2 Masses on a spring and a rocket with changing mass and air resistance
In summary, the conversation discusses a problem involving two masses connected by a spring on a smooth horizontal table. The problem seeks to find the speed of the center of mass, the speed of one mass relative to the table at a specific moment, and the period of oscillatory motion. The attempt at a solution includes using conservation of momentum and deriving a differential equation for the motion of a rocket experiencing linear air resistance.
Gaderath
Two mass m1 and m2, connected by a massless spring of force constant k, are at rest in equilibrium on a smooth horizontal table. A velocity of magnitude v and direction away from m2 is imparted to m1.
a.) Find the speed of the center of mass.
b.) Determine the speed of m2 relative to the table at the instant the spring again becomes unstretched.
c.) Find the period of the oscillatory motion.
Vcm = (m1*v1 + m2*v2)/(m1 + m2)
v1= v1cm +Vcm and likewise for v2
v2 = Vcm -m1v12/(m1+m2)
v12 = velocity of 1 with respect to 2 in my notation here ^^
Vcm = velocity of the center of mass in the lab frame
v1cm = velocity of mass 1 in the center of mass reference frame
a.) This one I got, Vcm = m1*V/(m1+m2)
It follows from Vcm's definition above, and the conservation of momentum law for the system (m1V = m1*v1 +m2*v2) and subbing that into the numerator of the definition of Vcm.
b.) This is where I'm really stuck. After I derived v2 = Vcm - m1v12/(m1+m2), which I'm confident in, I got hung up trying to figure out the velocity of 1 with respect to 2. In the CM reference frame the total momentum of the system is 0, and so using conservation of momentum m1*v1cm = -m2*v2cm. Sorry I don't know how to do subscripts here by the way, I know that notation has got to look confusing. I've more or less been running in circles since I got this far. I thought there had got to be something I could assert from the physics and the actual motion of the system to come up w/ the velocity of 1 with respect to 2 and use "v2 = Vcm -m1v12/(m1+m2)" above with my result from a.) to get it. But as I thought about it I don't think I CAN do that, as the velocity of the 2 masses wouldn't be some constant thing based on what little info I'm given at the start.
c.) I haven't looked at this one too much, but I don't know how much trouble I'll have when I get to it after b.), so any tips/advice would be great, but I don't know how much I need it (yet anyway... :) ) I expect it to be fairly normal result from a simpler problem, but with the mass being the reduced mass, m1*m2/(m1+m2), but that's just my gut, I don't know if that's true or how to prove it yet.
So far I've taken "unstretched" to mean neither compressed or stretched, rather that completely compressed, which might actually have made the problem simpler...
A rocket traveling through the atmosphere experiences a linear air resistance -kv. Find the differential equation of motion when all the other external forces are negligible. Integrate the equation and show that if the rocket starts from rest, the final speed is given by v = V*(alpha)*(1-(m/m0)^(1/(alpha))) where V is the relative speed of the exhaust fuel, alpha = absolute value( (1/k)*(dm/dt) = constant, and m0 is the initial mass of the rocket plus fuel, m being the final mass of the rocket.
Not many, dp/dt = net external forces is the only one I really use (maybe I should be using others?)
I started w/ dp = f*dt, where f is the external force(s). I integrated the momentum from time t to time t+dt, and got (M-absolutevalue(dM))(v+dv)+Vcm*absolutevalue(dM)-Mv
where Vcm = -V+v. I worked this down to:
f = M*dv/dt - V|dM/dt|, with the last term being the rockets thrust. The || is the absolute value again :), seemed like a better way to write it...
f here is again the net external force, which in this problem will be -kv. Knowing the mass is being lost, the sign on dM/dt is negative, so for the next step I dropped the || and added a - in front.
-V*dM/dt = M*dv/dt + kv.
I believe this is the differential equation the question asks for, however, as to integrating it... what in the world?! I really don't know much about solving differential equations, the only examples in class we've had have been separation of variables (he did a similar problem, but with no external forces where separation of variables worked really nicely). Here separation of variables does NOT work, and dividing through by M puts an M on the kv term, and dividing by v puts a v on the M terms. Theres no way *to* separate them as I see it. I also don't understand how I'm supposed to differentiate it and somehow still have a dm/dt term in the final answer (in alpha). I'm ok with there being an m and m0 in it, as I suspect it's from, the limits of the integration being m0 and m, and probably in a natural log function, so the subtraction can be written in the answer as a division like it is. But I don't know if that's the case here, as so much of this part is confusing me. The fact that he tells us in the problem that alpha = |(1/k)(dm/dt)| and that its CONSTANT seems like a huge hint to me. The rate of change of the mass is constant then, but the mass still isn't and so that doesn't help w/ the unseparability of the equation.
Heh, this assignments pretty long, and I've felt so good everytime I've finished one of the problems, lol, but it doesn't last when I get so stonewalled on these 2. I've talked to about 8 others in the class (of roughly 20 people) and they've all been just as clueless and on these same parts (or earlier)...
Nevermind, I've gotten them now...
1. How does the mass of the two masses on a spring affect the motion?
The mass of the two masses on a spring affects the period and frequency of the oscillation. A greater mass will result in a longer period and a lower frequency, while a smaller mass will result in a shorter period and a higher frequency.
2. What is the relationship between the mass of the rocket and its acceleration with air resistance?
The mass of the rocket has an inverse relationship with its acceleration when air resistance is present. This means that as the mass of the rocket increases, its acceleration decreases. This is due to the fact that air resistance acts as a force opposing the motion of the rocket, and a greater mass requires more force to overcome this resistance.
3. How does air resistance affect the motion of the rocket?
Air resistance acts as a force opposing the motion of the rocket. As the rocket moves through the air, it pushes against air molecules, causing them to move out of the way and creating drag. This drag force reduces the acceleration of the rocket and can also cause changes in its trajectory.
4. What is the difference between a spring-mass system and a rocket with changing mass?
A spring-mass system is a simple harmonic oscillator, where the motion is determined by the mass and spring constant. On the other hand, a rocket with changing mass is affected by additional factors such as air resistance and the amount of fuel being burned. This results in a more complex motion and a changing mass as the rocket expels fuel.
5. How can we calculate the maximum height reached by a rocket with changing mass and air resistance?
To calculate the maximum height reached by a rocket with changing mass and air resistance, we need to use the principles of projectile motion and take into account the changing mass and the effects of air resistance. This can be done by using equations of motion and considering the forces acting on the rocket at different points in its trajectory.
