- #176
PeterDonis
Mentor
- 45,797
- 22,741
JDoolin said:If indeed, the gravitational field from a receding object has some predictable variation based on its relative velocity, then we should, of course, use that modification. But if you want to claim that there is no predictable variation; no predictable "meaningful" position we can use for distant objects, I beg to differ.
The answer to this will be easier to understand if I answer your other question first. See below.
JDoolin said:On another topic, if possible, can you support your argument that "ordinary Lorentz frames...are valid only locally." I've heard this time and time again, but no one has ever explained what it means.
It means that you can set up a Lorentz frame centered around any event you like in spacetime, but the frame will only obey the laws of special relativity in a restricted local region of spacetime around that event. Strictly speaking, it will only obey the laws of special relativity exactly *at* that event; but in practice, there will be a finite region around the event where the deviations from the laws of special relativity due to the curvature of spacetime are too small to detect. The size of that region depends on how accurate your measurements are and how curved the spacetime is.
Here's a simple example: take an object that is freely falling towards the Earth from far away (say halfway between the Earth and the Moon), and set up a Lorentz frame using its worldline as the t axis. Since the object is in free fall, i.e., inertial motion, its worldline can be used this way according to the laws of SR. Now take a second object which is also in free fall towards the Earth, but which is slightly lower than the first object. Suppose there is an instant of time at which the second object is at rest relative to the first; we take this instant of time to define t = 0 in our Lorentz frame, and the position of the first object at this instant to define the spatial origin, so the frame is centered on that event on the first object's worldline.
It should be evident that, for a given accuracy in measuring the relative velocity of the two objects, there will be some time t > 0 at which it becomes apparent that the second object is no longer at rest relative to the first. (This is because it is slightly closer to the Earth and therefore sees a slightly higher acceleration due to gravity.) But SR says that' can't happen: both objects are moving inertially, both were at rest relative to each other at one instant, and SR says that they therefore should remain at rest relative to each other forever. They don't. So we can only set up a Lorentz frame around the first object's worldline for a short enough period of time that the effects of tidal gravity (which is what causes the difference in acceleration of the two objects) can't be measured. Similarly, if the second object were further away from the first, its relative acceleration would become evident sooner; so there is a limit to how far we can extend a Lorentz frame around the first object in space as well, before the effects of spacetime curvature become evident.
JDoolin said:Are you saying that when I point at a distant galaxy, that that direction that I am pointing only exists locally? Are you saying that the very concept of direction is only a local phenomenon?
The direction you are pointing is the direction from which light rays emitted by the distant galaxy are entering your eyes. It is certainly reasonable to call that "the direction of the galaxy", but only if you are aware of the limitations of that way of thinking. Light paths are bent by gravity, so the direction you are seeing the light come from may not be "the" direction the galaxy is "actually" in. This is another manifestation of spacetime curvature, and it means you can only set up a Lorentz frame locally with regard to directions and positions as well as relative motion of objects.
This also applies to what you were saying about assigning a "distance" to distant objects. There is no unique definition of "distance" in a curved spacetime; there are at least three different ones that are used in cosmology. You can uniquely define distance in a local Lorentz frame, but that only works locally; once you are out of the local region where the laws of SR can be applied to the desired accuracy, your unique definition of distance no longer works.
