Is Ek0-Ek1 Greater Than Zero?
  • Thread starter May11
In summary: Haha, that's an interesting stance to take. If you plan on continuing with physics, I suggest you try to get out of this mentality that there is a 'right' way of arriving at a solution. If a given derivation or proof seems logically sound to you, then it's good. I have some physics major friends who are in a similar mindset, and when doing problem sets with me they always say things like, 'can you do that?', as if there were some mystical physics police that sets the rules for how you approach physics problems! Of course there's not, and as long as you don't abuse math, everything's fine!
May11
Hi there,
I need your help to prove the following, please:
Ek0-Ek1>0
Thanks in advance. (:
Try to prove that Ek1-Ek0<0
Seriously, if you don't explain your notation, then we can't help obviously.
Ek0 is the initial kinetic energy that an object possesses.
Ek1 is the eventual kinetic energy that an object possesses.
Try to prove that Ek0-Ek1 (energy loss) equals a positive value.
Did you get my question? need a further explanation?
Sure does. This is simply not true in general. You need to tell about the system, and what it is doing. With the information given we can do nothing.
Depending on the circumstances, an object's kinetic energy can either increase, decrease or remain constant. What are the circumstances in your case? What kind of object are we talking about? What forces act on it?
It is a plastic collision, masses exert forces on each other, ending up with a joint velocity (U). We fisrt have to express the equation of the velocity at the end of the collision, that is : U= Mv/M+m
Then, express the equation of Ek0 and Ek1 :
Ek0= Mv²/2
Ek1= (m+M)u²/2 = M²v²/2(m+M)
Then, prove that Ek0-Ek1>0 ...that is pretty much all! we are not given any further...
Two masses, actually.
V1 (velocity of M before the collision) = v
V2 ( velocity of m before the collision) = 0
Ek0= Mv²/2
Just write it out? It seems like you haven't even tried this.
[tex]E_0-E_1 = \frac{1}{2}Mv^2 - \frac{1}{2}\frac{M^2v^2}{m+M} = \frac{1}{2}Mv^2 \left( 1- \frac{M}{m+M} \right)[/tex]
Now what can you say about whether or not this is positive?
Mv²/2 is undoubtedly positive.
1-M/m+M:
1>M/m+M
M+m>M<1 = positive.
Umm, makes sense. The teacher said we have to use more formulas which are not given in the question, haven't expressed them, to branch out a little from what we are given. I will ask if your proof is valid and acceptable.
Thanks a heap! :)
Thanks a heap! :)
With re: to this problem, all the physics is essentially in solving for the final velocity (where you have to apply conservation of momentum).
I will bear that in mind !
FAQ: Is Ek0-Ek1 Greater Than Zero?
1. What does the term "Prove Ek0-Ek1>0" mean?
The term "Prove Ek0-Ek1>0" is a mathematical statement that means to show or demonstrate that the difference between two values, denoted as Ek0 and Ek1, is greater than zero. This is typically done using mathematical proofs and logical reasoning.
2. Why is it important to prove Ek0-Ek1>0?
Proving Ek0-Ek1>0 is important because it allows us to establish a relationship between two values and determine the direction of change. It is commonly used in scientific research and data analysis to support hypotheses and draw conclusions.
3. What are some common methods for proving Ek0-Ek1>0?
There are several common methods for proving Ek0-Ek1>0, including algebraic manipulations, graphical representation, and mathematical induction. Depending on the specific context, other methods such as calculus or statistics may also be used.
4. Can you give an example of proving Ek0-Ek1>0?
Sure, here's an example: Let Ek0 = 5 and Ek1 = 3. We want to prove that Ek0-Ek1>0. Using algebra, we can rewrite this as 5-3>0, which simplifies to 2>0. This is a true statement, so we have successfully proven that Ek0-Ek1>0 for these specific values.
5. Are there any applications of proving Ek0-Ek1>0 outside of mathematics?
Yes, proving Ek0-Ek1>0 is not limited to mathematics and can also be applied in other fields such as physics, chemistry, and economics. In these fields, it is often used to analyze data, make predictions, and support theories or laws.
9K
