Help: Two frictionless pucks are placed on a level surface
In summary, Jaime calculated that the block of mass closest to the ground was 5 meters away when the spring was stretched by 1 meter.
Jaimie
35
"Two frictionless pucks are placed on a level surface at an initial distance of 20.0 m. The mass of puck 1 is 0.80 kg and it has a charge of +3.0 X 10^-4 C., while puck 2 is 0.40 kg with a charge of +3.0 X 10^-4 C. the initial velocity of puck 1 is 12.0 m/s (E) and the initial velocity of puck 2 is 8.0 m/s (W). Find the minimum separation of the two pucks."
Pti= Ptf
Etki= Etkf+ Ee
(I dropped the units just so reads easier)
m1v1+m2(-v2)=(m1+m2)vf
vf=(0.80)(12)+(0.40)(-8)/0.80+0.40
vf=5.33 m/s
Ek1+Ek2=Ee+Ekf
1/2m1v1^2 + 1/2m2(-v2^2) = kq^2/r + 1/2(m1+m2)(v')^2
1/2(0.80)(12)^2 + 1/2(0.40)(-8.0)^2 = 1/2(0.80+0.40)(5.33)^2+(9.0X10^9)(+3.0X10^-4)^2/r
Isolate for r
r= 1/2(0.40)(-8.0)^2= 15.2 m= 15m
Can someone advise if this is correct? I am unsure about this answer as it isn't that different from the original distance. In a similar example (as per homework manual), it is taking the initial electric potential energy as negligible. Is this right?
Hello, Jaime.
Is there a reason that you didn't make use of the initial distance of 20 m in your energy calculation?
I think that I am having trouble understanding how the conservation of energy is applied to the moving charges.
From what I am now understanding is that the conservation of energy equation, when applied to these problems should be...Etki + Eei= Etkf+ Eef. Is this right?
In this case, I am to interpret that because they are at a set distance apart (not very far distance apart), there is electric potential energy initially so I need to factor in the initial distance with the Ee equation. So...
1/2m1v1^2 + 1/2m2(-v2^2) + kq1q2/ri = 1/2Vf^2(m1+m2) + kq1q2/rf
1/2(0.80)(12)^2 + 1/2(0.40)(-8.0)^2 + ((9.0X10^9)(+3.0X10^-4)^2))/20= 1/2(0.80+0.40)(5.33)^2 (9.0X10^9)(+3.0X10^-4)^2/r
r= 810/93.86= 8.63m= 8.6m
Can you also give some advice on how you approach these problems? Very frustrating as I don't feel like I am "getting this" quickly. I'm having trouble sorting out how to approach a problem like this and when to use cons. of energy eq. or cons. of momentum eq. Thank you!
Similar type of problem, but using something that you might know a little better:
I have a spring with spring constant k, and I put a block of mass m ontop (the spring is attached to the ground at one end and oriented vertically) I stretch the spring by pulling the block upwards 1 meter. What's the closest the block gets to the ground?
If you can solve this you should be able to solve the original problem. =]
I guess i should give the spring a length =/
5m haha
You have to think about whether there's any work lost or gained (internal friction, external forces, impacts) and whether momentum, angular momentum could change (external forces and torques).
For momentum, you may be able to find a particular direction in which it will be conserved, because the only external force is orthogonal to that. Similarly, you may be able to find a reference point about which angular momentum is conserved, because the only external forces act through that point.
Whichever conservation laws pass this test can be used. Which are the most useful for a particular question is another matter, but most questions are set such that you need to use all conservation laws that apply.
Thanks everyone!
1. What is friction and how does it affect the movement of objects?
Friction is a force that opposes the motion of an object. It is caused by the interaction of two surfaces and can slow down or stop the movement of objects.
2. Why are the pucks in this scenario considered "frictionless"?
The pucks in this scenario are considered "frictionless" because they are placed on a level surface with no roughness or irregularities that would create friction.
3. What factors can influence the movement of the pucks in this scenario?
The movement of the pucks in this scenario can be influenced by several factors including the initial force applied, the mass of the pucks, and any external forces acting on the pucks.
4. What happens to the pucks if they collide with each other?
If the pucks collide, they will transfer momentum and change direction based on the laws of conservation of momentum. In a frictionless scenario, the pucks will continue to move without slowing down or stopping.
5. What is the significance of studying frictionless scenarios in physics?
Studying frictionless scenarios allows scientists to isolate and better understand the effects of other forces, such as gravity and inertia, on the movement of objects. It also helps to simplify complex systems and make accurate predictions about their behavior.
