Is Electricity Generated when a Magnet Falls Through a Copper Pipe?
In summary, the conversation discusses the production of ohmic currents and their effect on the speed of a falling magnet in a copper pipe. The amount of current produced is proportional to the size of the pipe and strength of the magnet to a certain extent, but conservation of energy must also be considered. Eddy currents are also mentioned as a result of the moving magnetic field.
Yoann
The title is pretty self-explanatory. I know the speed of the falling magnet is much slower in a copper pipe, but since the magnetic field moves, is there still some electricity generated in the process, even though the speed isn't great?
Thanks!
The fact that current is produced is the reason that the magnet falls slower. the current produced by the moving magnetic field produces its own magnetic field that inhibits the motion of the falling magnet.
Great, thanks for the replies. And Rooted, awesome document you have there!
So is the amount of current produced proportional to the size of the pipe and strength of the magnet? I'm guessing yes, right? Like if we plugged light bulbs to the copper pipe, the bigger the pipe and stronger the magnet, the more light bulbs would go on?
To a point. You have to remember conservation of energy. If you drop a magnet through the tube under the influence of gravity the magnet starts with a given amount of gravitational potential energy. The stronger the magnet and the more conductive the tube the more energy will be converted into electricity and the less will be converted into kinetic energy and lost to friction.
Likes Undacuva
Ok I get it now. Thanks for the reply!
Eddy Currents!
1. How does a magnet falling through a copper pipe generate electricity?
When a magnet falls through a copper pipe, it creates a changing magnetic field. This changing magnetic field induces a current in the copper pipe, which then generates electricity.
2. What is the principle behind the generation of electricity from a magnet and copper pipe?
The principle behind this phenomenon is electromagnetic induction. This refers to the production of an electric current in a conductor when it is exposed to a changing magnetic field.
3. Why does the copper pipe need to be conductive for electricity to be generated?
Copper is a highly conductive material, meaning it allows electricity to flow through it easily. When the changing magnetic field induces a current in the copper pipe, this current can then flow through the pipe and be harnessed as electricity.
4. How does the speed of the falling magnet affect the amount of electricity generated?
The speed of the falling magnet does not have a significant impact on the amount of electricity generated. As long as the magnet is falling through the copper pipe at a consistent speed, the same amount of electricity will be produced.
5. Can this phenomenon be used to generate a significant amount of electricity for practical purposes?
The amount of electricity generated by a falling magnet through a copper pipe is relatively small and not practical for large-scale electricity production. However, this concept is utilized in some power generation systems, such as hydroelectric generators, where the movement of water through a copper pipe produces electricity through the same principle of electromagnetic induction.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
12K
