Exploring the Multifaceted Nature of Time: A Comprehensive Discussion
In summary: I'm typing on a keyboard!).The second is in quantum mechanics there seems to be a world clock that ticks at a constant rate. The phase of each energy eigenstate evolves asIn quantum field theory also time is a unitary evolution. However the Lagrangian is taken to be Lorentz invariant.And the third where the direction of time is given by the direction of entropy increase of the system. And a also relating to the time symmetry of the underlying laws.The world clock can be thought of as analogous to an ordinary clock, but it has the additional feature that it ticks at a constant rate. This is what is known as the quantum mechanical world clock. The phase of each
Prathyush
212
The question posed is a very general one. I want to understand the nature of time exactly in this thread. Time seems to have 3 commonly ways of looking at
First is in special relativity we have world lines evolving in a space time continuum with the Lorenz transformation the space time metric.
(e^iEt/h)
The purpose of the thread is I hope to get clarity over the various things related to time.
"Time is what clocks measure" -Einstein
Physics doesn't tell us what time is, only how its behaves. More general, science does not tell you why, but how.
Physics can tell you that time elapses at different rates in different situations, measured from different locations. That's it.
As espen180 mentions, I think that the question you are asking is fundamentally not a scientific question. Think about this:
You have provided three different ideas about time, what kind of experiment could you perform and what experimental results would indicate the correct idea? If there is no possible experiment that could distinguish the answer, then the question cannot be addressed via the scientific method.
I think what espen180 and DaleSpam said is true, but that the original post need not necessarily be interpreted that way. The sentence "The purpose of the thread is I hope to get clarity over the various things related to time. " suggests that what the OP is asking for is a discussion of the various ways that the notion of 'time' enteres into our physical theories, and possibly a similar discussion of related notions like 'clock', 'spacetime' etc.
That is a good point. Prathyush, can you clarify what kind of answer you are looking for?
Ya as dx said would like to look at the all the aspects of time in the physical theories and try to relate them. I have motivated the three ideas related to time based on, well tested theories Special theory, Schrodinger wave wave equation and second law of thermodynamics.
Regarding the first two, SR and QFT, I would say that those are similar in terms of their treatment of time. In both cases time is simply the timelike coordinate of your Minkowski spacetime and in both cases other equivalent coordinate systems are obtained via the Poincare group (Lorentz transform for boosts, plus spatial rotations and spatial and temporal translations). The difference between the first two is not in terms of the treatment of spacetime, but rather the usual differences between QM and classical mechanics. Specifically, operators and states and commutators and fields and the uncertainty principle and other quantum weirdness that results. So, I would say that QFT and SR treat time the same, but they treat matter quite differently (e.g. no point particles with well defined positions and momenta in QFT).
Regarding the first two and thermodynamics. I actually don't know much about that topic. I have the impression that a complete relativistic treatment of thermodynamics is still not well-established.
Some comments:
My earlier post was rather glib. Consider in general a clock as any causal sequence of events (each tick causing the next tick). One can then compare and calibrate clocks and observe "good" clocks as those for which the dynamics of physical systems has the simpler form (within the constraint of being equally useful for prediction) when the systems are parametrized by their clicks.
Consider this in the sense of general covariance where we allow arbitrary re-parametrization of time in our dynamic equations. (possibly but not necessarily constrained by monotonicity e.g. preserving time ordering).
It helps to understand here that the space-time continuum itself is a continuous array of events (including null events e.g. "nothing happened here-now"). As time is used here it is inextricably mixed with our notions of causal ordering of events and hence of our notions of causality and events themselves.
But note that here, time (and also in the relativistic case space as well) is a parametric quantity which is to say something we construct to index the causal relationship between events as opposed to being representative of any physical observable of existent objects. It is the events which we observe and thus which have direct physical meaning (clicks of particle detectors and collisions of galaxies or simply the fact that nothing extra-ordinary has happened). I think that you can't isolate time in this setting. Speak only of space-time structure as it models the transitive causal relationship between events:
A affects B
B affects A
A and B are causally isolated from each other.
Mathematically such a set of relationships (with "affects" being transitive A->B->C => A->C) forms a lattice structure. This plus topology gives us the metric space-time structure since knowing the boundaries of the future light-cones for (events which may be affected by) each event defines the metric on a topological space.
(e^iEt/h)
The "world clock" in this case is the laboratory clock and we must invoke some form of covariance to express how e.g. different laboratory frames will see the same events. I'm not sure what you mean by "seems to tick at a constant rate" rates are comparisons (same root as ratio). All clocks tick at a constant rate with respect to themselves. We must start with the base clock to compare other changing quantities to in order to define a rate.
In any event this quantum time is itself parametric in nature just as mentioned in the relativistic case above. Hence time is not a physical observable in standard QM.
Note however that in the treatment of position as an observable automatically breaks the time and space unification of special relativity and its generalization. In using time parametrically we must in the relativistic setting also treat space similarly.
If we take the reverse course and seek to treat time as an observable of a system then our quantum systems can no longer be thought of as corresponding to classical objects (in the large scale of action limit) but rather to classical events. Consider e.g. when doing collision experiments then how one deduces where and when two particles collided based on the tracks of their products. Also consider how one might need to modify the interpretation of "bras" and "kets" not as state vectors but as "event vectors" some of which are not localized either in space or in time.
The Lorentz invariance of which you speak isn't there in finite dimensional QM e.g. particle spin. The relativistic treatment is rather more involved and typically jumps straight into a quantified theory (quantification = variable number of instances of the base system i.e. many particle theory = field theory). I think to treat it properly we must look beyond unitary QM and develop a satisfactory pseudo-unitary formulation. That's an open project as far as I've been able to determine.
Be careful here. The entropy arrow is only meaningful when we speak of systems in isolation. The entropy of my leftovers certainly drops when I stick them in the freezer.
This then opens a possible can of worms as to whether we can speak of "systems in isolation" meaningfully without invoking time. Certainly we can't control or know about a "system in isolation" unless and until we make prior and posterior observations (breaking isolation) of that system. This then requires we speak of "isolation for a period of time" in some sense. I don't believe we can glean as much understanding of time from considering entropy as we can glean understanding of entropy by considering time...if that makes any sense. In short I think it better to consider time apart from the 2nd law first, get a handle on it and then come back to the thermodynamic issues.
(However at the heart of any measurement process especially at the quantum level are thermodynamic considerations... Just look at what the physicist's do in the lab, how much cooling equipment is required to do precision quantum measurements!)
In the end, to my mind, it all comes down to causal structure which we infer and assume as we interpret what it means to observe and effect measurements i.e. to affect and be affected by nature (which itself is the epistemological foundation of any knowledge we assert in physics). I don't think we can reduce it further but must treat it in the same way mathematicians treat undefined terms... as primaries which we understand in application from common experience and use then to define other terms.
Well that's my 2cents worth. (Make the check payable to James Baugh ;)
1. What is the concept of time?
Time is a fundamental concept in physics, referring to the measurement of the duration between events. It is often described as the fourth dimension, along with the three dimensions of space.
2. How is time measured?
Time is typically measured using units such as seconds, minutes, hours, days, and years. These units are based on the rotation of the Earth and the movement of objects in our solar system. More precise measurements of time are made using atomic clocks.
3. Is time constant or can it be manipulated?
Time is relative and can be manipulated through factors such as gravity and velocity. This was famously demonstrated by Einstein's theory of relativity, which showed that time can appear to pass at different rates depending on the observer's frame of reference.
4. How does time relate to the universe?
Theories about the nature of time are closely tied to our understanding of the universe. For example, the Big Bang theory suggests that time began with the creation of the universe, while other theories propose the existence of multiple dimensions of time.
5. Can we travel through time?
Currently, time travel is only possible in theory. While some speculate about the potential for time travel through wormholes or advanced technology, there are currently no known methods for physically traveling through time.
  • Quantum Physics
  • STEM Academic Advising
9K
