Calculate induced emf across loop antenna by another loop antenna
In summary, to find the emf across the 50 ohm load, you will need to calculate the flux through the second loop using Faraday's law. This can be done by using the magnetic field equation B=uH and the E field equation of the first loop. Alternatively, you can use the equation V= 2pi*u*N*A*f*H*cos(theta). To get a more accurate measurement, you may need to consider the impedance of the antennas and transmission line. Good luck with your calculations!
avionion
i need to find emf across 50 ohm load attached to square loop antenna of single turn with each side of 10 cm. this antenna is placed 10 cm away from a similar antenna which is driven by a sinusoidal source of 10 v amplitude and with 1mW power.
i have derived E field equation of loop with sinusoidal source but don't know how can i get flux or H through the second loop to measure emf,
B=uH
To find the emf across the 50 ohm load, you will need to calculate the flux through the second loop. This can be done by using Faraday's law, which states that the emf induced in a loop is equal to the rate of change of flux through the loop. In this case, the loop is the 50 ohm load and the flux is the magnetic flux through the loop caused by the nearby antenna.
To calculate the magnetic flux, you will need to use the equation B=uH, where B is the magnetic field, u is the permeability of the medium (in this case, air), and H is the magnetic field strength. You can calculate H using the equation you have derived for the E field of the first loop. Once you have calculated the magnetic flux, you can then use Faraday's law to calculate the emf across the 50 ohm load.
Alternatively, you can also use the equation V= 2pi*u*N*A*f*H*cos(theta) to calculate the emf directly, where N is the number of turns in the second loop, A is the area of the loop, f is the frequency of the sinusoidal source, H is the magnetic field strength, and theta is the angle between the plane of the loop and the direction of the magnetic field.
To get a more accurate measurement of the emf, you may also need to take into account the impedance of the antenna and the transmission line connecting the two antennas. This can be done by using the equations for impedance matching.
I hope this helps you in finding the emf across the 50 ohm load. Good luck with your calculations!
1. How is induced emf calculated in a loop antenna?
The induced emf in a loop antenna is calculated using the formula E = -N(dΦ/dt), where E is the induced emf, N is the number of turns in the loop antenna, and dΦ/dt is the change in the magnetic flux through the loop over time.
2. What is the relationship between the induced emf and the distance between two loop antennas?
The induced emf is directly proportional to the distance between two loop antennas. As the distance increases, the induced emf decreases.
3. Can induced emf be negative in a loop antenna?
Yes, the induced emf can be negative in a loop antenna if the magnetic flux through the loop is decreasing over time.
4. How does the orientation of the loop antennas affect the induced emf?
The induced emf is maximum when the two loop antennas are oriented parallel to each other, and minimum when they are perpendicular to each other.
5. What other factors can affect the induced emf in a loop antenna?
The induced emf in a loop antenna can also be affected by the size and shape of the loop, the frequency of the signal, and the material properties of the loop and its surroundings.
