Comparing Relations: Symmetry, Antisymmetry, and Transitivity
  • Thread starter rooski
  • Tags
    Relations
In summary, the question asks for proof that the composition of two symmetric relations is also symmetric, antisymmetric, transitive, and not symmetric. The solution involves showing that for any elements a and b in set A, if a is related to b in both R and S, then b is related to a in both R and S when combined into a single statement. The attempt at a solution involves showing that for any elements a and b in set A, if a is related to b in both R and S, then b is related to a in both R and S when combined into a single statement. This process must be repeated for each condition (symmetric, antisymmetric, and transitive) and the final result proves that S
rooski
61
let A be any set of numbers and let R and S be relations on A.
if S and R are symmetric then show S o R is symmetric.
if S and R are antisymmetric then show S o R is antisymmetric.
if S and R are transitive then show S o R is transitive.
if S and R are antisymmetric then show S o R is not symmetric.
For The first question i would do something like
[tex]\forall a,b \in A : aRb \rightarrow bRa[/tex] and [tex]\forall a,b \in A : aSb \rightarrow bSa[/tex] then show that when combined into a single statement it is valid, right?
Yes, you're on the good track.
So take a(SoR)b. You'll have to prove that b(RoS)a.
1. What is the difference between symmetry and antisymmetry in relations?
Symmetry in relations means that if element A is related to element B, then element B is also related to element A. In other words, the direction of the relation does not matter. On the other hand, antisymmetry means that if element A is related to element B, then element B cannot be related to element A. This means that the direction of the relation does matter.
2. How do you determine if a relation is symmetric or antisymmetric?
To determine if a relation is symmetric, you can check if for every pair of elements (A,B), if A is related to B, then B is also related to A. If this is true for all pairs, then the relation is symmetric. To determine if a relation is antisymmetric, you can check if for every pair of elements (A,B), if A is related to B and B is related to A, then A must be equal to B. If this is true for all pairs, then the relation is antisymmetric.
3. What is an example of a relation that is both symmetric and antisymmetric?
An example of a relation that is both symmetric and antisymmetric is the "equal to" relation. For any two numbers x and y, if x is equal to y, then y is also equal to x. However, if x is equal to y and y is equal to x, then x must be equal to y. This satisfies both the conditions of symmetry and antisymmetry.
4. What is transitivity in relations?
Transitivity in relations means that if element A is related to element B and element B is related to element C, then element A is also related to element C. In other words, if there is a chain of relations between elements, then all elements in that chain are related. This concept is important in understanding the properties of directed graphs.
5. Can a relation be both symmetric and transitive?
Yes, a relation can be both symmetric and transitive. An example of such a relation is the "divides" relation in mathematics. If a number x divides another number y, then y must also divide x. Additionally, if x divides y and y divides z, then x must also divide z. This satisfies both the conditions of symmetry and transitivity.
  • Topology and Analysis
