Time it takes for an electron to travel a set distance
In summary, the conversation discusses the acceleration and speed of electrons in a CRT tube. The electrons are accelerated by a 20,000 V potential difference between the cathode and the positive metal mesh, 5.00 cm away. Using the formula for kinetic energy, the speed of the electrons is found to be 8.386*10^7 m/s. To determine the time it takes for the electrons to reach the wire mesh, two methods are used: using the formula t = d/v and using a combination of formulas for force, acceleration, and distance. Both methods result in a time of approximately 1.192*10^-9 seconds. It is safe to assume that both methods are correct and the answer is accurate.
Reprisal35
In a CRT tube, electrons are accelerated by a 20,000 V potential difference between the electron gun (the cathode) and the positive metal mesh 5.00 cm away.
a. What is the electron’s speed when it reaches the positive wire mesh?
b. How much time does it take the electron to reach the wire mesh?
[itex]U = q∆V\\
K = \frac{1}{2}mv^2\\
F = ma\\
F = qE \\
E = \frac{V}{d}\\
d = d_0 + (v_0)(t) + \frac{1}{2}(a)(t^2)\\
[/itex]
For part A, I got the following which is actually the same example we did in class.
[itex]
U = K\\
q∆V = \frac{1}{2}mv^2\\
(1.6*10^{-19}C)(20000\frac{J}{C}) = \frac{1}{2}(9.1*10^{-31}kg)(v^{2})\\
3.2*10^{-15}J = 4.55*10^{-31}kg(v^{2}) \\
(3.2*10^{-15}J)/(4.55*10^{-31}kg) = v^{2} \\
7.033*10^{15}\frac{m^{2}}{s^{2}} = v^{2} \\
v = √7.033*10^{15}\frac{m^{2}}{s^{2}} \\
v = 8.386*10^{7}\frac{m}{s}\\
[/itex]
Where I'm getting a bit paranoid is part B.
At first I thought, in order to get ##t##, all we needed to do was use the formula, ##t = \frac{d}{v}## and I got an answer of ##5.96*10^{-10}s##, but that seems to simple for this kind of problem.
So then I decided to use a combination of several formulas we learned in the past in order to determine the time it takes for an electron to travel a set distance.
Here's what I did:
[itex]
F = ma\\
F = qE \\
E = \frac{V}{d}\\
ma = \frac{qV}{d}\\
a= \frac{qV}{dm}\\
d = \frac{1}{2}(a)(t^2)\\
d = \frac{1}{2}[\frac{qV}{dm}](t^2)\\
2d = \frac{qV}{dm}(t^2)\\
\frac{2d^{2}m}{qV} = t^2\\
t = √\frac{2d^2m}{qV}\\
t = √\frac{(2)(.05m)^{2}(9.1*10^{-31}kg)}{(1.6*10^{-19}C)(20,000\frac{J}{C})}\\
t = √\frac{4.55*10^{-33}}{3.2*10^{-15}}\\
t = √1.422*10^{-18}s\\
t = 1.19*10^{-9}s\\
[/itex]
Now looking back at my second attempt, it seems a bit ridiculous to do all that to get ##t##. So my question is, is my second attempt for getting ##t## correct or did I mess up?
[itex]U = q∆V\\
F = ma\\
F = qE \\
E = \frac{V}{d}\\
[/itex]
[itex]
U = K\\
[/itex]
Here's what I did:
[itex]
F = ma\\
F = qE \\
E = \frac{V}{d}\\
ma = \frac{qV}{d}\\
a= \frac{qV}{dm}\\
t = 1.19*10^{-9}s\\
[/itex]
Can you show your working to get your answer in the bit I made red, so we can check you did it correctly.
Sure,
[itex]
d = 0.05m\\
v = 8.386∗10^7\frac{m}{s}\\
v = \frac{d}{t}\\
t = \frac{d}{v}\\
t = \frac{0.05m}{8.386∗10^7\frac{m}{s}}\\
t = 5.96*10^{-10}s
[/itex]
Reprisal35 said:
Sure,
[itex]
d = 0.05m\\
v = \frac{d}{t}\\
t = \frac{d}{v}\\
t = 5.96*10^{-10}s
[/itex]
OK, You have used the final velocity, not the average velocity.
Well that makes sense now.
[itex]
v_{avg} = \frac{v_0 + v_f}{2}\\
v_{avg} = \frac{0 + 8.386∗10^7}{2}\\
v_{avg} = 4.193*10^7\\
t = \frac{0.05}{4.193*10^7}\\
t = 1.192*10^{-9}s
[/itex]
I feel kinda silly for forgetting to take the avg of speed... Thanks for pointing that out!
So both methods give the same answer. Is it safe to assume both methods work and that the answer is correct?
[itex]
t = 1.192*10^{-9}s
[/itex]
Seems reasonable to me.
Likes 1 person
Awesome! Thanks again!
Related to Time it takes for an electron to travel a set distance
1. How is the "time it takes for an electron to travel a set distance" calculated?
The time it takes for an electron to travel a set distance can be calculated using the formula t = d/v, where t is the time, d is the distance, and v is the velocity or speed of the electron.
2. What is the typical speed of an electron?
The speed of an electron can vary depending on the material it is traveling through, but on average, electrons can travel at a speed of approximately 2.2 million meters per second.
3. Does the time it takes for an electron to travel a set distance change in different materials?
Yes, the time it takes for an electron to travel a set distance can change in different materials due to variations in the material's atomic structure and composition. This can affect the electron's speed and therefore the time it takes to travel a set distance.
4. How does the time it takes for an electron to travel a set distance impact electronics?
The time it takes for an electron to travel a set distance is a crucial factor in the functioning of electronics. Fast-moving electrons are essential for the quick transfer of information and the efficient operation of electronic devices.
5. Can the time it takes for an electron to travel a set distance be manipulated?
Yes, the time it takes for an electron to travel a set distance can be manipulated by altering the properties of the material it is traveling through, such as changing the temperature or applying an electric field. This manipulation can have significant effects on the performance of electronic devices.
