieman tensor.
[tex]R^\alpha_{\beta\gamma\delta} = \frac{\partial \Gamma^\alpha_{\beta\delta}}{\partial x^\gamma} - \frac{\partial \Gamma^\alpha_{\beta\gamma}}{\partial x^\delta} + \Gamma^\alpha_{\gamma\rho}\Gamma^\rho_{\beta\delta} - \Gamma^\alpha_{\delta\sigma}\Gamma^\sigma_{\beta \gamma}[/tex]
Where the Christoffel symbols are defined as follows.
[tex]\Gamma^\alpha_{\beta\gamma} = \frac{1}{2}g^{\alpha\delta}\left(\frac{\partial g_{\beta\delta}}{\partial x^\gamma} + \frac{\partial g_{\gamma\delta}}{\partial x^\beta} - \frac{\partial g_{\beta\gamma}}{\partial x^\delta}\right)[/tex]
And using the line element I posted earlier, the non-zero elements of the metric tensor are following.
[tex]g_{tt} = r^2\omega^2 sin^2\theta + \frac{2M}{r} - 1[/tex]
[tex]g_{rr} = \left(1-\frac{2M}{r}\right)^{-1}[/tex]
[tex]g_{\theta\theta} = r^2[/tex]
[tex]g_{\phi\phi} = r^2 sin\theta[/tex]
[tex]g_{t\phi} = -r^2\omega sin^2\theta[/tex]
The tidal acceleration from curvature is easy.
[tex]a^\alpha = - R^\alpha_{\beta r \delta}u^\beta u^\delta L[/tex]
Since object starts out at rest, u is trivial.
[tex]u^\alpha = (\left(1-\frac{2M}{r}\right)^{-1/2}, 0, 0, -\omega \left(1-\frac{2M}{r}\right)^{-1/2})[/tex]
(Feel free to verify that uαuα=-1)
So all you really need are 3 vectors: Rαtrt, Rαφrφ, and Rαtrφ.
Because I'm obviously not going to do all that work, I threw it into a Mathematica package and crossed my fingers.
[tex]a^\alpha=\left(0, \frac{2M}{r^3}L, 0, 0\right)[/tex]
Which is exactly the same result as I should get without rotation, so that's a good sign. If I substitute in the numbers for M, L, and r, I get tidal acceleration of 0.00015m/s². At the mass of 1000kg, that's 0.15N of tidal force. You should get exactly the same from classical method. (Especially since the classical formula gives you 2GM/r³.)
  • #53
daniel6874 said:
...I can get a refund from Dover for Gamow's book?
Perhaps, but from what I could see from the OP, there was nothing wrong with Gamow's explanation.
  • #54
Since you have gone to the trouble, perhaps you could explain why this might imply a bulge on the far side of the earth? The page Russ cited says the author found the gradient of the force-field to arrive at his conclusions about the movement of water. The gradient field in his picture, if correct, answers the question. I have access to Mathematica, so if you outline the calculation, that would be sufficient. It is clear we must take into account the shape of the earth.
  • #55
The problem would be that if what Russ said about centrifugal force is true, the explanation cannot be correct. I am suspending judgment until I understand the argument better.
  • #56
The computation I showed gives you a differential in forces acting on the front and far sides of the planet or other object. All it says is that the object will be stretched out. Id est, there will be some sort of bulging. Whether that bulging is symmetric or not is a matter of higher order effects which we have not yet discussed.
If you want to use Mathematica to graph what the Earth's surface would look like if it was a perfect fluid, taking into account Earth's gravity, Earth's rotation, and Moon's gravity, I can help you out with this. But maybe you should send me a PM, so that we don't clutter this topic.
Edit: Unless there are other people who want to see it. I suppose, I can just set it up in Mathematica and upload the notebook.
  • #57
I'm not sure the posts in the thread have much if anything to do with Gamow's explanation (which appears to be equivalent to Feynman's description, quoted in the other, similar discussion), so you won't understand the argument any better by reading what Russ said.
  • #58
Or in the words of Bill O'Reilly: You can't explain that!
  • #59
I think that Russ and K^2 did address the OP. A quick summary of the positions so far might include:
1. Gamow as per the OP.
2. Feynman, and [extrinsic to this post] [ crackpot link deleted ] daniel6874, the link you cited is not a good link for this site.. And that F. himself saw problems with his idea.
3. A quaint older text suggesting that the pull of the moon is stronger on the Earth than the water, so the Earth shifts like an egg-yolk toward the moon, leaving a bulge on the far side.
4. A reasonable note by xts that water for high tides is shifted from low-tide areas, and glosses from others [outside this post] on the effect of resonant land formations and separation of oceans to explain tidal height discrepancies.
5. An series of notes by K^2 that suggest the explanation of forces depends on choice of coordinate system.
6. Cited by Russ, http://www.lhup.edu/~dsimanek/scenario/tides.htm, an author who calculates the "tide-generating force" as the gradient of the moon's gravitational potential [I mistakenly said "force"], with a picture that seems to explain tidal bulges in terms of gravitation alone. The author then proceeds to outline what appears to be K^2's approach--the use of a rotating coordinate system with barycenter at the origin, noting that the mathematical origin of the "fictitious" forces is often omitted in this approach.
7. A gloss by harrylin on essentially the egg-yolk theory of 3 above, but updated I think to account for discussion in the post.
8. A.T. posts http://www.vialattea.net/maree/eng/index.htm, which seems to agree with K^2 but like Russ emphasizes the non-use of fictitious forces.
I am tempted to conclude that Russ, K^2, Gamow, and Feynman are all correct, taking into account simplifications and assumptions. After reading the author's home-page in 2 above I no longer think it bears pursuing. Thanks to all who helped with this apparently not-so-easy question.
  • #60
I'll start off by noting that I am not a fan of the centrifugal force explanation of the tides.
That said, one cannot say that a centrifugal force explanation is incorrect. K^2 was spot-on correct way back on page 2:
K^2 said:
It. Is. Arbitrary. You can chose ANY coordinate system. In any coordinate system, the results will be the same. In some systems, part of the tidal bulging is due to centrifugal force. In other systems, there is no centrifugal force.
You can choose ANY system you like and do the computations. You'll get the SAME answer.
General relativity says that all frames of reference are equally valid. Do the math right and you will come up with the same correct answer regardless of perspective. How can you say that one explanation is right and another is wrong when both explanations yield the same end results? You can't. What you can say is that one explanation is clean and simple in comparison to another that is twisted and ugly. The extra terms that arise in a rotating frame explanation vanish from the perspective of a non-rotating frame. While those extra terms are not essential to explaining the tides, they are not wrong.
The explanations that result from a non-rotating perspective and a barycentric frame rotating with the Moon's orbital rate are valid with respect to the tidal forcing functions. Both are correct with regard to the shape of the Earth itself in response to these forcing functions. The Earth itself undergoes tidal deformations. See http://en.wikipedia.org/wiki/Earth_tide, for example.
Neither explanation is correct with regard to oceanic tides. There is no tidal bulge. There are two huge land masses, the Americas and Eurasia+Africa, that prevent this from arising. To get a correct picture of the oceans' responses to the tidal forces you need to go to yet another perspective, one based on the rotating Earth. There you'll get a picture of amphidromic points, points with virtually no tides, about which the tides appear to rotate.
Picture: http://svs.gsfc.nasa.gov/stories/topex/images/TidalPatterns_hires.tif
Movie: http://svs.gsfc.nasa.gov/vis/a000000/a001300/a001332/full.mov
Since all frames are equally valid, I suppose one could come up with an explanation of the ocean tides from the perspective of a non-rotating frame or a frame that rotates with the orbit of the Earth and Moon about one another. Nobody does that because such an explanation would be hideously complex.
Addendum
An example of a hideously bad explanation based on centrifugal force, courtesy of our government: http://co-ops.nos.noaa.gov/restles3.html. This is so convoluted that I can't see if they've done the math right. There's just too much hand waving and there is no math to check. If they did do the math right they would of course have come up with the same answer as the much, much simpler gravity gradient based explanation.
  • #61
No matter how many times I say I understand that the math works out, people keep harping on it, so I must not be making myself clear. Let me try a completely different approach:
I dropped my pen and it fell to the ground. The centrifugal force due to the Earth's rotation caused the pen to fall to the ground. True or false? And why or why not?
  • #62
D H said:
Addendum
What's wrong with it? It's pretty much what Gamow and Feynman were talking about.
If you think about it carefully, rotating coordinates aren't so counter-intuitive for explaining tide-producing forces. The tidal "bulges" (in all the simplified examples here) are stationary relative to the earth-moon line, not to relative to fixed points on a non rotating Earth in an inertial frame.
  • #63
Well, causes are a philosophical thing.
But physics-wise, I'd like to hear why anybody would explain a pen falling toward the ground as being due to the centrifugal force due to the Earth's rotation.
  • #64
I disagree, but perhaps that is the whole problem here...
Since as people harped on me previously, we can construct rotating or non-rotating frames from which to analyze the question and all will give the same result, right? So then any effect captured by the calculations can said to be the cause.
  • #65
Well, not to point at you specifically, but there does seem to be much ado about nothing in some recent threads. There are a few obviously wrong explanations being tossed about, and then there are the persistent disagreements which are based on people's opinions about what is the "right" frame of reference for physics.
As I said, if you think it makes any sense to explain a falling pen that way, then I'd like to hear that construction. :wink:
  • #66
You're missing my point: I don't think it works that way, but that is what I think I am seeing from others.
What I'm seeing from others in this thread is this:
1. Since we can construct a mathematical model of the tides that incorporates a centrifugal force component, we can say that the centrifugal force causes the tides.
So why can't we then say this:
2. Since we can construct a mathematical model of the motion of a falling pen that incorporates a centrifugal force component, we can say that the centrifugal force causes the tides.
Why is one correct and the other not?
  • #67
D H said:
[..] Addendum
At first sight they seem to give exactly the same explanation:
'the effect of the external gravitational force produced by another astronomical body may be different at different positions on the Earth because the magnitude of the gravitational force exerted varies with the distance of the attracting body.' (but why "may be"?!)
Also (and happily!) they do point out that 'It is important to note that the centrifugal force produced by the daily rotation of the Earth on it axis must be completely disregarded in tidal theory.'
PS: note that I fully agree with your criticism on the way they phrase things.
  • #68
False, of course. Centrifugal force is directed outwards. It explains why your pen takes longer to fall to the ground than it would on a non-rotating planet with the exact same acceleration due to gravity.
Let g' be the local gravitational acceleration vector due to the Earth's mass only. From the perspective of a frame rotating with the Earth, your pen accelerates Earthward at g' due to the Earth's mass and accelerates outward at r×Ω2 due to the Earth's rotation. Here r is the vector from the Earth's rotation axis to the pen and Ω is the Earth's rotation vector, 1 revolution per sidereal day. The pen's net acceleration is g=g'-r×Ω2. Assuming that gravity and centrifugal acceleration change very little over the short fall, the time the pen takes to fall is given by [itex]\sqrt{2h/g}[/itex]. This calculation becomes even easier if you just use g in the first place rather than g'. For example, the standard value for Earth gravity, g0=9.80665 m/s2 includes both the gravitational and centrifugal forces at sea level and at a latitude of 45.5 degrees.
From the perspective of an inertial observer, the only force acting on the pen is gravity. The pen has an initial horizontal velocity due to the Earth's rotation that puts it on a curved trajectory. That initial horizontal velocity coupled with the Earth's curvature means the pen will fall for a distance slightly greater than the initial height h above the surface of the Earth. Account for that increase in the vertical distance traveled by the pen and make a simple second order assumption (the first order correction is zero) and you will get the exact same answer as above, [itex]\sqrt{2h/g}[/itex]. Just not as easily.
This is one of those occasions where working in a rotating frame is easier than an inertial one.
  • #69
Better: We can say that centrifugal forces can be used to explain the tides. Saying that they cause the tides is going a bit too far IMO.
Consider a moon the same mass as ours that is in an orthogonal orbit about some planet the same size as the Earth. (Orthogonal orbit: An orbit with a zero angular momentum. When the moon hits the planet, the impact angle will be orthogonal to the ground.) At the instant that this hypothetical moon is one lunar distance from the planet, the tidal forces exerted by this moon on that planet will be exactly the same as the tidal forces exerted by our orbiting Moon on the Earth. Explaining that this is the case is a piece of cake if you use a gravity gradient based explanation. Now try from explaining using a centrifugal force based explanation.
You most certainly could explain the tides from the perspective of an Earth-fixed frame. Explanation follows my response to harrylin's post.
That's because oceanographers are elided. (Elided because of the old mantra, If you can't say something nice don't say anything at all.)
The reason that centrifugal forces due to the Earth's rotation must be disregarded is because those forces have already been taken into account. The starting point for an Earth-fixed based explanation of the tides is the geoid. The geoid is an equipotential surface of the gravitational plus centrifugal forces. Accounting for those centrifugal force again would be a double booking.
  • #70
Hmm...what does this have to do with anything?
  • Classical Physics
  • Astronomy and Astrophysics
  • Classical Physics
  • Earth Sciences
