Cannon at rest shot on frozen pond. what is cannon balls v after cannon recoil?
In summary, shooting a cannon at rest on a frozen pond is done to study the effects of recoil and cannonball velocity on the frozen surface. The recoil can cause vibrations and potential cracks in the ice, and the velocity depends on various factors. The frozen pond can affect the cannonball's trajectory by providing a smooth surface, but the thickness and condition of the ice can also impact it. Safety precautions, such as checking ice thickness and using protective gear, should always be taken when conducting this experiment.
IDKPhysics101
31
A 253.5 kg cannon rests on a frozen pond. The cannon is loaded with a 6.8 kg cannon ball and is fired horizontally. If the cannon recoils to the right with a velocity of 6.9 m/sec , then what is the velocity (in m/s) of the cannonball just after it leaves the cannon?
Also would like a hint to start it! thanks
momentum is conserved
momentum is mass * velocity
253.5*6.9=1749.15/6.8=-257.22
i think the answer should be negative or so I am told?
1. What is the purpose of shooting a cannon at rest on a frozen pond?
The purpose of shooting a cannon at rest on a frozen pond is to study the effects of the recoil of the cannon and the velocity of the cannonball on the frozen surface.
2. How does the recoil of the cannon affect the frozen pond?
The recoil of the cannon can cause vibrations on the frozen pond's surface, potentially causing cracks or fractures in the ice. This can also lead to changes in the ice's structure and thickness.
3. What is the velocity of the cannonball after the cannon recoil?
The velocity of the cannonball after the recoil will depend on various factors such as the weight and size of the cannonball, the force of the recoil, and the friction between the cannonball and the frozen surface. It is difficult to determine an exact velocity without conducting experiments.
4. How does the frozen pond affect the trajectory of the cannonball?
The frozen pond can affect the trajectory of the cannonball by providing a smooth surface for the cannonball to travel on. The ice can also cause the cannonball to slide or bounce, altering its path. The thickness and condition of the ice can also impact the trajectory.
5. What safety precautions should be taken when shooting a cannon at rest on a frozen pond?
Safety should always be a top priority when conducting any scientific experiment. When shooting a cannon at rest on a frozen pond, it is important to ensure that the ice is thick enough to support the weight of the cannon and the recoil. Safety equipment, such as protective gear and barriers, should also be used to prevent any accidents. It is also crucial to have a trained professional supervise the experiment.
