Why Does Curved Beam Analysis Include a Negative Strain Energy Term?
In summary, Shigley's Mechanical Engineering Design includes a section on deflection of curved members which explains the concept of negative strain energy and its equation for calculating it, derived from the principle of virtual work. This term is necessary to account for the increased stiffness of curved members and improves the accuracy of strain energy calculations.
Rothlisburger
I'm teaching a class using Shigley's Mechanical Engineering Design. There is a section on deflection of curved members. If you have this text, you'll notice it calculates the strain energy in bending, axial, and shear, as usual. Then it says that there's another "negative" strain energy component, and cites an equation for this without introduction or reference. The text explaining this term is incomprehensible.
First off, since the strain energy is the integral of the strain energy density throughout the volume, and since we've accounted for all stresses (bending, axial, and shear), why should we need another term? And since when can strain energy be negative?
Any help would be most appreciated.
-David
The negative strain energy component is related to the geometric stiffness of the curved member. Curved members are inherently more stiff than straight members due to their curved shape, and this increased stiffness can be accounted for in the strain energy calculations by using a negative strain energy term. The equation used to calculate this term is derived from the principle of virtual work, which states that the work done on a system can be calculated as the integral of the force multiplied by the virtual displacement. The negative strain energy term is then the integral of the moment of inertia multiplied by the virtual curvature over the entire length of the member. This additional term accounts for the increased stiffness of the curved member, and thus improves the accuracy of the strain energy calculation.
1. What is deflection of curved beams?
Deflection of curved beams is the amount of bending or displacement that occurs in a curved beam when a load is applied to it. It is a measure of the beam's flexibility and can impact the overall strength and stability of a structure.
2. How is deflection calculated for curved beams?
Deflection of curved beams can be calculated using various mathematical formulas and equations, depending on the type of beam and the load applied. These calculations take into account factors such as the beam's curvature, material properties, and applied load.
3. What are some common factors that affect the deflection of curved beams?
The deflection of curved beams can be influenced by several factors, including the beam's shape, size, material properties, applied load, and support conditions. The type and magnitude of the load, as well as the beam's curvature, can also play a significant role in determining the amount of deflection.
4. How does the deflection of curved beams compare to that of straight beams?
In general, curved beams tend to have a higher deflection compared to straight beams of the same material and dimensions. This is because the curvature of the beam causes the applied load to be distributed differently, resulting in a greater amount of bending and deflection.
5. How is deflection of curved beams used in engineering and design?
The deflection of curved beams is an important consideration in engineering and design, as it can affect the structural integrity and performance of a building or structure. By accurately calculating and predicting deflection, engineers can ensure that a structure is strong and stable enough to withstand expected loads and conditions.
  • Mechanical Engineering
34K
36K
18K
  • Quantum Physics
  • General Math
9K
