Exploring Relativistic Mass with pmb_phy: A Conversation on Its Relevance
  • Thread starter Aer
In summary, Pervect does not believe there is one thread that can convincingly argue for the usefulness of relativistic mass. He spent 7 years studying the subject and believes that the term "relativistic mass" refers to the mass that possesses the inertial, passive gravitational, and active gravitational mass. He also argues that the definition of mass should be discussed without referring to outside sources, as seen in his disagreement with pmb_phy's paper. He quotes Einstein's belief that it is better to stick to the concept of "rest mass" rather than introduce the concept of mass for a moving body. He also acknowledges the different viewpoints on the concept of mass, but believes that the proper length and contracted length are defined through the Lorent
  • #71
Aer said:
We clearly do not define mass to be the same thing, you say mass is M = ? * m.
NO I DON'T! I've said over and over again that this issue of inertia can be phrased solely in terms of energy.
Aer said:
I claim mass is m, not M. M is relativistic mass and is mentioned nowhere in any of my physics textbooks, why is that?
Because most physicists prefer not to use the concept of relativistic mass (not because it's 'wrong'--any statement involving relativistic mass has an equivalent in terms of rest mass, momentum, energy, etc.--but just because it can be misleading). What does this aesthetic choice have to do with the physical question of whether inertia is proportional to total energy or not? Once again, are you or are you not disagreeing with the assertion that the theory of relativity says the inertia of a compound object is proportional to its total energy?
Aer said:
They lost energy in binding together - i.e. binding energy, that is no surprise.
So you agree the binding energy contributes to the inertial mass of the reactants, that their inertial mass is not solely the sum of the rest masses of all the particles involved?
  • #72
I didn't mean I'm surprised you're claiming relativistic mass is a useless concept. I meant I'm surprised that such a claim has sparked such a long debate with no clear winner. Why hasn't anybody addressed it in the context of general relativity yet? (Atleast not in the posts I've read; I admit I haven't read them all.) Shouldn't whatever general relativity states is the mass (relativistic or invariant) that decides a body's weight be the deciding factor? Or could that be interpreted in multiple ways too? I suppose it could, so the deciding factor really seems to be if there is another explanation for why we can't accelerate particles faster than the speed of light in our own reference frame and whether there is a clear relationship between inertia and inertial mass.
Actually, there is. Inertial mass is caused by a body's resistance to acceleration, so if increase in speed = increase in inertia = increase in inertial mass = increase in gravitational mass = increase in weight is correct, which it seems to be to me from the reasoning I outlined earlier, then relativistic mass would seem to atleast be related to inertial mass, if not equivalent. :confused:
  • #73
I provided you a link that stated otherwise - that is, the assertion you are making above is incorrect.
Where do you think binding energy comes from? It comes from the particles rest masses, not any type of kinetic or potential energy! That is fundamental.
After the objects bind, this binding energy is forever lost and thus the inertial mass of the new object is less than the combined inertial masses of the two objects before binding. Again - nothing to do with kinetic and potential energy increasing an objects inertia.
I never thought I'd have to remember concepts learned in chemistry class on a relativity forum.
  • #74
As an object is accelerating within Earth's gravitational field, if it approaches .9c, it will still accelerate all the same with the same amount of force in its own frame. (i.e. relativistic mass does not equal gravitational mass) and inertial mass = rest mass
  • #75
The link you provided was ambiguous, and I provided four links to back up what I'm saying. And as I said, I emailed the author of the page you referred to, if he ends up supporting my position will that change your mind in any way?
Huh? The binding energy is the energy it takes to pull the atoms apart, and the atoms are held together by electromagnetic forces. So, the binding energy is just the difference between the electromagnetic potential when the atoms are in the bound state vs. the electromagnetic potential when they are moved arbitrarily far apart (the system naturally stays bound because the potential energy is lower, although in some cases there may be a 'hump' in the potential where the potential becomes higher when you start to move them apart but then goes lower when they're even farther apart, so some molecules can release energy when broken apart, as described on http://www.2ndlaw.com/obstructions.html ).
  • #76
I did not find it ambiguous, what part of, -mass is frame independent- is unclear. Or did you just choose to ignore that?
Ahh yes, you can tell I am not a Chem person. This is true - I stated it backwards. Anyway, the binding energy still comes from the rest mass of the object that is being split. My argument was still correct in substance. :biggrin:
  • #77
Like I said, there was also the issue of whether he was talking about a compound object where all the parts were at rest with regard to each other. Again, if he ends up supporting my position will this change your mind at all? I want a commitment in advance on this! :wink:
No, as I said it comes from the difference in potential energy between the bound state and the unbound state. The sum of the rest masses of the particles doesn't change when you split them apart.
  • #78
Why would I make up an opinion based only on some random person's opinion? Only experimental proof will change my mind - find that.
That is part of the rest mass, is it not?
  • #79
From wikipedia:
Some books follow this up by stating that "mass and energy are equivalent", but this is somewhat misleading. The mass of an object, as we have defined it, is a quantity intrinsic to the object, and independent of our current frame of reference. The energy E, on the other hand, varies with the frame of reference; if the frame is moving at a high velocity relative to the object, E will be very large, simply because the object has a lot of kinetic energy in that frame. Thus, E = mc2 is not a "good" relativistic statement; it is true only in the rest frame of the object.
So doesn't this mean either the above is incorrect or "mass of a compound object is a measure of its total energy" is incorrect.
  • #80
From wikipedia:
Because a bound system is at a lower energy level, its mass must be less than its unbound constituents. Nuclear binding energy can be computed from the difference in mass of a nucleus, and the sum of the mass of the neutrons and protons that make up the nucleus. Once this mass difference (also called the mass defect) is known, Einstein's formula (E = mc²) can then be used to compute the binding energy of any nucleus.
  • #81
Shifting the goalposts again. As I've said over and over, I am only asking about what the theory of relativity predicts. Surely the opinion of professional physicists should have some influence on whether you accept my claim that the theory predicts inertia is proportional to total energy, no? If all the physicists in the world claimed that the theory does predict this, would you still somehow argue that they are all wrong about what the theory "really" predicts?
Uh, no, potential energy is not part of the rest mass, since I just told you the sum of rest masses doesn't change when you change the potential.
Of course, I agree 100% with this. What's your point?
Because a bound system is at a lower energy level, its mass must be less than its unbound constituents. Nuclear binding energy can be computed from the difference in mass of a nucleus, and the sum of the mass of the neutrons and protons that make up the nucleus. Once this mass difference (also called the mass defect) is known, Einstein's formula (E = mc^2) can then be used to compute the binding energy of any nucleus.
Here I think they are talking about inertial mass (or gravitational mass, which would be the same), not rest mass (or you could say they are talking about the rest mass of the nucleus, but with the understanding that the 'rest mass' of a compound system is defined as its total energy divided by c^2).
  • #82
JesseM said:
Here I think they are talking about inertial mass (or gravitational mass, which would be the same), not rest mass.
Inertial mass IS rest mass
Even when you are shown to be wrong, you still claim you are right!
What other mass would they be referring to? Mass only has one definition in the equation E = mc^2 and that is inertial mass.
Here, maybe numbers will help you:
A deuteron is the nucleus of a deuterium atom, and consists of one proton and one neutron. The masses of the constituents are:
mproton = 1.007276 u (u is Atomic mass unit)
mneutron= 1.008665 u
mproton + mneutron = 1.007276 + 1.008665 = 2.015941 u
The mass of the deuteron is:
Atomic mass 2H = 2.013553 u
And if rest mass is not inertial mass, then which of the following is it?
Strictly speaking, there are three different quantities called mass:
* Inertial mass is a measure of an object's inertia: its resistance to changing its state of motion when a force is applied. An object with small inertial mass changes its motion more readily, and an object with large inertial mass does so less readily.
* Passive gravitational mass is a measure of the strength of an object's interaction with the gravitational field. Within the same gravitational field, an object with a smaller passive gravitational mass experiences a smaller force than an object with a larger passive gravitational mass. (This force is called the weight of the object. In informal usage, the word "weight" is often used synonymously with "mass", because the strength of the gravitational field is roughly constant everywhere on the surface of the Earth. In physics, the two terms are distinct: an object will have a larger weight if it is placed in a stronger gravitational field, but its passive gravitational mass remains unchanged.)
* Active gravitational mass is a measure of the strength of the gravitational field due to a particular object. For example, the gravitational field that one experiences on the Moon is weaker than that of the Earth because the Moon has less active gravitational mass.
  • #83
For a compound system, this is only true if you define its total "rest mass" as its total energy divided by c^2. This is how physicists define things, but if you choose to make up your own idiosyncratic definition where the compound system's rest mass is just the sum of the rest mass of its parts, then inertial mass and rest mass will not be the same. And of course, if you do this, you'll be hard-pressed to explain why the reactants in a chemical reaction have a different inertial mass than the products, even though all the constituent particles are the same (as far as I know massive particles like protons, electrons and neutrons are not created or destroyed in chemical reactions--photons may be, but they have zero rest mass).
That source doesn't "show" that inertial mass IS rest mass, it doesn't address the issue at all--you are just making an assumption.
  • #84
Aer said:
From wikipedia:
Yes... this precisely shows that the rest mass of the nucleus is not simply the sum of the rest masses of the constituent particles. You need to take into account the energy content.
Nuclear binding energy is just one form of energy that leads to mass... it is by no means the only one.
A hydrogen atom weighs slightly less than the sum of the masses of a proton and electron. The difference in mass is due to kinetic energy, and electrostatic potential energy between the electron and proton.
  • #85
No, the m in that equation is rest mass.
What's your point? I am sure they are defining the mass of the deuteron as its total energy divided by c^2. If they were just defining its mass as the sum of the rest masses of all the particles, then why do you think its mass is not 2.015941 u, assuming you acknowledge that "binding energy" does not involve any extra particles with nonzero rest mass?
This is from the wikipedia entry on mass, and they say in the section on relativity that "the quantity m has a simple physical meaning: it is the inertial mass of the object as measured in its rest frame, the frame of reference in which its velocity is zero." This definition implies that the inertial mass of the object when measured in a frame other than its rest frame will not be equal to the "m" in E=mc^2 (ie the rest mass)--and of course this is true, objects with large velocities are harder to accelerate than objects that have the same rest mass but smaller velocities, which by definition means they have different inertial masses.
  • #86
Actually, isn't the m in [tex]E=mc^2[/tex] relativistic mass (if applied to other reference frames)? I thought the invariant mass version of the equation was [tex]E^2=p^2c^2+m^2c^4[/tex].
  • #87
It takes energy to bind the proton and neutron together, no?
  • #88
From this page
The rest mass (m) of a particle is the mass defined by the energy of the isolated (free) particle at rest, divided by c 2 . When particle physicists use the word ``mass,'' they always mean the ``rest mass'' (m) of the object in question
  • #89
Yup, and of course this fits with my claim that the inertial mass of the deuteron is equal to its total energy divided by c^2, but it doesn't fit too well with your claim that its inertial mass is dependent only on the sum of the rest masses of its parts, and not on any other forms of energy that may be in the deuteron.
  • #90
From this page
the energy that holds a nucleus together; the difference between the sum of the masses of the individual nucleons and the actual mass of the nucleus.
So is the energy not a part of the combined system?
Sorry that I have to keep referring to authority - Chemistry is not my strong point.
  • #91
Aer said:
From this page
Yes, that's exactly what I just said, m is used to mean rest mass (although again, for a compound object the rest mass is defined to be the inertial mass in the compound object's rest frame, which is equal to its total energy divided by c^2 in that frame).
  • #92
Why isn't this binding energy apart of the rest mass of the system? (I think your answer is rest mass is different from inertial mass - then what is the difference, explicitly)
  • #93
But by that definition, you have to separate each particle separately and measure it's -rest mass-
What part of isolated particle is not clear?
  • #94
Aer said:
From this page
Of course it's part of the combined system, but the energy doesn't have any rest mass of its own. So this contradicts your claim that the rest mass of the combined system is just the sum of the rest masses of its parts, and supports my claim that the rest mass of the combined system is the total energy of the system divided by c^2.
  • #95
It doesn't support your claim! BTW - I never made any claim regarding combining masses in chemistry!
If it supported your claim, then the mass of the deutron should be LARGER than the mass of the proton and neutron combined. Because it not only contains your proton and neutron, but also binding energy - which adds to the total energy.
  • #96
It is! But that's assuming you use my definition that the "rest mass" of a composite system is the total energy in the system's rest frame divided by c^2. If you want to define the rest mass of a composite system as just the sum of the rest masses of each of its parts, then instead of looking at each components energy/c^2 from the point of view of the combined system's rest frame, you have to consider each part's energy/c^2 in that part's own rest frame (ie each part's rest mass), ignoring the rest of the system. But what is the rest mass of the binding energy on its own, ignoring all the particles? That doesn't seem to make any sense, binding energy is just a difference in potential energies, how can a difference in potential energies have a rest frame?
  • #97
It's your definition that the rest mass of a compound system is the sum of the rest mass of it's parts, which means you have to measure each part's rest mass separately. My definition is that the compound system's rest mass is the total energy divided by c^2, and I claim that the theory of relativity predicts this is equal to its inertial mass, which you can measure just by looking at the system's resistance to acceleration in its own rest frame.
  • #98
I only said this about adding together particles that were separated but contained (as in a box), NOT regarding binding particles together - which LOSE mass.
  • #99
Doesn't fit too well with your binding energy argument.
  • #100
Which goes back to what I said, the binding energy comes from the proton and neutron's rest mass but is still apart of the system.
  • #101
No, the potential energy is greater when you pull the proton and neutron apart than when they are bound together--that's why they naturally tend to stick together! As it says in the wikipedia entry on binding energy, "A bound system has a lower potential energy than its constituent parts; this is what keeps the system together; it corresponds to a positive binding energy." In other words, binding energy is defined in a funny way, so that more positive binding energy is equivalent to less potential energy, and it's potential energy that you must use when calculating the total energy of different states.
  • #102
I looked up the definition of binding energy, got:
"the energy that holds a nucleus together; the difference between the sum of the masses of the individual nucleons and the actual mass of the nucleus."
is this definition wrong?
  • #103
Is the binding energy apart of the deutron or not?
  • #104
It's not wrong, but it could be misleading if you interpreted it to mean that there was some form of energy that increased in the bound state rather than decreased. It is the decrease in potential energy that holds a bound system together, and the fact that you have to climb a potential hill to separate the parts that makes it difficult to do so--do you disagree with this?
  • #105
All this says is that the proton and neutron lose rest mass when they are bound together. This rest mass is referred to as the potential energy since all mass is essentially a form of energy. But this doesn't imply that kinetic energy or gravitational potential energy will become the potential energy that is considered mass. At least, there is nothing to assume that. What is needed is experimental evidence, not this endlessly pointless discussion.
