What is the Meaning of 8πr in Differentiating Sphere Volume?
In summary, the formula for the volume of a solid sphere, 4/3πr3, is related to the formula for the surface area, 4πr2, through differentiation. However, differentiating the surface area does not have a geometric meaning.
Aeneas
27
If you differentiate the formula for the volume of a solid sphere, 4/3 [tex]\pi[/tex]r3, you get 4[tex]\pi[/tex]r2, the formula for the surface area. This seems to make sense, as, onion-like, the sphere is made up of successive surface areas, so the rate of change will be the surface area for any given r. If you differentiate 4[tex]\pi[/tex]r2, however, you get 8[tex]\pi[/tex]r. My question is, what is the meaning of this 8[tex]\pi[/tex]r? If you arrange the 4[tex]\pi[/tex]r2 into a new circle, say of radius p, the perimeter works out as 4[tex]\pi[/tex]r, where 'r' is the old radius of the sphere. You would think that the 8[tex]\pi[/tex]r, then, must be the perimeter of the 'net' of the sphere, whatever that is. Is that this '9-gore' idea, or is that just a practical approximation? Is there a simple formula for its perimeter? If it is 8[tex]\pi[/tex]r, is there any significance in the fact that it seems to be twice the smallest perimeter that would enclose such an area?- or is my reasoning all wrong? Sorry about the flying pies!
Thanks in anticipation,
Aeneas
HI Aeneas! :smile:
(have a pi: π :wink:)
The reason why differentiating the volume gives you the surface area is that the volume is made up of shells of that surface area.
(Similary, differentiating πr2 for the area of a circle gives you 2πr for the circumference, and it also works for the volume and surface area of any n-dimensional "sphere".)
But the surface area isn't made up of shells of anything, so differentiating it doesn't give anything geometric.
(sorry, but the rest of your post I didn't follow :redface:)
1. What does the "8πr" in the formula for differentiating sphere volume represent?
The "8πr" in the formula represents the surface area of the sphere. This is because the formula for differentiating sphere volume is given by V = (4/3)πr^3, and when we differentiate with respect to r, we get dV/dr = 4πr^2. This is the formula for the surface area of a sphere.
2. Why is "8πr" used in the formula instead of a different value?
The value of "8πr" is used because it is the derivative of the volume formula with respect to r. This means that when we differentiate the volume formula, we get the surface area formula, which is what we need to calculate the surface area of a sphere. Using any other value would not give us the correct result.
3. How does "8πr" affect the calculation of the sphere's volume?
The "8πr" term is used in the formula to calculate the surface area of the sphere. This means that it does not directly affect the calculation of the sphere's volume, but rather is used as a step in the process of differentiating the volume formula to get the surface area formula.
4. Can the "8πr" term be changed or replaced with a different value?
No, the "8πr" term cannot be changed or replaced with a different value. This is because it is the derivative of the volume formula with respect to r, and any other value would not give us the correct result. However, we can use different units for r, such as centimeters or inches, to get the volume in different units.
5. What is the significance of the "8π" in the "8πr" term?
The "8π" in the "8πr" term represents the constant value of the surface area of a sphere. This value is derived from the formula for the surface area of a sphere, which is 4πr^2. When we differentiate this formula with respect to r, we get the value of "8π". This constant value is important in calculating the surface area of a sphere and cannot be changed or replaced with a different value.
  • Calculus
  • Calculus
  • Calculus
