Finding Pressure with constant temperature and varying volume
In summary, the problem is ambiguous and could have different solutions depending on the assumed process for the compression of the gas. Assuming an isothermal process, the new pressure of the gas would be 533.33 kPa. However, if the process is different (such as adiabatic or isobaric), the answer may be different.
joe465
94
A 3-litre vessel contains gas at a pressure of 200 kPa. Five litres of gas at the same pressure is forced into the vessel. Calculate the new pressure of the gas.
P1V1 = P2V2
P1V1 = P2V2 (Keeping Temp = Constant)
V2 = 3 + 5 = 8 litres
3 * 200 = P2 * 8
P2 = 600/8 = 75 kPa
I have been told this answer is wrong but unsure why if anyone could help me out, would greatly appreciate it.
Thanks, Joe
P1V1 = P2V2
Just to be sure, you are working with an ideal gas right?
Are you sure that's the final volume, V2? It sounds to me from the problems statement that 8 liters is the initial volume, V1. (Although this volume is split into two separate containers, one 3 liter container and another 5 liter container.)
3 * 200 = P2 * 8
P2 = 600/8 = 75 kPa
If more gas is being forced into the 3 liter container (while keeping temperature the same), you would think the pressure in that container would increase, not decrease, right?
Thanks for your reply, well the question has been copied word for word and just says gas so i presume it would be right to assume its an ideal gas.
So you suggest V1 would be 8L and the 5L is forced into the 3L section making V2 3L therefore making the pressure rise.
V2 = 8 - 5 = 3 litres
8 * 200 = P2 * 3
P2 = 1600/3 = 533.33 kPa
That looks like a more realistic outcome, what do you think?
8 * 200 = P2 * 3
'Looks good to me. :approve: (This is assuming the temperature is kept constant.)
Thankyou very much, it literally only states what it does in the question and doesn't suggest temperature change.
Would the question emply or give a temperature if this was required?
Thanks, Joe
PV=nRT.
Process 1, adding gas at fixed pressure, n changes, V changes, T stays same.
Process 2, with new V, we compress it to old V. Thus in PV=nRT, the pressure and temp are ambiguous. We must compress it in a certain way.
A temp bath would keep the temp constant. A thermos would stop heat exchange (not the same as temp bath). A free piston on top would keep pressure the same.
The problem is ambiguous since it doesn't tell us which process to use for process 2.
That is, either isothermic, adiabatic or isobaric.
Thanks, Joe
If it explicitly states in the question (such as in the title of this thread) that the temperature remains constant, or if it states that the process is isothermal, then your answer is fine. :smile:
Even if it doesn't state anything about temperature, then I'm still guessing that your answer is fine, and the process is assumed to be isothermal.
On the other hand, if the process is adiabatic, then things get a little more complicated. But I doubt this is the case, since the problem statement never mentioned whether the gas was monatomic, diatomic, or whatnot. If your coursework hasn't discussed this stuff (yet), I'd assume that the temperature stays constant, and your answer is correct.
1. What is the relationship between pressure, temperature, and volume?
The relationship between pressure, temperature, and volume is described by the ideal gas law, which states that the pressure of a gas is directly proportional to its temperature and inversely proportional to its volume when other factors, such as the number of gas molecules, remain constant.
2. How can I calculate the pressure of a gas when the temperature is constant and the volume is changing?
You can use the combined gas law, which combines the relationships between pressure, temperature, and volume from Boyle's Law, Charles's Law, and Gay-Lussac's Law. The formula is P1V1/T1 = P2V2/T2, where P is pressure, V is volume, and T is temperature. Simply plug in the values for two sets of conditions and solve for the unknown pressure.
3. Why does pressure increase when volume decreases at a constant temperature?
This phenomenon is known as Boyle's Law, which states that when the temperature of a gas is held constant, the volume and pressure of the gas are inversely proportional. This means that as the volume decreases, the gas molecules are more closely packed together, resulting in a higher pressure.
4. Can pressure be calculated if the temperature and volume are both changing?
Yes, as long as the number of gas molecules remains constant, you can use the ideal gas law to calculate the pressure. The formula is PV = nRT, where P is pressure, V is volume, n is the number of moles of gas, R is the gas constant, and T is the temperature in Kelvin.
5. How does the pressure of a gas change with temperature at a constant volume?
According to Gay-Lussac's Law, when the volume of a gas is held constant, the pressure and temperature are directly proportional. This means that as the temperature increases, the pressure of the gas also increases. This relationship is only valid if the number of gas molecules remains constant.
