Each planet's angle from it's argument of perihelion
In summary, the conversation is about finding a chart for each planet that displays their angle from their argument of perihelion at a specific time on Earth. The speaker is not looking for an ephemeris and needs the angle along the elliptical path or the true anomaly. They have checked the charts provided by JPL but they do not include the argument of perihelion. However, they do have the longitude of the ascending node and the longitude of the perihelion, and there is an equation for calculating the argument of perihelion using these values. The speaker is wondering if there is a simpler formula for this calculation.
Philosophaie
462
I am looking for a chart for each planet. This chart must contain each planet's angle from it's argument of perihelion for a particular time on Earth time. I am not looking for an ephemeris, I don't think. I need the angle along the eliptical path of the planet or the true anomaly.
Astronomy news on Phys.org
These JPL charts doen't give the Argument of Perihelion(PA). The charts do give Longitude of the Ascending Node(LAN) and the Longitude of the Perihelion(LP). The equation for this is:
PA=LP-LAN
These are 3D compound angles. Is there an easy formula to calculate this?
1. What is the argument of perihelion for a planet?
The argument of perihelion is the angle between a planet's orbit and the point at which it is closest to the sun, known as perihelion. It is measured in degrees and is an important parameter for understanding a planet's orbit.
2. How is the angle of perihelion different for each planet?
The angle of perihelion for each planet varies depending on its orbital characteristics and position within the solar system. For example, Mercury has an angle of perihelion of 29 degrees, while Neptune's angle is 131 degrees.
3. How does the angle of perihelion affect a planet's orbit?
The angle of perihelion can affect a planet's orbit in several ways. It can influence the planet's distance from the sun at different points along its orbit, as well as the shape of its orbit. It can also affect the planet's seasonal variations and its potential for axial tilt.
4. Can the angle of perihelion change over time?
Yes, the angle of perihelion can change over time due to various factors such as gravitational interactions with other planets or objects in the solar system. These changes can be small and gradual or more significant depending on the planet's orbit.
5. How is the angle of perihelion calculated for a planet?
The angle of perihelion is calculated using mathematical equations that take into account the planet's orbital elements, including its eccentricity, inclination, and longitude of the ascending node. These calculations allow scientists to determine the precise angle of perihelion for a given planet at any point in its orbit.
  • Astronomy and Astrophysics
