Solution of a Differential equation (Linear, 1st order). x=dependent variable
In summary: If it is in the form:\displaystyle \frac{dy}{dx}+P(x)y=Q(x) the integrating factor is:\displaystyle e^{\int P(x)\,dx} In this problem:\displaystyle \int P(x)\,dx=\int 12y^2\,dx\,.You are close to the right idea. Write:\displaystyle x(y)=\frac{\int e^{12y^2}\left(\frac{y^{10}}{10}-487y^{-2}\right)\,dy+C}{e^{12y^2}} You can integrate this. Then evaluate at y=2 to determine C.
coolhand
the problem is as follows:
[1-(12*x*(y^2))]*(dy/dx)=y^3
we need to solve this equation such as x=5 & y=2 by regarding y as the independent variable.
Here is my work for the first attempt:
Step 1)separation & integration
Step 2)ln(x)= (-1/(2y^2))-12ln(y)+C
x=Ce^(-1/(2y^2)) +(1/(y^12))
x(y)=5.665
anyone know where I went wrong?
I'll translate your text to atex and you tell me if I've understood you:
You started with the following to solve...
[tex]\left [ 1-12xy^2 \right ] \frac{dy}{dx} = y^3[/tex]...but you want the solution in the form [itex]x=f(y)[/itex]...you can solve for y=f(x) and change the variable or figure how dy/dx is related to dx/dy.
Anyway - you did it the first way and you are pretty sure of your solution:
[tex]\ln{(x)} = -\frac{1}{2y^2} - 12\ln{(y)} + c[/tex]
Taking the exponential of both sides gives me:
[itex]x = C \exp{ \big [-\frac{1}{2y^2} - 12\ln{(y)}\big ]}[/itex] which is:
[itex]x = C \exp{ [-\frac{1}{2y^2}]}\exp{[\ln{(y^{-12})}]}[/itex]... does this make sense?
Simon,
that makes sense, we essentially came to the same solution of the general equation. However, when I plug in for the given x & y values to solve for "C", I get a huge number on the order of 2*10^4
to interconvert between dy/dx, can you just simply invert (given that you invert the functions as well)?
What I got was different to your result of x=Ce^(-1/(2y^2)) +(1/(y^12)) which I read as:
[tex]x = C\exp{\left [ -\frac{1}{2y^2} + \frac{1}{y^{12}} \right ]}[/tex] which tells me that [tex]C=x\exp{\left [ \frac{1}{2y^2} - \frac{1}{y^{12}} \right ]}[/tex] ... when I put in x=5 and y=2, I get C=36.936.
Mine is different - it's the y^12 that throws it out ... and I get about C=30,000.
... always assuming the solution you got is correct. Any reason to suspect C is not big?
x(y)=5.665
It looks like your solution to the differential equation is wrong.
Taking the derivative of both side of [itex]\displaystyle \ln{(x)} = -\frac{1}{2y^2} - 12\ln{(y)} + c[/itex] gives:
[itex]\displaystyle \frac{1}{x} = 2\frac{1}{2y^3}y' - 12\frac{1}{y}y' [/itex]
and finally [itex]\displaystyle y^3 = \left(x - 12xy^3\right)\frac{dy}{dx} [/itex]
It doesn't look like your D.E. is separable.
Find an integrating factor to make it exact.
I think the y^12 indicates that an integrating factor has been tried... but when I tried it I got a different solution. Advise to OP: revisit the differential equation. Check the algebra.
Rewrite [itex]\displaystyle \left [ 1-12xy^2 \right ] \frac{dy}{dx} = y^3[/itex]
as [itex]\displaystyle \frac{dy}{dx}=y^3+12xy^2\,\frac{dy}{dx}\,.[/itex]
Multiply through by [itex]y^9\,.[/itex]
[itex]\displaystyle \frac{d}{dx}\left(x\cdot f(x)\right)=f(x)+x\cdot\frac{d}{dx}\left(f(x) \right)[/itex]
So I just tried reworking through my algebra, starting with Sammy's suggest of rewriting the function as :
(dy/dx)=y3+12xy2(dy/dx)
However, I had some confusion about multiplying through using y9. Is that step generating an integrating factor such that:
y= [([itex]\int[/itex]Q(x)*M(x)dx)]/(M(x))
then, P(x)= [M(x)']/M(x)
then the integrating factor would be e^([itex]\int[/itex]P(x))?
If so, I was confused as to which function would be the appropriate Q(x), in the form that you re-wrote it in, it seemed to be y^3. However, I could be completely mistaken.
Using y^3 as Q(x), I calculated P(x)=e^([itex]\int[/itex](9/y))
The integrating factor was then:
C(e9)+y
That doesn't seem right
Aside: Get into the habit: what is it about the function that leads you to think "that doesn't seem right"? You get a gut reaction: "ugh - somefink rong - tell brain", try investigating to figure what triggered the reaction.
[itex]y^9[/itex] is the integrating factor. Multiply through to give:[tex]y^9 \frac{dy}{dx} = y^{12} + 12xy^{11} \frac{dy}{dx}[/tex]... then identify P(x,y) and Q(x,y).
Hint: Try rearranging so that it has form: P(x,y)+Q(x,y)y' = 0
You are missing the most important point if you want us to point out a mistake: how did you separate? This looks to me like it is not a separable equation.
x(y)=5.665
As you said in your title, this is a linear equation. Writing it as a function x, in terms of variable y, it is [itex]dx/dy+ 12y^2x= 1/y[/itex]. There is a standard formula for the integrating factor of a linear equation.
I get [itex]\displaystyle \left(y^3\right)\frac{dx}{dy}+ 12y^2x= 1\ .[/itex]
This is equivalent to [itex]\displaystyle \frac{dx}{dy}+ 12\frac{x}{y}= \frac{1}{y^3}\ .[/itex]
Ok, so after reworking this problem a few more times, I think I'm finally close the right solution:
using y12 as the integrating factor, and Q(x)=1/y3:
=[itex]\int[/itex]Q(y)P(y)
=[itex]\int[/itex]y9+C
5=(1/10)(210)+C
C=(-487/5)
x(y)=(1/P(y))Q(y)P(y)+C]
x(y)=(y-12) [itex]\int[/itex][((1/10)y10)-(487/5)]
x(y)=(1/(10y2))-(487/(5y12))
however when I input this as an answer it was wrong. Should I have solved for C later in the problem (i.e. right before my final answer)?
1. What is a differential equation?
A differential equation is an equation that involves an unknown function and its derivatives. It relates the rate of change of a variable to its current value and other variables. It is often used to model systems in physics, engineering, and other fields.
2. What is the solution of a differential equation?
The solution of a differential equation is a function that satisfies the equation. It is found by finding the antiderivative of the equation, which involves finding a function whose derivative is equal to the original equation. The solution can also be found numerically using numerical methods.
3. What is a linear differential equation?
A linear differential equation is a differential equation where the unknown function and its derivatives appear only in a linear form. This means that the variable and its derivatives are not multiplied together or raised to a power. Linear differential equations are often easier to solve compared to non-linear ones.
4. What does it mean for x to be the dependent variable in a differential equation?
In a differential equation, the dependent variable is the variable that is changing and is dependent on other variables. In other words, the value of x is determined by the values of the other variables in the equation. In a linear, first-order differential equation, the dependent variable is typically the variable that is being differentiated.
5. How is a first-order differential equation different from higher-order differential equations?
A first-order differential equation involves only the first derivative of the unknown function, while higher-order differential equations involve higher derivatives. This means that a first-order differential equation can be solved by finding the antiderivative, while higher-order equations require more complex methods such as integration by parts or reduction of order.
