In semiconductors, can phonons create excitons?
In summary, excitons are created when an electron is liberated from the valence band of a semiconductor and becomes bound to the hole it leaves behind. Similar to hydrogen, the quantized energy levels of excitons can be calculated. The ground state of an exciton in GaN has an energy of approximately 0.023eV. At room temperature, the thermal energy is around 0.026eV, which is close to the exciton energy level. Excitons are not usually created thermally, as the minimum energy required is the band gap energy minus the exciton binding energy. However, they can be destroyed at high temperatures when thermal excitation creates free electrons and holes.
jeebs
325
As I understand it, an exciton is created when an electron is liberated from the valence band of a semiconductor, but becomes bound to the hole that it leaves vacant via Coulomb attraction.
We can calculate the quantized energy levels of the exciton just like hydrogen. I have done this for the ground state of an exciton in GaN, which turns out to be about 0.023eV.
At room temperature, the thermal energy is about kT = 0.026eV. These are two close figures. Am I correct in thinking kT can be considered the phonon energy?
I was wondering, do excitons get created by phonons knocking the electrons out of the valence band, or is it only able to happen when there is a photon of wavelength equal to the ground state (or an excited state) of the exciton?
No, excitons will usually not be created thermally. The minimum energy needed to create an exciton is the band gap energy minus the exciton binding energy. GaN is a wide band gap material and the band gap should be somewhere near 3.2 eV at room temperature. Although the exciton binding energy is quite large in GaN, it is still much smaller than the band gap, so you will usually not get the (almost) 3.2 eV needed to form an exciton out of phonons.
However, excitons are usually destroyed thermally at high temperatures. In this case the thermal excitation creates free electrons and holes instead of the bound electron-hole state.
1. What are phonons and excitons in semiconductors?
Phonons are quanta of lattice vibrations in a solid, while excitons are bound electron-hole pairs in a semiconductor material.
2. How can phonons create excitons in semiconductors?
When a phonon interacts with an electron in a semiconductor, it can create an exciton by transferring energy and momentum to the electron, causing it to move to a higher energy state and leaving behind a hole. The electron and hole then become bound together by the Coulomb force, forming an exciton.
3. What are the applications of excitons in semiconductors?
Excitons play a crucial role in various optoelectronic devices, such as solar cells, LEDs, and lasers. They also have potential applications in quantum computing and information processing.
4. Can phonons destroy excitons in semiconductors?
Yes, phonons can also break apart excitons by transferring energy and momentum to the bound electron-hole pair, causing them to separate. This process is known as exciton dissociation.
5. How do phonons affect the properties of excitons in semiconductors?
The interaction between phonons and excitons can affect the energy and lifetime of the exciton, as well as its ability to move and recombine. This can have a significant impact on the overall properties and performance of semiconductor devices.
  • Atomic and Condensed Matter
