Could Earth Capture a SECOND Satellite the size of the Moon?
In summary: Sun, much less the temperatures of the planets.In summary, according to this article, there have been other natural satellites of the Earth in the past, and it would be possible to keep the satellite in orbit for long enough to mine or launch missions from it. However, there aren't any asteroids half as large as the moon, so that would be a big no. Another option would be to use the moon itself as a launchpad, but capturing something half the size of the moon would be beyond daunting. There are also some smaller asteroids that could be used as anchors for launching missions.
Taymith
I'm doing a research paper based on mining asteroids or near Earth objects.
I was wondering, could we pull/move a relatively large asteroid About half as large as the moon could we use is as an anchor to launch missions?
Thanks!
Astronomy news on Phys.org
Well I'm not sure if you already saw this link but
http://www.universetoday.com/92022/Earth's-other-moons/
Based on this article there have already been other natural satellites of the Earth in the past. The question is whether it would be possible to keep the satellite in orbit for long enough to mine or launch missions from it.
There are no asteroids half as large as the moon so that would be a big no.
Likes 1 person
True all the asteroids in the Asteroid Belt would not equal the size of our moon. I was taking the questions as a theoretical one.
Why couldn't you have the missions launched from out moon itself instead?
That would seem more feasible.
I think capturing something half the size of the Moon, whether by mass or by radius, is pretty close to crazy talk. Adding any sort of useful ΔV against that much inertia would be beyond daunting.
For more sensible-sized asteroids, have a look at these:
http://www.nss.org/settlement/asteroids/capture.html
http://www.kiss.caltech.edu/study/asteroid/asteroid_final_report.pdf
Also, the largest asteroid is Ceres, with less than third of the Moon's radius and 1/100th of its mass.
There are, since Pluto was demoted and branded with a number.
It was demoted to dwarf planet, not to asteroid, though.
There aren't any such objects in the solar system but there may be such objects in interstellar space with trajectories that will bring them through our solar system at some time.
@Glappkaeft: Good point.
@Mrspeedybob: Nearly 70% of the mass of the interstellar medium is made up of hydrogen atoms. The rest is mostly helium and heavier atoms, molecular clouds, and dust. Asteroids orbit the Sun, and most of them are inside the orbit of Jupiter.
Correction. Most *known* asteriods are inside the orbit of Jupiter.
Kuiper belt is quite farther out than Jupiter.
While we detected many sub-kilometer object inside the orbit of Jupiter, in KB we only detected some of the largest stuff - and already we know about six objects larger than Ceres (>1000 km in diameter). It looks like in reality, "most asteriods are outside of orbit of Neptune".
Thank you for posting important links! These are really helpful to know.
Best Regards!
You are right. :)
That doesn't make sense. If there were more *unknown* asteroids, how could you know?
nikkkom said:
Kuiper belt is quite farther out than Jupiter. It looks like in reality, "most asteriods are outside of orbit of Neptune".
That's quite the opposite of what NASA/JPL indicates and Wiki clarifies
...as minor planets in the outer Solar System were discovered, their volatile-based surfaces were found to resemble comets more closely and so were often distinguished from traditional asteroids. Thus the term asteroid has come increasingly to refer specifically to the small bodies of the inner Solar System out to the orbit of Jupiter.
Whatever the bodies outside of Neptune are called, most Kuiper belt bodies are made up of ices. Those wouldn't remain solid anywhere near Earth.
Most of them are not massive enough to melt near Earth.
When you ask, "Could Earth capture..." you have to add more about whether it is being guided with direct manipulations (meaning space tugs or whatever), or whether (at least in the final approach) it is allowed to try to insert into Earth orbit "hands off".
With enough technology, I think it could be done with direct manipulation.
But, another way of interpreting the question would be, could we manipulate the motion of a distant large object so that it naturally approaches the Earth and inserts into a stable orbit? This is similar to asking if a passing large body could enter the solar system, approach the Earth, and adopt a stable orbit.
For these later cases of the object "passively" (at least for the final approach ) inserting into a stable orbit without direct additional manipulation, I'm not so sure... especially if the body is coming from higher than the Earth's orbit around the Sun.
Imagine an object that is already in stable Earth orbit... now imagine how you would move it out of that orbit - you would have to apply an acceleration to do so. To me I think this means that the body had to decelerate in order to insert into the orbit...
What would cause a body approaching the Earth and increasing attraction with approach to decelerate other than direct manipulation?
Large satellites orbiting planets have some interesting properties when it comes to the dynamics of the system. I believe I have read somewhere (possibly even on PF) that lack of other satellites of the Earth is due to the fact Moon interferes with their orbits, effectively ejecting them into space.
IOW, it is not just a matter of putting something on the orbit, it is also a matter of keeping it in that orbit and not destroying the already existing system.
This is what I understand to be a major "problem" in having a second large satellite in the Earth system. As moons go, our Moon is quite dense and massive, and simply inserting a large satellite into the system isn't going to fly. Small objects for mining and the like seem feasible, since they could possibly be constantly manipulated to keep them in orbit, but putting, say, Ceres into orbit, not even considering the energy required to do that, seems destined for failure over the long term. The interaction between the Earth, the moon, and the smaller, yet large satellite would, I think, end up with the smaller object getting booted out.
I think we have discussed this here before. I like simulating this stuff. There are no prograde orbits around Earth exterior to the Moon that are stable. Any object put in any prograde orbit exterior to the Moon gets ejected from the system in just a few orbits. Retrograde orbits exterior to the Moon are fine. But they're not too common in the solar system. Prograde orbits interior to the Moons are stable. But the Moon was once much closer to Earth. It would have swept that area (volume?) clear as it migrated to where it is now.
I agree. Just out of curiosity, I created a simulation using the Sun, Earth, Moon, and Ceres. The only way I could keep Ceres in a stable orbit was by placing it in Earth-Moon Lagrange Points 3, 4, and 5. Everywhere else (including Earth-Moon Lagrange Points 1 and 2), Ceres either crashes into the Moon, or gets flung out of the Earth-Moon orbit.
In absolutely every case (even with Ceres in the Earth-Moon Lagrange Points 3, 4, and 5), the extra mass was sufficient to slightly slow down the Earth's velocity around the Sun (from 29.8 km/s to 29.3 km/s), causing Earth's orbit to increase slightly (1.02 AU SMA) and increasing the length of a year (adding about 8.4 hours per year).
The amount of energy required to move an object the size of Ceres would be huge. Well beyond all the energy of our combined nuclear weapons. However, once in either the Earth-Moon Lagrange Points 3, 4, or 5, no additional energy would be required to keep it in a stable orbit.
Of course an object at the first and second Lagrange points is going to be booted out of the system. Those points aren't stable. So is the third. Only the two triangular Lagrange points are stable.
That you couldn't find any stable orbits suggests that you might just be seeing an artifact of your numerical integrator rather than something real. If you are using the classical fourth order Runge-Kutta integrator, you can almost certainly blame the booting on the integrator rather than reality. The same applies for low order symplectic integrators. The large truncation errors associated with these techniques means the results are pure fiction after a few dozen orbits. A good integrator for the four body problem (the Sun is going to be a big perturber) is hard to come by.
There has been a lot of interest of late in selenocentric distant retrograde orbits (google that term). These orbits appear to be stable for hundreds of revolutions given the right evection angle (between -90 and +90 degrees, more or less). Some are very distant indeed. At a distance of 70,000 km from the Moon, these orbits are anything but elliptical when viewed from the perspective of a Moon-centered frame, and they are rather exotic when viewed from the perspective of an Earth-centered frame.
Most known planets are in our galaxy, but we know our galaxy is not unusual in that respect - other galaxies have stars with planets as well, we just don't have the technology to detect them (with a few candidates as exception).
In the same way, you can know that the Kuiper belt has many objects we did not discover so far, as our telescopes are not good enough and/or did not scan the whole sky with the same precision.
It would screw up our lives. That's all I can say.
I did not consider putting Ceres in a lunar orbit. When I place Ceres 70,000 km in a lunar orbit (30.1 km/s with an eccentricity of 0.014, or 19.1 days per orbit around the Moon), using RK4, in about 4.5 (~90 days) orbits the eccentricity of Ceres' orbit increases to 0.56 and is flung out of the Earth-Moon orbit into an orbit around the Sun. Furthermore, the eccentricity of the Moon increased, bringing the Moon almost 100,000 km closer to Earth at its semi-minor axis.
You can't use RK4 and expect anything remotely resembling reality after even one orbit. It is not a stable integrator.
The RK4 integrator I use in Gravity Simulator can hold a Ceres-mass object in the Moon's L4 or L5 indefinitely. If I input solar system data for today, and run it backwards, I can accurately postdict solar eclipses from hundreds of years ago. My predictions for future eclipses are in excellent agreement with the predictions given in Nasa's eclipse website. This is after not just one orbit, but thousands of lunar orbits, hundreds of Earth orbits, and hundreds of orbits of the other planets that perturb the system.
My original Euler-Cromer integrator can do these things too provided the time step is low enough.
Beyond hundreds of years, the postdictions start to fail, not because of integrator error, but because of forces not modeled (i.e. Earth is not a perfect sphere like I pretend it to be). Likewise, I can integrate forward and find the circumstances of Venus' next transit of the Sun, and be in excellent agreement with published values. But I can't predict the next time Io will occult Europa, as Jupiter's oblateness is significant but not modeled in the code.
I had the same experience holding a Ceres-mass object in the Moon's L4 and L5 points indefinitely. However, D. H. referred me to selenocentric distant retrograde orbits. When I place Ceres 70,000 km in a lunar orbit (30.1 km/s with an eccentricity of 0.014, or 19.1 days per orbit around the Moon), using RK4, in about 4.5 (~90 days) orbits the eccentricity of Ceres' orbit increases to 0.56 and is flung out of the Earth-Moon orbit into an orbit around the Sun. According to selenocentric distant retrograde orbits, that should not be happening. Ceres should be in a stable orbit around the moon.
I also agree that the margin for error is directly proportional to the step increment.
|Glitch| said:
...When I place Ceres 70,000 km in a lunar orbit (30.1 km/s ...
I'm probably not understand you, but 30.1 km/s is typical of a solar orbit. Lunar orbits are much slower than that, even when they're near the moon's surface, let alone 70,000 km.
I worked it out as a four-body problem, using the Sun, Earth, Moon, and Ceres. In order for the Earth to maintain a solar orbit at 1 AU with an eccentricity of 0.0167, it needs to travel at 29.8 km/s. The Moon orbits the Earth slightly faster than that, and in order for Ceres to orbit the Moon it needs to travel slightly faster than the Moon's velocity.
|Glitch| said:
...In order for the Earth to maintain a solar orbit at 1 AU with an eccentricity of 0.0167, it needs to travel at 29.8 km/s. The Moon orbits the Earth slightly faster than that...
The Moon orbits the Earth WAY slower than that. It's more like 1 km/s. Unless you're talking about the Moon's velocity with respect to the Sun. In that case, it spends about half its time orbiting the Sun up to about 1 km/s faster than the Earth, and the other half of the time orbiting the Sun up to about 1 km/s slower than than the Earth. I think you know what you're talking about, but we're just having some trouble communicating.
  • #31
I know in my previous post I'm essentially disagreeing with you when you say "You can't use RK4 and expect anything remotely resembling reality after even one orbit. It is not a stable integrator. "
But with all due respect, you helped me get my degree in Physics and Astronomy. Google "tony87004 thanks DH". I used to be an electrical contractor. Now I'm a high school physics teacher :)
  • #32
I think we are talking about the same thing. Only I am referring to the total orbital velocity, rather than the relative orbital velocity. I completely agree that the Moon only orbits the Earth at some thing just under 1 km/s. Furthermore, Ceres would orbit the Moon at less than 1 km/s as well. However, their total velocity includes Earth's velocity around the Sun since it was a four-body problem. If I worked out the simulation as just a three-body problem (Earth, Moon, and Ceres) then the Moon would have an orbital velocity around Earth of 996 m/s and Ceres would have an orbital velocity around the Moon of 860 m/s (at a distance of 70,000 km).
  • #33
There's your problem.
If you are using native floating point (specifically, double precision; if you are using floats you are completely lost) and if want any hope of capturing the dynamics you need to set up a hierarchy of reference frames. If you want to do all of your computations in a common solar system barycenter frame, you *must* use some kind of extended precision arithmetic to avoid the huge truncation error problems in your integrators that would otherwise result with using double precision numbers.
For example, it's best to represent an object orbiting the Earth using an "Earth-centered inertial" (aka ECI) frame. I put that in quotes because (a) it's not an inertial frame and (b) it is a very commonly used term. There's even a wikipedia page on Earth-centered inertial: http://en.wikipedia.org/wiki/Earth-centered_inertial.
This ECI frame is not inertial. It is an accelerating frame. The astronomical / aerospace engineering term for the fictitious forces that results from using this accelerating frame is "third body force". (Physicists would call these apparent forces "tidal forces", but that term is used to denote something else in modeling solar system dynamics.) You need to model these apparent forces or you need to use extended precision arithmetic. If you use the latter, your integration will proceed extremely slowly.
These selenocentric distant retrograde orbits (SDROs) are in the class of "exotic orbits", particularly when the orbital distance is greater than the distance to the Earth-Moon L1 point (for example, a 70,000 km orbit about the Moon). These very distant SDROs don't look anything close to elliptical when viewed from the perspective of a Moon-centered inertial frame. They look more like a square with rounded corners. They do look roughly elliptical when viewed from the perspective of an Earth-centered inertial frame, but the Earth is not at one of the foci of the ellipse.
These very distant SDROs are of increasing interest to NASA, other space agencies, and also to the (not anywhere close to ready for prime time) asteroid mining community. So we've studied them. You need a very good integrator to model the behaviors. RK4 just doesn't cut it. Things get wonky after just an orbit or so when one uses RK4 against these exotic orbits.
Thanks! I'm blushing.
Likes 1 person
1. Can Earth's gravity capture a second satellite the size of the Moon?
Yes, Earth's gravity is strong enough to capture a second satellite the size of the Moon. The Moon itself is already captured by Earth's gravity and orbits around our planet.
2. How would a second satellite affect Earth's orbit and rotation?
A second satellite the size of the Moon would have a significant impact on Earth's orbit and rotation. It would likely cause changes in the tides and potentially alter the length of Earth's day.
3. What would happen to Earth's climate if a second satellite was captured?
The effects on Earth's climate would depend on the composition and distance of the second satellite. It could potentially cause changes in the Earth's axial tilt, leading to changes in seasonal patterns and possibly affecting global temperatures.
4. Is it possible for Earth to capture a second satellite naturally?
While it is possible for Earth to capture a second satellite, it is highly unlikely to happen naturally. The gravitational pull of the Moon is already strong enough to capture any objects that come close to Earth's orbit.
5. What would be the potential benefits or drawbacks of Earth capturing a second satellite?
The potential benefits of Earth capturing a second satellite could include new opportunities for space exploration and potential resources on the satellite. However, there could also be potential drawbacks such as changes in Earth's environment and potential conflicts with existing satellites and space debris.
  • Astronomy and Astrophysics
9K
  • Aerospace Engineering
