Calculating Electric Field of Concentric Spheres
In summary, the smaller sphere acquires a positive potential, so there will be an outward electric field between the spherical shells. Your task should be to find out what charge will accumulate on the spheres as a result of the potential difference.
yahoo32
27
We have two thin concentric conducting spheres r1 and r2. THe spheres are connected with a power source which supplies emf of epsilon_0. The smaller sphere is connected to the positive pole of the power supply and the larger sphere is connected to the negative pole. Using Gauss Law find the electric field between r1< R <r2 and find the electric field R>r2.
For this the electric field R. r2 would be 0 correct? Because charge enclosed is 0?
And for the electric field between r1 and r2 it would be equal to E = (+Q)/(4pi*R^2*Epsilon_0)?
After disconnecting the battery we ground the outer shell. Now calculate the electric field R>r2 and R<r1.
For R<r1, the electric field is 0 because charge enclosed is 0, correct?
And for R>r2 the electric field is now equal to E = (+Q)/(4pi*R^2*Epsilon_0) because charge enclosed is now +Q +Q -Q = +Q.
Could you guys please verify if my reasoning is correct for these problems. Thank you so much for your help!
anyone?
Since the smaller sphere acquires a positive potential, there will be an outward electric field between the spherical shells. Your task should be to find out what charge will accumulate on the spheres as a result of the potential difference. How can you relate charge to potential?
We are given Q. I just need to show what the electric field would be in terms of Q. Therefore in between the spheres, as you stated, the electric field would decrease as a function of 1/r^2, correct? Could you state which part of the problem you are referring to? Because once you ground it, the positive charge should leave from the sphere correct?
You didnt state that you had Q at the beginning of the problem> I was referring to the very first part where you're supposed to find the E field between the spheres. The E field there is not zero if there is a potential applied between the spheres.
EDIT: ahh, didnt see that you had that part, but it looks good.
EDIT2:Thats what I would have done, unless I missed something.
Sorry. So Q is given to me. Now would it be true that for the first part the electric field outside the concentric spheres is 0 and between them is equal to E = (+Q)/(4pi*R^2*Epsilon_0)?
Yeah, that looks right since the superposition of charges in gauss' law is a linear operation, your net charge is zero outside the second shell. inbetween the only charge contributing to electric flux is contained on the inner sphere (which terminates on the outer sphere)
I see. So is my equation correct for the charge in between the two conducting concentric spheres? Also could you also verify my reasoning for when the outershell is grounded?
Actually, wait I think we missed something. If there is a potential between the spheres, your eq is:
V = q/(4piepsilon)*(1/ra - 1/rb)
and your E field between the spheres becomes
E = V/((1/ra - 1/rb)*r^2)
it seems redunant that they give you charge and the potential between the spheres.
When the outer shell is grounded, it has access to any charge flow, which will be determined by the charge on the smaller sphere. Once the power is disconnected (as long as the potential is not gradually lowered, if that's possible) the spheres retain their charge i believe. So, after grounding the larger shell, its charge is determined by the charge that is on the smaller sphere, which will 'pull' an equal amount of charge towards the inner surface of the shell. What happens after this?
It is asking to calculate it using Gauss' Law. And after you ground the outer shell, the total charge enclosed at r=20cm is +Q, correct? Wait that new formula you calculated for E, is that really true? That would throw everything off in this last part of the problem?
The formula will reduce to what you have if q is actually Q on the inner shell -- I am sort of confused why they give you both Q and the potential difference applied between the shells. It seemed to me first that this was a spherical capacitor problem because of this.
Edit: if it is not Q, though, it won't be hard to calculate using the formula for V above. But, your general formula will be right because the charge on a spherical conductor acts as if its concentrated at a point in the middle of a sphere.
I am very confused now. There was a portion of this problem I solved before that required EMF to solve because it asked to solve for the charge and the energy stored in the electric field. Maybe the potential difference isn't required for this part?
Ahh, ok, well forget what I've been saying then. If you've solved for the charge and have set it to Q, then your formula for between the sphere in the first part is correct.
Okay, how about the part of the problem where we ground it. Is my reasoning correct for those two electric fields as well?
This one, however, I'm not sure if you have the right answer, since the outer conductor is grounded. (this would be true if the conductor was neutral, and ungrounded). Since the conductor is grounded,it can pick up net charge because it has unlimited charge to take up from the 'earth'. so, if the inner conductor is at +Q, the outer conductor will match this with -Q on its inner surface. In a neutral conductor, the outer surface would become +Q, to keep the net charge at 0. However, the conductor is now grounded which leads me to believe that the outer conductor will attain a net charge of -Q, changing your answer. IM NOT 100% on this.
I see, could anyone else provide their opinion? The way I see it, you lose the -Q charge meaning Q enclosed at a distance outside both spheres would be +Q -Q +Q which is equal to Q. Anyone?
When you ground the outer sphere, there will be no charge on the outer surface of the outer sphere. But there will be negative charge on the inner surface of the outer sphere because of the positive charge on the outer surface of the inner sphere. And there is no charge on the inner surface of the inner sphere. So there is no electric field at R<r1 and R>r2.
Wait a sec, if it is true that once you ground it there is no electric field at R.r2, then that would mean it is also true that when it is NOT grounded there IS an electric field at R>r2, which is not true, according to what I think...
When you connect a power supply to a neutral concentric spheres, the electrons were transferred from innere sphere to outer sphere. Since charges always reside on the outermost surface of the conductor, outer surfaces of inner and outer spheres have equal and opposite charges. Hence field at R>r2 is zero. When you connect the outer sphere to the ground, the electrons move to the ground. Now there is no charge on the outer surface of the outer sphere. At this instant the +ve charge on the inner sphere induces equal amount of electrons on the innere surface of the outer sphere. Equal amoungt of +ve charges are induced on the outer surface of the outer sphere which are neutralised by the supply of electrons from the ground. In this case also electric field is zero at R>r2.
If you remove the ground connection, electrons on the inner surface will move toward the outer surface. And that will be the same case as in the first one.
That is true, but at the same time they are all being grounded. So you are constantly losing that charge on the outer sphere, no?
No. You are grounding only outer surface of the outer sphere. If you keep it grounded, there will not be any flow of charges either way.
What is the formula for calculating the electric field between two concentric spheres?
The formula for calculating the electric field between two concentric spheres is given by E = k(q1-q2)/r2, where k is the Coulomb's constant, q1 and q2 are the charges on the two spheres, and r is the distance between the two spheres.
Can the electric field between two concentric spheres be zero?
Yes, the electric field between two concentric spheres can be zero if the charges on the two spheres are equal and opposite in sign, i.e. q1 = -q2. In this case, the electric field is cancelled out and becomes zero.
What is the direction of the electric field between two concentric spheres?
The direction of the electric field between two concentric spheres is always radially outward from the center of the smaller sphere to the center of the larger sphere. This is because the electric field is always directed from a higher potential to a lower potential.
How does the distance between the two concentric spheres affect the electric field?
The electric field between two concentric spheres is inversely proportional to the square of the distance between them. This means that as the distance between the two spheres increases, the electric field decreases. Similarly, if the distance decreases, the electric field increases.
What is the significance of concentric spheres in calculating the electric field?
Concentric spheres are useful in calculating the electric field because they provide a symmetrical configuration, making it easier to apply the formula and calculate the electric field. Additionally, concentric spheres are a common scenario in many practical applications, such as in capacitors and metal spheres, making it a valuable concept to understand in the field of electromagnetism.
